Question about Brother DCP-330C All-In-One InkJet Printer
Brother DCP 330C 'unable to clean 46' printer will not print
Brother DCP330C recon from Brother 14 months. Screen message 'unable to clean 46' m/c will scan,copy to computer but will not print
Many thanks
  • 3 more comments
  • HAS BEEN Mar 30, 2009
    Many, many thanks for your time and info. Got desperate so have bought another printer!
  • kenjoy May 20, 2009
    my printer has the same error message. Help!!!
  • Ray M. May 11, 2010
    i've responded to this on an above post.
  • Anonymous Mar 17, 2014
    my brother printer DCP -J125 cannot print because cleaning
  • Anonymous Mar 27, 2014
    i do the cleaning too many times but still the same...the alignment is out of line..the printing result is blurred and out of line..
  • 215 Answers
Responded to this on a error 46 post by joachim.
hth,
razors
Posted on Mar 30, 2009
SOURCE:
My printer brother dcp-330c have "unable to clean 46" problem.. the answer in your website doesn't help as i was unable to enter the maintenance mode from the instruction.. my printer does not...
I developed the same problem "unable to clean 46" on my brother dcp -330c printer.. after taking to a maintenance guy... he told me to remove my ink absorption pads and wash them out with water and leave to dry then once dry replace back in..
Apr 14, 2011 | Brother DCP-330C All-In-One InkJet Printer
I have a DCP-330C and the error message unable to clean 46 comes up
The error message "Print Unable 46" is an indication that the machines ink absorbers are almost full. The ink absorbers hold liquid and dried ink after it has been purged from the print head. These absorbers can control enough ink for the expected life of the machine.
There is a possibility that this message may have occurred in error. Upgrading the firmware of the Brother machine may resolve the issue. Follow the procedure below to determine if a firmware update is required:
-if the display screen is displaying an error message, press the STOP/EXIT key to change the LCD to the main screen.
-press the # and * key at the same time. The first 2 characters on the top row will determine the ROM version.
If the ROM version is OE or greater (example: OF, OG, OH, etc), the firmware does NOT need to be upgraded. If the ROM version is OA, OB, OC or OD, follow the procedure on this link to upgrade the firmware.
If the message "Print Unable 46" continues to appear on the display the Brother machine after completing the firmware upgrade and your machine is within warranty (even if it's not under warranty you have to do the same thing), you have to take it to a Brother Authorized Service Center. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000059/faq002659_000.html?reg=us&c=us&lang=en&prod=mfc290c_all&Cat=11
Nov 30, 2010 | Brother DCP-330C All-In-One InkJet Printer
My Brother DCP 330C says " Unable to print 4F" What does this mean and what can i do to fix it please??...... Thank you Kindest reagrds Milli
Hi millih,
An error coded 4F means that there is a mechanical problem with the printer, usually, "unable to print means one of two things. Firstly an empty cartridge, secondly a full absorbing pad. I am guessing that the latter is not the priblem as the code would be #46, so if the ink cartridges are empty, get them replaced or refilled then disconnect the machine from the power for about 5 minutes, then reconnect and it should reset itself.
Sincerely
rover620
Sep 20, 2010 | Brother DCP-330C All-In-One InkJet Printer
Unable to print . Message says ' Black cartirdge
Disconnect power for 5 minutes then power up to reset printer, make sure cartridge is secured properly. If it still happens, see my related solution on Error code #46.
sincerely
rover620
Sep 08, 2010 | Brother DCP-330C All-In-One InkJet Printer
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Unable to clean 46 error for a brother DCP-330C printer
Error "unable to clean" on Brother MFC Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 28, 2010 | Brother DCP-330C All-In-One InkJet Printer
DCP-330C All in one
Hi. I had unable to print and unable to init 46 error. Any help available to reset my machine please. Thank you
Jul 27, 2008 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP 330C
This COULD BE that there is some paper stuck in the dcp. Open cover and try to see if there is some paper left in the machine. I ve noticed, that -seeing from behind!- on the right side paperpieces are stuck and disturb the disk (foil) which give the printer info what to do. Open cover and try to look into the edges (seeing from the front: its the left side -where the modell name is printed) In some cases this means that the purgecamshaft is defective.
Aug 17, 2007 | Brother DCP-330C All-In-One InkJet Printer
Brother DCP-330C All-In-One InkJet Printer Logo
3,049 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
