Question about GE 31GT660 TV
GE 31GT660 picture is intensly WHITE
Picture is intense white (not snowy)& picture vibrates once in awhile & then stops. All external components are disconnected from the set such as DVD/VCR so TV runs by itself. Anntena check okay, DVD input image ALSO produces WHITE picture. Messed with adjustments resulted w/no change. Mysteriously it worked last night. Today NO. What is the problem/issue?? (Tom)
  • 398 Answers
The GE (actually RCA) 31GT660 uses the CTC187 series chassis. This chassis is notorious for bad solder joints on the shields around the tuner and microprocessor. When the solder joints on the shields crack, the microprocessor and EPROM lose their ground and the EPROM's data becomes corrupt. The solder joints on the shields will all have to be resoldered and the EPROM reprogrammed or replaced by a qualified tech familiar with the 187 series chassis.
Posted on Aug 23, 2007
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
Snowy picture
The remote doesn't effect the channels, I would say you have poor signal or interference from another device nearby.
Sep 12, 2008 | Orion1934 19" TV
No picture
have you connected up correctly, have you selected correct EXTERNAL inputs, you do NOT "tune" a Channel to see picture, you choose external AV input on set. Must connect color to color. 3 for Composite Video AV.Yellow, Video, Red & White Audio. and 5 cables for Component 3 for Video , & 2 for Audio Blue, Green, Red, Also Red & White, Audio.
AV
Mar 18, 2010 | Panasonic DMR-ES10 DVD Recorder
My TV 's picture is snowy
COULD BE TUNER OR VIDEO CIRCUIT. EITHER IS PROBABLY NOT WORTH THE COST ON THIS OLD OF A SET.
Aug 09, 2009 | Televison & Video
SONY rear projection TV - Whites have started looking "snowy"
This is your Picture tubes getting very weak.( low in emission ) You have three in there and I guarantee they are no longer available so I would start thinking about investing in a new set, but use that one until you can't stand it anymore.
May 28, 2009 | Sony KP-53XBR200 53" Rear Projection...
Snowy black & white picture
Sounds like the problem is back again
Feb 08, 2018 | Televison & Video
Plasma
First of all, I'm not an expert but you might wanna change your cables. Bad and cheap cables are usually the reason for bad and snowy picture. Good luck!
Jun 24, 2008 | Televison & Video
Picture quality and sound
than the tuning coil of circuit,like 39mhz coil or other circuite related with I.F. and detection section coil or any p.f.will be damaged if it should b currect than replace the tuner
Mar 06, 2007 | Zenith Z46Z83D 46" Rear Projection...
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
White circles appear on the image. Why is That?
When shooting with flash in a location where there are many suspended particles, such as in a dusty area or on a snowy day, the image may contain white circles as shown in the picture below. Why does this happen? If the flash fires when a suspended particle floats right in front of the lens, the reflection of the flash from the particle appears more intensely than that of the subject, as the particle is much closer to the lens than the subject. Therefore, the reflection of the flash turns out in the image and causes an effect such as that shown in the sample image above. The closer the lens and strobe are located, allowing suspended particles to be exposed to more light, the more frequently this effect can occur. How can I avoid this effect? Ideally, it is best to shoot in locations where there are very few suspended particles. If not, you can use following method to prevent this effect. a) Avoid using flash by lighting the area as much as possible. b) If your camera has a zoom function, shoot at a wide angle. c) If you can attach an external flash, use the external flash to distance the flash from the lens.
Aug 31, 2005 | Canon PowerShot Pro1 Digital Camera
GE 31GT660 TV Logo
53 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
