Polaroid 7 Inch Tablet-One Size Logo
Anonymous Posted on Jun 21, 2013
Camera What is the fix for when the camera comes up and says unfortunaltly gallery has stopped what does this mean I just bought this tablet.
William Alequin
Level 3:
  • Polaroid Master 932 Answers
  • Posted on Jun 21, 2013
William Alequin
Polaroid Master
Level 3:
Answers
932
Questions
0
Helped
201593
Points
2855
Most probably that the gallery folder within the root of the tablet is not present or was deleted. In order to find that out, you need to have a file manager installed like ES Explorer or Astro. Check to see if you find a DCIM folder. You didn't post if you bought it brand new or used, but I'm guessing used. I it's brand new, just take it back, since it should be under warranty.
My gallery has stopped working. How do i fix it?
goto myprofile. click it camera/pictures then see it when you needs to see on your gallery.
How can I get gallery on mybtablet to see pictures I took with camera
Get in touch with the manufacturer's support people.
My nexus 7 i cannot retrieve photos from my gallery ?
To fix this problem u can swipe left to go to the next picture or in the gallery. Another thing u could do is go to you setting den go to clear data. But to do that you have to have your pictures saved to your SD card (if u have one)
How to fix camera can not connect on hannspree tablet
Hard reset your tablet , if your tablet is updated the camera stops functioning. Hold power and Up or Down volume button to hard reset.
1helpful
How to delete or remove all photos stored in samsung galaxy tablet 3 gallery?
Although I do not have a Galaxy Tablet 3, I own a Samsung Galaxy S3 phone and I believe both might use the same technique.
There are two ways to erase the photos from the gallery. I generally use the first one, using a computer although you may prefer the second one that works directly in the tablet.
In general, when you connect an Android device that has a camera to a computer, it will display in the Windows Explorer an Icon with the name of the device, if Windows has the right drivers for your device installed. At the same time, an icon of a USB connection will be shown in the device's screen top bar.
If you click on your device's icon at the computer, you may find one or two folders (in general, "Card" and "Phone" in cell phones" and "Card" and "Tablet" for tablets). The "Card" folder appears if you have an SD card inserted in your device. Depending on where you set up your tablet to store the photos, inside those two folder you will find another folder called DCIM (that stands for Digital Camera IMages). Check on both to locate where your photos are. Then, select the ones you want to erase or select them all pressing CTRL + A and then press DELETE on your keyboard.
The other way is acting on your tablet. Touch the GALLERY icon to open the Gallery app. If you have more than one folder in your gallery, touch on the folder you want to erase the photos, to select it. If you have only your Camera folder, touch and keep you finger touching any of the photos for around two seconds. The photo will be selected with a green mark and a rectangle will appear at the top, close to the Gallery icon, indicating "1 selected". Touch this rectangle and the option to either "Select all" or "Unselect all" will appear. Selecting all photos will turn them all marked. Then, touch the "Trash can" (delete) icon and you will be asked if you want to delete all pictures. Touch OK and they are all gone! See images 1 and 2 attached to this note.
Hope you may find this information helpful!
Regards,
Miguel L. Martins
1helpful
Gallery error
Hmmmm...
Sounds to me that your tablet is syncing pictures from a cloud or another account. Try turning off autosync options. Also, are you deleting the duplicates directly from the "files" I mean, not from the gallery viewer.
As for the video playing, try deleting all video player apps (or at least pause them) from the apps tools.
Hope any of this helps.
Top Polaroid Tablets & eReaders Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
nexrad_chris
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
