Routers
Problem for Routers
Generic problem for all Routers
One laptop connects but not another
By brian_cook4 on Mar 24, 2009
I've been connected without problems using D-Link DIR-655 but recently lost connection. My network list no longer even shows connection. I can connect with wire. I've called Comcast and household is connected.
Solution #1
posted on Mar 24, 2009
Not Rated)
JARRA2
Rank: Guru
Rating: 88%, 44 votes
If you use Windows XP:
First do some checks!
Confirm that your WL adapter on your Laptop is not DISABLED !
If it is, Enable it! How?
Open Control panell and then, open Network connections. Right-click on your Wireless Network Adapter and click 'ENABLE' !
Next check!
Right-click My Computer, and then click on 'MANAGE' !
On the left side click 'Services and Applications', and then 'Services'.
Find 'Wireless Zero Configuration' and double-click.
Check the Startup type is Automatic, and if the service is started.
if not, change it to automatic, and then click on START.
Click APPLY and OK, and than closle Computer management console.
Do you use some Software for your WireLess ?
If so, then close and exit it!
Do you see a network icon near the clock on the right bottom of your toolbar?
Right-click on the icon and click on 'View available networks' !
If not, then open Control panell and then, open Network connections. Right-click on your Wireless lan and click 'View available networks' !
You should see a list and your Network now?
If so, then restart your Laptop, use your WL software (if any) and try to find and connect your network.
If you don;t see any network, again close and exit the software and try to connect as I said before.
If it works, than something is wrong with that software.
Do you have a CD with installation of that software?
If so, than first UNINSTALL the software, restart your Laptop and try to install it again.
If it doesn't work, then, (again) uninstall it, restart your laptop and continue to use your Windows Wireless Zero Connection instead.
regards
Was this helpful?
Yes
No
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
Can get a connection when connected via ethernet. Can't get a wireless connection?? Worked fine... (More)
Answer
cable went out, eventually fixed and confimed internet connection via ethernet line. now router... (More)
Answer
unable to print with a brand new iMac. to an HP all in one over an ethernet connection. No luck... (More)
Answer
i can't log into the web page. I seem to be locked out and cannot access the site to make my... (More)
Answer
I have a netwave base g4 wireless router w/4. We installed comcast internet service and I can get... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Routers Experts
Top Computer & Laptop Repairmen
in , AR
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
