Question about JVC AV-27320 27" TV
JVC Vertical Problem
I try to solve my tv by my self, so can u give me solution of this. my TV is JVC 21" i forgot the exact model... the problem is vertical out. i try to replace the vertical ic and i solve the problem. but i found out that the output.. we have 1 inch black color at upper and lower. the picture is good and sound except the 1inch color at the upper and lower. can u give me a solution of this...
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
You need to adjust the vertical height in the Service menu.Press the SLEEP TIMER key and set the SLEEP TIMER for 「0 MIN」. Then press the DISPLAY key and VIDEO STATUS key of the remote control unit at the same time to enter the Service menu.In SERVICE MENU, press the FUNCTION ▼/▲ key to select any of the SUB MENU items. (The letters of the selected items are displayed in yellow.)You want #2 DEF - go to sub-menu and look for the height adj. FUNCTION / key Setting (adjust) the SETTING VALUE of the SETTING ITEM. When the key is released the SETTING VALUE will be stored (memorized). EXIT key Returns to the previous screen.
Posted on Aug 22, 2007
SOURCE:
Why I have a thin line across the screen in my TV model Panasonic TC 21. After replacing the vertical IC the horizontal line across the screen reduced to few inches and not as it was earlier. vertica
First, You should to replace by original part, then you should check the voltages on power supply, and check the voltage for vertical IC based on datasheet, also check the voltages on vertical section including yoke and last you should check the ESR capacitors on vertical section.
Oct 13, 2014 | Panasonic TC-21PM10RQ 21" TV
JVC flatscreen tv model Number AV-21mt35 with vertical interference? how to solve this problem?
It will be best to replace its Line Output Transformer [LOT]. It is not good to join the broken EHT wire. EHT arcing cannot be stopped by using glue.
Apr 04, 2013 | JVC AV-27720 27" TV
The vertical ic of my jvc tv model no. av f21mx5 are always burn even i replace a new one
Just check the supply voltage input to the vertical IC. If it is more than normal, this type of fault can occur. Just compare this voltage . The TV schematic will help you to find this detail. Check whether the IC is firmly screwed on to its metal heat sink.
Jul 03, 2012 | JVC AV-20020 20" TV
My television, a jvc 21 inch shows only half-screen or at times just a bright line in the middle, what could be the problem and can it be fixed ?
Yes.This tv problems it is pretty easily repair,tv have a cold soldering in a vertical IC or around that area.But must have a soldering iron and a roll of solders and know and have some basic soldering skills.Take the tv aparts and turn it on take the plastic end of a screw driver tapping arond a vertical IC or around that area.Find out the vertical IC or around that area.Turn the tv off and resolders that vertical IC or that area,will solved this problems.Or take it to the tvs shops tell them the problems.If they're give u fairly priced for a job.Like about $25-$35 maxs.
Aug 13, 2011 | GE 31GT660 TV
My 52" Projection JVC TV
Hi:
I could help u more if you give me the complete model number of your television. Without the model I do not know what Were working with.
Thanks..
Apr 22, 2011 | JVC Televison & Video
I am watching my 14 days old JVC 21"TV but
Hello
Your TVs power supply regulator section has got some trouble with it, that is why power indicator doesn't light up. You have purchased it only fourteen days back, surely there will be warranty for it. Do not open the TV. The company will give no concession if the set is opened. Send it to the authorised service center and get it repaired. Some power supply faults may fatal, and may have to spend more. Since your TV is a new model, spare part availability in the open market may be difficult. Send it to them and let them do the work. OK.
Nov 09, 2010 | JVC AV-A21M3U 21" TV
Black box taking up over 1/2 the screen.
caption box selection is on. disable caption
Jun 29, 2009 | JVC AV-27530 27" TV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
JVC TV model AV-31BP6 single horizontal line
1c4 21 is not an 1c. it is the location number under the green circuit board.
the name of the ic is written as la 7832 for example
Nov 19, 2008 | JVC Televison & Video
JVC TV
civilman, the first set has either no high voltage or is collapsed vertically, until someone checks for high voltage there is no concrete answer, the AV27730 is vertical collapse from your description, either the voltage to the vertical IC is missing or the vertical IC has failed, not a big deal cost-wise, hope this answers your questions, if not e-mail me back, good luck, BMW Rider
Dec 20, 2007 | JVC AV-27730 27" TV
JVC AV-27320 27" TV Logo
243 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
