Question about SanDisk Sansa e250 MP3 Player
Synchronoze to continue music subscription
I have downloaded music from napster and they used to work fine but now wenever i try to play the napster tracks(WMA still works)the Synchronizre to continue music.... appears. Wats wrong?
I treat my Sansa like a disk drive and simply transfer the files from my hard drive to the Sansa via Explorer.  The tracks purchased from Napster can be downloaded to your hard drive.  Then I exit Napster and use Windows Explorer to simply transfer the data.  Works great for me for the past month!
Posted on Oct 28, 2007
SOURCE:
How do i put songs from my PC to my psp? i have it connected to the computer with the usb connecter. i have dragged music files from the computer to my music folder onto my psp, but then when i look at it,...
hi, there is an option on the psp menu taht enables the psp to play WMA files on it. just enable it and they should work..
If this doesn't work try to convert the zzzz.WMA into zzzzz.mp3 format, you can get a FREE WMA to MP3 converete at www.download.com
good luck
Oct 07, 2009 | Sony PlayStation Portable (PSP) Slim...
Tip
Remove DRM from WMV WMA
What is DRM? Why do we remove DRM from WMA WMV? Have you download music and video from Windows Media Player, iTunes, Rhapsody, Napster, bearshare, Spiral Frog, BBC iPlayer downloads? These popular music and movie download programs among the music fans always come with a disgusting word - 'DRM'.
DRM (Digital Rights Management) - The anti consumer copy protection that prevents you from using music or movies in a way that suits you. For example, if a WMA or WMV you downloaded from WMP(windows media player) that has DRM, you can only play it back on a compatible device, so if every piece of music had DRM on it you would need to buy the same track on CD to listen in your CD player or car, as an iTunes download to play on your iPod, as a ms store download to play on your Zune etc, but since you paid for it once you shouldn't be forced to pay for it again and again and again, remove DRM license from WMA WMV and other protected files then you can play the music video on phone, iPod, Zune, PSP, CD player, pc, burn DRM protected WMV files to DVD and copy drm protected wmv itunes m4v movie files to anything else that you can listen to music video on.
How to remove DRM from WMA WMV? I got a few methods listed below:
1. Burn and rip
Actually, there is a common free method to remove DRM from WMA with 2 steps, Step 1 Burn the protected WMA to a CD
Step 2 Rip them off to your computer, then the DRM should be removed from the WMA files.
But it's not very convenient and may wear out your CR-ROM. And windows media player can only burn and rip the WMA (or you will need DVD copy and DVD ripper for other formats).
2. Re-record
One of the most common and simple technology is recording the DRM protected WMA then use an ordinary converter to convert the recorded and unprotected files. Because this technology is easy to realized and easy to support more DRM formats besides protected WMA it is welcomed by most of the DRM converters like the SoundTaxi, NoteBurner , etc.
But there are some disadvantages for those programs.
1. The conversion speed won't get much improvement due to the long recording process.
2. Much audio and video quality could be lost during the recording process.
3. Hook
Hook is another new and more complicated technology which can be used to remove DRM license from protected WMA WMV files. Comparing with recording process, these sorts of drm removal have much higher conversion speed, but it's hard to make it support some DRM formats with new and lofty encrpytion tachniques.
And as far as I know, Aimersoft was one of its supporters. After giving a test for some free trials I found it is convenient to crack DRM from protected WMA WMV files with Aimersoft Media Converter, and it also supports other formats conversion like AAC, AC3, WAV, M4A, M4b, MP3, etc.
media-converter-sc.gif Ok, Hope you can get some useful resources from this article
Remove DRM from WMA WMV and your favorite music videos to release you music life.
Have Fun:)
on Mar 15, 2010 | Office Equipment & Supplies
Tip
How to remove DRM protection from Napster
Napster music contains DRM protection, which always in a DRM protected WMA format. I
f you want to put it into iPod, Zune, or other MP3 player, you have to remove DRM protection from Napster music first. Here is a detailed guide to show you how to remove Napster DRM.
You may need specific Napster DRM Removal Software to strip this DRM copy protection from these Napster WMA tracks. This article presents you a easy way: using software, such as Wondershare Music Converter to remove Napster protection to non-drm ones . This software is especially useful for alleviating compatibility issues.
Here is the step by step tutorial for the program:
1. Download Wondershare Music Converter, install and run it. Then, add DRM WMA music onto it. You can either click 'ADD' button to insert the music you want to convert, or easily drag & drop the files into 'Getting started' table. This software supports batch conversion, so you can add several files at a time.
2 Choose MP3 or WMA as your output audio format. Click the setting button, you can set the parameter with pleasure. You also can change the output file location, or the output files will be located as default.
3.Last thing, click the start button, and the converting process is beginning. After converting, the audio are DRM-ripped. Just finish the process of removing DRM from Napster WMA in several minutes.
Please click here to read more about this artcle
If you would like to see the demo about the details guide ,please
kindly check here :http://www.youtube.com/watch?v=IdxSWfjWe90
on Dec 30, 2009 | Computers & Internet
Can't download music from Napster to YH-920
Move all the files to the windows media player. So the songs are listed in the media player. Then connect the device and use the sync option in the media player. There may also be a sync option in napster but I think the windows media player would work better.
May 13, 2009 | Samsung Napster YH-920 MP3 Player
Creative zen music will not play on memory card
I also use Napster. Unfortunately with the music being on the memory card and not on the device itself, Napster detects this and will not play music from the memory card.
There are two things you can do to resolve this, the first one won't cost you anything. Move non-Napster music files to the memory card, leaving only Napster music on the device itself. As a Napster-To-Go device, you'll be able to play and sync without issues. The second is to purchase the tracks from Napster that you want on the memory card. Once you do this, you can play them in any compatible media - not just the Zen device.
Dec 27, 2008 | Creative Labs Zen Digital Media Player
Tip
Song Formats for Mp3 Players Explained, Part II by Tha Mp3 Doctor WMA files are...
by Tha Mp3 Doctor
WMA files are special. There are two types of WMA file, and the Mp3 or digital Audio Player documentation will not always tell which of these two types the Mp3 player will recognize. Type I is a non-licensed, or non-DRM-protected WMA file. DRM stands for Digital Rights Management, and it is Microsoft’s copyright system for music files. If you have a type of Mp3 player that will only accept non-DRM protected files, the product specs for your player will NOT mention the words "DRM" or "Windows Plays ForSure" on them (unless they are using it in the negative, such as "this player does NOT support DRM encryption"). In MOST cases (there are more and more exceptions), Windows Media Player will convert songs from CD’s that you personally bought from the store into non-DRM encrypted WMA format.
The second type of WMA file is a DRM-encrypted WMA file, and there are several subtypes of these. Every DRM-encrypted file can have "play rights," "burn rights," and "transfer rights." "Play rights" mean you can play the song on your computer, "burn rights" mean you can burn the song to CD, and "transfer rights" mean you can transfer the song to your Mp3 player. Once again, not all WMA files are created equal. If you have a BASIC subscription to a music service such as Napster, you may download songs that have "play rights" – you can play them on your computer without any problem; but they may lack burn rights and transfer rights – so you cannot burn them to CD, or transfer them to your Mp3 player without incident. The solution here is to upgrade your music service to the premium, more expensive subscription that includes burn rights and transfer rights.
Then there are "fixed-term" licenses and "unlimited" licenses on WMA files. A fixed-term license will expire after so many days, months, or years; and will require you to resynchronize your songs to the music service or to your computer in order to continue playing them. This is a key reason behind songs "disappearing." Napster and Rhapsody are two examples of music services with fixed-term licenses. You must resynchronize your Mp3 player to your computer every 30 days, and you must keep you music service subscription active. If you let your subscription lapse, then the songs that were once working will no longer be playable. Once again, the only remedies are to renew your music service subscription (legal), convert those songs into a different format that the Mp3 player will recognize (possibly illegal), or to use DRM-removal software (illegal and unreliable).
One word needs to be said about burning your own personal CD’s and transferring them to the Mp3 player. CD’s naturally put song files into CDA format. Most Mp3 players do not recognize CDA format. So you will have to use Windows Media Player (easiest, IMO) or some other software to convert the CDA files into Mp3, WMA, or some other format that your Mp3 player recognizes, BEFORE you can transfer them to the Mp3 player.
Real Audio files also have an encryption system, and may not work with most Mp3 players – check your product documentation.
Audiobooks are in their own format and bring their own special problems which fall outside the scope of this article.
There are a ton of music services out there. iTunes uses AAC format. Napster, Rhapsody, Bearshare, Spiral Frog, and many others use DRM-protected WMA format nowadays. Limewire and Morpheus generally use Mp3 or non-DRM-encrypted files. Double check the formats that your player will support BEFORE choosing a music service. Conversely, if you already have a music service, choose an mp3 player that’s right for your particular service. Note: most store workers do not have the faintest idea of what I have been discussing in this article, so don’t trust their judgment – educate yourself first.
AS A GENERAL RULE OF THUMB (as always, there are exceptions), all Mp3 players recognize the Mp3 file format. The Mp3 file format is the least problematic of all the file formats. It takes up less space on your Mp3 player than most file formats – so you can load more songs onto your player than if you were using other formats. So, if you download all of your songs into Mp3 format, or tell Windows Media Player to convert your own CD’s into Mp3 format, then you will rarely go wrong.
on Jun 09, 2008 | iRiver H340 MP3 Player
GPX Model MW3337
well... what you can do is go to downloads.com and download limewire and get your songs off of that
Oct 21, 2008 | GPX MW3337G
Notification "Cannot play"
The songs are in the wrong format.
The format of the songs are wrong in one way or another. Each Mp3 player has a product spec sheet that lists which type of music file it is compatible with (Mp3, WMA, WAV, AAC, etc). You can't play iTunes songs, which are AAC format, on a player that only accepts Mp3 or WMA format.
The second formatting issue has to do with the DRM license on the songs you have downloaded. Right click a song that gave you an error, click on "Properties," and click on the "License," "Media Usage Rights," or "Digital Rights Mgmt" tab (wording varies by configuration). Not every song allows unlimited or even one-time transfer to a "portable device" (code word for "Mp3 player" in this case). Also, some songs are fixed-term - they expire after a while - sometimes in as little as 24 hours.
To get around this, convert every song to Mp3 format. Either that, or upgrade your music service subscription to the highest pkg they have available and never cancel (Napster's basic music svc, for instance, does not let you transfer to an Mp3 player, but their "Napster To Go" upgrade does allow transfer).
-Tha Mp3 Doctor
Mar 18, 2008 | Sony NW-E107 MP3 Player
Won't paly WMA files that I bought online!
I remember reading somewhere that if you upgrade your firmware of your H340 from US to international to get video you lose the ability to play DRM music. I from this I would that the international version can't play the copy protected files. I am not sure of the legalities in your location, but you may be able to work around the copy protection. Maybe a google search would give you some hints.
Nov 13, 2006 | iRiver H340 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
113 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
