Question about Nokia 1110 Cellular Phone
No display the surface of the main board which the lcd connector will contact is lose
Lcd alrigth but it ask security code
Posted on Oct 25, 2007
SOURCE:
Hobart scales lines in display
All LCD displays have a connector from the main board, and it may also be ON the main board, and may have a long, special connector that is layers of silicone and conductive material that connects the back of the glass display with the connection points on the PC board.
When one of these points is not connected, you can get a blank line or a dark line on the display. Either way, you have to take the front panel off and try a few things. Sometimes just disconnecting and reconnecting the display connector is all that is needed. In the case of the silicone connector, the screws or clips that hold it together need to be loosened, the connection moved, and then re-tightended.
In the case of an intelligent display, there will be just a few wires, as few as 5 or so. In this case, the fault is in the display itself, and you have to get a new LCD display.
Jun 11, 2014 | Hobart Quantm1-1ss Quantum Self-service...
Solution for black display
There are many relating problems regarding the issue.To Change LCD, secondly Main Strip,thirdly Main strip connector and Display IC(Filter).So, the first step is to change LCD and the Main Strip.If the problem still persist you need to the display IC and to check the Strip connector.But in my advise better to contact mobile repairing shop.Good luck.Thanks for visiting fixya.
Oct 17, 2011 | Nokia 6500 Slide Cellular Phone
Blank but still has sound
Its a matter of losing the display,eventually you can hear any sounds or access receiving calls and messages. It can be fix by unscrewing the screws located at the back panel,sometimes when the phone accidentally dropped on the ground,lcd flex connector dislocate from the lcd terminal in the main board.put it back and check if its working,if not,service center will be the next option to fix the problem,it might need a new lcd replacement.
Jul 28, 2011 | LG GD510 Cell Phone
I have a blank line running vertical down my screen about 5" wide it is over the main menu I tried other inputs resetting. what is the problem and can it be fixed
This sounds like a problem with the T-CON board. This is the LCD controller board for displaying images on the screen.
Some times the contacts on the connectors do not make good contacts for whatever reason.
IF you know how to work on electronics or have a friend with knowledge/skill you may be able to fix it.
>UNPLUG the set and all attached cables.
>Lay the set face down on a cloth covered surface.
> Remove the back cover.
> Remove the shield over the T-CON board.
> Disconnect AND reconnect the cables to the T-CON board. Be careful here. The connectors will have a clip which must be released to remove the cable. Hopefully this will clean the contacts.
If it's not fixed, try it again.
If the problem is not solved you can try replacing the T-CON board. Make sure the part numbers are the same.
YOU CAN TEST THE SET BEFORE THE BACK COVER IS RE-INSTALLED BUT BE CAREFUL. IT'S ELECTRIC !!
>Replace the shield over the T-CON board.
>Replace the back cover.
>Try the set.
You can search for T-CON board from;
www.shopjimmy.com
eBay
http://www.tvpartsandmanuals.com/
http://magictvparts.com/
etc
The board will look something like;
Feb 17, 2011 | Samsung LN52A550 LCD TV
Problem is that when we open the camera white screen display on lcd ,no pictures display but movie recording is ok.
Connecting flexible cable between lcd board and main board of camcorder seems lose, open lcd cabinet and insert flexible cable in connector of lcd board properly to get image in lcd screen.
Below image shows flexible wire and connector on lcd board of MHS-CM1 camera.
Hope these info will help you.
Thanks.
Nov 17, 2010 | Sony MHS-CM1 HD AVC Camcorder
I have a nokia 1208,in which the back light is glowing n there is no display.PLz help me,wat is to be done?
You have to replace the screen.Please contact your nearest Nokia service center for a genuine accessory.
Jan 01, 2010 | Nokia 1208 Cellular Phone
My screen can't display correctly info.
align the contact of interface connector of lcd and main board or change display i.c.
Dec 17, 2009 | Nokia N70 Cellular Phone
No graphic display
If blank, or some segments missing, it can be the connector to the main board, (usually a ribbon) or it can be the rubber connector electrode that links the lcd glass to the circuit board connectors. If you have the inclination, and patience, and a steady hand, and are confident... (alot of "and's" there ;-) you can take it apart, remove the LCD display, take it apart (usually by bending a few metal tabs, the thing will come out, and if you gently separate all the layers it will come apart fairly easy. Then you will see the rubber edge connector that goes to what looks like clear glass (but it actually makes contact there) to drive the segments. What you need to do is gently clean the rubber (both sides) and the gold board contacts (leave the glass display conmtacts part alone) then re-assemble the thing and you may get your display back. This symptom can happen to some LCD displays left in extreme temperature cycle enviorments, or other harsh conditions... or a garage for a few years.. You never know ...
If this does not bring it back, check the cconnectors for dirt (if face is detachable, I don't recall on that exact model if it is or not).
and then go further to the driving circuitry on the board.
Dec 22, 2008 | Pioneer DEQ-7600 15-Band Car Equalizer
Bad SMT connector on main board
mmm. a very small tipped soldering iron
while working under a mantis pcb magnifier.
you'll need a steady hand.....
don't however try to remove the sm connector, this will probably only wreck the pcb. try to use small wires to make the connections and bypass rather than try to rescue the connector.
Feb 25, 2008 | Dell 3100MP Multimedia Projector
"nokia 1110: no display
take fone to nokia care to fix hardware issue..thnx..
Aug 22, 2007 | Nokia 1110 Cellular Phone
Nokia 1110 Cellular Phone Logo
22 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
