posted by kat618 on Aug 22, 2007
We just bought a KLH 2.1-Channel Home Theater Speaker System. We found when we got home there were no installation directions. Can someone help with this?
Best Solution
posted on Aug 22, 2007
This means that you have purchased a three piece home theatre system. Two tweeters and a sub-woofer. Assuming you are using a Stereo player (Tape/CD/DVC)you have to connect the Left Output of the Stereo placer to the Left Input at the back of the Sub-Woofer and the Right output to the Right input of the subwoofer by cables. Then take tweeters and connect them to Right speaker and Left speaker output at the back of the sub-woofer ( note if the speakers are marked L/R, then connect them to the subwoofer output accordingly. In case you are using a 5.1 player, then only connect the front right and front left to the Right and Left input at the back of the subwoofer. You are and you can now start playing your music or movies and and you will get theatre quality sound.
Comment by balaniyer, posted on Aug 22, 2007
This means that you have purchased a three piece home theatre system. Two tweeters and a sub-woofer. Assuming you are using a Stereo player (Tape/CD/DVC)you have to connect the Left Output of the Stereo placer to the Left Input at the back of the Sub-Woofer and the Right output to the Right input of the subwoofer by cables. Then take tweeters and connect them to Right speaker and Left speaker output at the back of the sub-woofer ( note if the speakers are marked L/R, then connect them to the subwoofer output accordingly. In case you are using a 5.1 player, then only connect the front right and front left output of the player to the Right and Left input at the back of the subwoofer. You are and you can now start playing your music or movies and and you will get theatre quality sound.
Rating Locked! (?) kat618 has rated this solution as Thanks for Trying
Can you Help with these Home Theater Speakers and Subwoofers problems?
Built-in home theater package...
I'm remodeling and have the... Answer This...
Need to replace one of the 5.25
I bought a used Boston... Answer This...
Repair Service
Find Home Theater Spe. Repairman Near You:
