Question about Nokia 1110 Cellular Phone
"nokia 1110: no display
The surface of the main board which the lcd connector will contact is removed,
  • 490 Answers
Take fone to nokia care to fix hardware issue..thnx..
Posted on Oct 22, 2007
SOURCE:
C41 lock thish machine
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine. When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
Feb 08, 2013 | Toshiba e-Studio163 Copier
Tip
Samsung LNR408DXX XAA
TV has sound but no picture and the menu won't display.
Remove back, inner cover that is over the pc boards.
On LCD controller board next to the connector that goes to LCD panel check
cp this is a surface mounted component remove it and put a jumper in its place. I have done this and the result was a working TV.
on Sep 28, 2010 | Televison & Video
When i am calling or receiving a call the person on the other handset cannot hear what i am saying
Kindly check your cellphone's microphone.... it might be defective or inoperative. If your cellphone is equipped with a handsfree system, try it. This could solve or confirm your problem.
Jun 01, 2011 | Cell Phones
I have a blank line running vertical down my screen about 5" wide it is over the main menu I tried other inputs resetting. what is the problem and can it be fixed
This sounds like a problem with the T-CON board. This is the LCD controller board for displaying images on the screen.
Some times the contacts on the connectors do not make good contacts for whatever reason.
IF you know how to work on electronics or have a friend with knowledge/skill you may be able to fix it.
>UNPLUG the set and all attached cables.
>Lay the set face down on a cloth covered surface.
> Remove the back cover.
> Remove the shield over the T-CON board.
> Disconnect AND reconnect the cables to the T-CON board. Be careful here. The connectors will have a clip which must be released to remove the cable. Hopefully this will clean the contacts.
If it's not fixed, try it again.
If the problem is not solved you can try replacing the T-CON board. Make sure the part numbers are the same.
YOU CAN TEST THE SET BEFORE THE BACK COVER IS RE-INSTALLED BUT BE CAREFUL. IT'S ELECTRIC !!
>Replace the shield over the T-CON board.
>Replace the back cover.
>Try the set.
You can search for T-CON board from;
www.shopjimmy.com
eBay
http://www.tvpartsandmanuals.com/
http://magictvparts.com/
etc
The board will look something like;
Feb 17, 2011 | Samsung LN52A550 LCD TV
I have an vizio 32"
This looks like the cables connected to the T-CON board may have worked loose.
The T-CON or timing controller, is what sends the video signal to the LCD (sometimes called LCD controller). The cable connectors on this board have very small contacts. Sometime some of them can become loose because of heat, contamination, shaking etc.
IF you know how to work on electronics or have a friend with knowledge/skill you can repair it.
DO THIS ONLY IF YOU KNOW HOW TO WORK ON ELECTRONICS.
> Disconnect all cables/cords on the back of the set.
>Lay the set face down on cloth covered flat surface.
>Remove the back of the set.
>Remove the metal shield covering the T-CON board. This board generally located in the center near the top.
>You can wiggle the T-CON cables around (for better contacts) to try and get the streaks to go away.
> Set tv upright so it is stable.
> Reconnect the signal source and power cord. DO NOT TOUCH ANYTHING ON BACK OF SET!
IT IS ELECTRIC !
> Use the remote to turn on the set. IF the streaks are gone, then turn set off
and UNPLUG THE SET and remove the input signal cable.
Resume operation.
IF moving the cable does not improve the signal you can disconnect/reconnect the cables and see what the picture looks like. Be careful not to damage the connectors. They may have clip that must be released first before removing.
IF disconnect/reconnect the cables does not work you can purchase another T-CON board and install it. The boards are relatively inexpensive.
I think the board will look something like this;
!bw!llnwcwk~$(kgrhqn,!icev1+0f2hlbmg89w0)sq~~_1.jpg?set_id=880000500f
Feb 16, 2011 | Vizio L32 32 in. LCD HDTV
I got a C440 error code sub code "7" with Toshiba E-Studio 352 copier. I tried to reset using 0/8- 400 but still the error code appears. what is the possible defective parts?
Hi how are you this is jack ...([email protected])..
Dear follow the procedure
[C440] Fuser abnormality after abnormality judment.
CN455/456).
please vote me.
Thanks
Best Regards,
Jun 08, 2010 | Toshiba Office Equipment & Supplies
I have a samsung 40 lcd tv that needs a motherboard replaced how can I do this
Do you have a replacement board? What exactly is a motherboard in the tv? The main board with cpu? Open the back of the set and take digital pics of everything there with close up shots of the main board and all its connectors so you will be able to re-assemble the same way. Don't trust your memory. Unplug the set also, use an anti-static work surface and grounding strap. disconnect the wires to the board first then remove the screws holding the board. Don't drop or loose anything in the set. Install the new board and screw it into place, re-attach the wires. Plug it in and try it. If it works, re-install the back.
Mar 22, 2010 | Samsung LN40B530 40 in. LCD HDTV
My Sharp Carousel R-510HW 1200 Watts Microwave oven will not respond if I press any of the buttons. Have tried unplugging the unit and readjusting the plate with no success.
On these models, the LCD is connected to the main control board via a rubber connector known as a "zebra strip".
Sometimes the connections can get contaminated.
One can take the control board off and clean the contact surfaces of the board, the edges of the zebra strip and the connection side of the LCD glass with high-grade isopropyl alcohol.
See drawing below.
If you don't want to tackle this, we do it for $39.95 for customers nationwide.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Jul 08, 2008 | Sharp Microwave Ovens
Bad SMT connector on main board
mmm. a very small tipped soldering iron
while working under a mantis pcb magnifier.
you'll need a steady hand.....
don't however try to remove the sm connector, this will probably only wreck the pcb. try to use small wires to make the connections and bypass rather than try to rescue the connector.
Feb 25, 2008 | Dell 3100MP Multimedia Projector
No display
lcd alrigth but it ask security code
Aug 22, 2007 | Nokia 1110 Cellular Phone
Nokia 1110 Cellular Phone Logo
73 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
