I have a 4 channel Alpine amp that I have to send back for repair. It was running a set of component speakers (6 1/2" and 1") and a pair of 4x6 plate speakers. Meanwhile so I have tunes I installed an MTX 2 channel amp and ran the speakers parallel. From what I understand this makes it a 2ohm load which the amp is capable of handling. Is this correct? When I first hooked it up I got a noise from the rears even when the deck and amp were turned off. It increased and decreased when I pressed and released the gas pedal. Seems to have gone away now. Any ideas or suggestions? Thanks
if you get a buzz or whine noise that changes on acceleration of the engine,,, for some reason your amp is picking up alternator "noise"
the most common cause of this is a corroded/dirty/non bare metal/poor ground connection to the cars chassis form your amp..
recheck your connections and make sure!
Another trick is to run the rca cables on the opposite side of the car as the power wire. Also if your rcas have a small wire in the center DO NOT USE IT FOR A REMOTE WIRE!!! it is meant to be grounded on both ends to eliminate noise.
Also p.a.c.(pacific accessory corporation) makes a noise filter you can put inline betwen your rca cables and the amp. I have had some sccess with that..
all the songs play when it is connected to my computor,but when i connect it to my car stereo usb...
(More)
all the songs play when it is connected to my computor,but when i connect it to my car stereo usb port not even half the songs play.Any suggestions?
My boat has fairly good quality of sound when listening to a radio station, but when i put a cd in,...
(More)
My boat has fairly good quality of sound when listening to a radio station, but when i put a cd in, i only hear the sound coming out of the speakers on the right side of the boat. Then if I plug an ipod into the aux outlet I can hear out of both sides of speakers, but it is very scratchy. How can I fix this?
An Ipod will play the songs but my USB 8GB Kingston Data Traveller device wont Niether will my Cowan...
(More)
An Ipod will play the songs but my USB 8GB Kingston Data Traveller device wont Niether will my Cowan D2 2GB. i bought this HU from Kenwood so i can use it this way and not to be able to use it sucks. Do i need to format those devices in some other way?
