HP Officejet 5610 All-In-One InkJet Printer
Problem for HP Officejet 5610 All-In-One InkJet Printer
I Cannot Make the Machine Scan ! What do I need to
By ebobby12 on Mar 24, 2009
I Cannot Make the Machine Scan ! What do I need to do? WE Have had the Machine about 3 Years It is wonderful .BUT!!! we never Had need of the Scan Feature Until NOW! But cannot make it work!!!!!
HELP!!!!!
Clarification Request
Posted by jimcedar on Mar 24, 2009
Do you have the instruction manual for the printer and the scanning software installed on the computer you are using?
Solution #1
posted on Oct 04, 2009
Not Rated)
solution4all
Rank: Master
Rating: 98%, 4 votes
Try this :
At first try to Copy something from the printer to get the hardware is working or not.If not call hp and Hp will upgrade the printer as you dont have warranty on this printer .Let me tell you that the upgraded printers are good and will get at very low price.
If it is working.goood luck .. Its software problem then and the problem can be resolved.
Now there is 2 probabilities.
1>The digital imaging moniter(situated at the bottom right hand corner, with a green round and a chk inside,..is either not there or the digital imaging file is corrupted)
2>Issue with the printer sw .
But the very thing you can do is try copying something from the printer which shows the hardware functionality of the printer.
Now for the 1st>> goto computer>>drive c>>programfiles(programfiles 86x for vista 64 bit) >>hp>>digital imaging >>bin>>hpqtra08 ....double click on the hpqtra08.Now try to scan again.
Didnt work.
Now for the 2nd opt>> put the sw cd if you have right click explore ..(goto step 3) but if you dont have the cd you can download the sw from hp.com >support and drivers..extract the file and goto run(search bar for vista) type "%temp%" and then click on folder starting with 7z....now goto step 3.
step 3.goto util folder>>ccc>>unistall l2 but make sure you have to unplug the usb first.
>>Small black box will appear and press enter...and wait it will unistal the printer scan driver part.
>>goto printers and faxes folder under controlpanel (printer for vista)...chk if there is any hp printer any more...if there is any printer not in use..delete them.
>>restart the sys and then goto printer sw cd drive or u can take out the cd and put that back again.
>>A installation wizard will appear.
>>click on add a device and only connect the usb once the sw tells you to connect......this will surely work if it had worked before other wise there is some problem with the cd.
In this case download the sw and reinstall the sw but unistall the prev sw.but you have to unplug the usb first.
let me know.
Best wishes
suvrajit
Was this helpful?
Yes
No
Popular Solutions for HP Officejet 5610 All-In-One
Questions and Unsolved Problems for HP Officejet 5610 All-In-One
Do you recommend HP Officejet 5610 All-In-One InkJet Printer?
Answer
Answer
Q7310A PRODACTE N.M.R OFFICEJET ALL IN ON
Answer
color printer cartridge installed in wrong slot
Answer
everything that it copies or faxes that it receives is blank
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Officejet 5610 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 821
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
