Question about Panasonic DVD-S325 DVD Player
Dvd-s325 comes up with error -u11 wond play dvds, reads some and not others says no disc. no very only
  • Anonymous Apr 06, 2008
    The disc is in, but it is telling me that there is no disc in. It is a Sylvania MP3.
Does anyone have information about
IC MR6710 datasheet and/or where to order it?
It is an power sply device of PANASONIC S325 DVD Player.
Tank u in advance.
[email protected]
Posted on Jan 02, 2008
I need this ic too. where can i find its datasheet.
Posted on Sep 30, 2008
SOURCE:
I recently bought some dvds from the UK. JVC XV-S65 dvd player will not play them. It reads 'region error' everytime I try to play the discs. HELP!
The dvds discs u bought from the UK is play on only the DVD player that play PAL signal format. Where u live Canada,US or Mexico?DVD players in these countries.It play only NTSC signal format.U can't change DVD players regions format,only can a DVD players that have regions free to play all DVDs discs of the world.
Feb 02, 2011 | Televison & Video
Won't recognise DVD Ram and non-finalised discs from own recordings.
Usually, the U11 error code in a Panasonic DVD player indicates an optical problem. You could of course try doing a cleaning using a CD cleaner normally readily from computer parts stores. Alternately, you can open the unit up and do a manual cleaning with soft bristle brush and/or cotton buds. Other than that, it could be indicative of a weakening laser eye which of course would require parts replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you
need additional information.
Good luck and kind regards.
Thank you for using FixYa..
May 24, 2008 | Panasonic DMR-HS2 DVD Recorder
My panasonic dvd player is displaying error u11 code wont play any dvd's
If you are trying to run a recorded DVD (saved a video or movie on to it), it could be the quality of the disc. I would recommend buying quality DVD's, the lower quality ones can create read errors (U11).
Jan 25, 2011 | Panasonic Televison & Video
My lg bd50 is able to play any normal dvds however it is unable to play any bluyray dvds!!! when a blueray is loaded into the machine you cannot even eject the disc for sometime. i downloaded updates to...
hi,
blue ray players takes one to two minute to read the content. it will not read as fater as dvd. give some time and then find out what the player says. error or no disc. also check ur BD's region and the region of the disc u inserted. BD's comes with only one region.
ok
Dec 17, 2010 | LG BD350 Blu-Ray Player
The dvd recorder has stopped recognising dvds that previously it would play quite happily. Is the likely cause a dirty lens or is it more likely to be something to do with the spindle? I get the "cannot...
I presume you hade cleaned the discs and the players optical lense before posting this request and also tried them on another player?
Basicaly If they do not work on other players then the discs have now failed for some reason: many budget priced discs I have come across only work for a few years.
If you have a 'spindle problem' then your laser is probably slowly moving off track. If so you should be able to record and then playback on a GOOD disc for a while.
May 27, 2010 | Panasonic DMR-E50 DVD Recorder
Player won't read the DVDs
some players won't play burnt discs. If you are using a factory made disc and you still get this, then you can try and clean laser lens with rubbing alcohol and cotton swab.
If the cleaning doesn't work, then the laser lens circuit will need to be replaced.
Aug 05, 2009 | Televison & Video
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
Jul 16, 2009 | Sony PlayStation 2 (PS2) Console
Mizuda dvd player wont read dvds
A couple of things To try.
1:) The DVD Player May be Region encoded, can only play certain region Dvds. ** Try different Disks**
2:) The Disk May Be Dirty-Scratched ( Towards The Centre )
** Clean The Disk With A Soft Lint-Free Cloth**
3:) The Laser Head may have a speck of dust or debris on it.
** Try a Laser Cleaning CD**
Hope this works For You.
Mike @ Compurepair.
Mar 01, 2008 | Shenzhen Mizuda DVD-999 DVD Player
Playback of dvds
is the country code different on the dvds than on the unit?
Nov 28, 2007 | Emerson EWR20V4 DVD Recorder/VCR
DVR doesn't read disc, says region doen't match
check the region of the new one probably it is region 4 made in china.your disc is a region one thats the reason why it cannot play on your new dvr which is a region 3 or 4.go on the web and see hw you can hack the code or burn a copy of that same disc.then try it in your new dvr.good luck
Jan 22, 2007 | Yamaha DVR-S120 DVD Player
Panasonic DVD-S325 DVD Player Logo
953 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
