Question about World Wide Sourcing (CFB5521F242WH) Ceiling Fan
Need replacement bowl
I have a world wide sourcing fan that has a broken glass bowl. the one with the two chain holes. Where can I get a replacement
  • 944 Answers
Depends where you are. These are the guys who sell the fans in the US (Through Amazon): Direct link; http://www.antonline.com/c_0_18317_5__3268_1_50.htm Company name: ANTonline Street address: 33 Mansell Court Suite 200 Roswell, GA 30076 USA Web site: http://www.antonline.com Customer-service phone, fax, and e-mail Phone: 877-293-9797 Fax: 770-874-0789 Email: support@antonline.com Hours: 9am-6pm Mon.-Fri. EST Also the fan is Known by the "Boston Harbor" name (same model number). If you are outside the USA, please ask again. Hope this helps :) ps the Amazon list price for the whole unit is $77, so check on replacement bowl prices before ordering - if the fan is more than a few years old, it may be better to replace completely.
Posted on Aug 22, 2007
Need to replace due to breakage, but it has 1 center hole and 3 other pulls and cant find one like it
If you're talking about a glass bowl I would need the make/model of fan. If it was an add on light then I would need the model # of the light kit.
Jul 10, 2015 | Dryers
Why does fan chain bind at light housing on 10207 eastover
Take the glass off &make sure the chain goes through a hole in the fitter before it goes through the glass.
Sep 04, 2014 | Dryers
Pull chain hanup on glass light cover
Take the glass off and see if there is a hole in a small plate below the light sockets. The pull chain should go thru this hole first before the glass. I don't know if this has it or not being that it's a low-end store brand fan.
Jul 28, 2013 | Hampton Bay Ceiling Fan. Hawkins 44 in....
How do you open a wu pin switch. the chain broke & went inside switch
My chain was broken about 1.5 - 2 centimeters inside the wu pin. I took a chain connector (with some chain hanging off one end) and fed it into the hole, trying to connect it to the broken chain. After a couple of tries I managed to get the end of the broken chain inside the wu pin to connect to the chain connector by gently pulling down once it was somewhat inside the chain connector. I hope this works for you. I was so glad I didn't have to resort to cutting any wire or making a trip to a home improvement store!
Jun 13, 2011 | Westinghouse Electric Westinghouse...
I have a Hunter fan with a bowl type light fixture. The chain that controls the fan goes through two holes, one through the metal disc that the bowl sits against, and the other through a hole in the cap...
Sorry to read about your problem, I hope this helps you out.
Either you take a glass drill and make the hole a little larger, or just to put a bevel on the holes, or take a candle/wax and rub on the chain, where it it goes thru the hole. last but not least, you can try to convert to a string,instead of a chain.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Hunter Ceiling Fan Control Switch
Where does one source a replacement cpu heatsink
Any computer store or www.partselect.com may have it or kijiji or ebay
You have this vast expanse call the world wide web (WWW)
Happy searching
Jul 31, 2010 | HP Pavilion (F2111-60950) CPU Heatsink &...
Ceiling Fan Chain Broken Off
You have to kill all power to the fan and start taking it apart till you get to the switch. There's usually just a bottom plate to remove. Sometimes lights. Replace switch and reassemble. If some chain is still connected to the switch you can add chain to it and won't have to replace switch.
Oct 04, 2009 | Dryers
Ceiling fan stuck on high.
The fan usually has two holes for separate switch control. See if there is another hole on the opposite side that a switch can be added for separate control. Then go to the hardware store and buy fan switch with pull chain. Ask for help finding them, they have them in the special switch section of lamp parts. Install new switch (es) and wire the one the way it is. Add the new one and take the light or fan wire out from the old switch and put it to the new switch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 08, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Broken glass steamer bowl
glass breakes you can fix it so replace it
Sep 08, 2008 | Cook's Essentials Cooks Essentials Arome...
World Wide Sourcing (CFB5521F242WH) Ceiling Fan Logo
233 people viewed this question
Top World Wide Sourcing Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you a World Wide Sourcing Dryer Expert? Answer questions, earn points and help others
