Question about Panasonic Palmcorder PV-GS9 Mini DV Digital Camcorder
Help! All of a sudden, I am trying to capture footage from tapes that is only a few months old, and the sound is stuttering and is full of blips. What could be causing this?? I tried another tape, and it is not as bad, but definitely a sound problem. The first tape even had problems with the screen on the left side. It was all garbled up. It was horrible! I tried another battery, but it didn't help.
  • 31 Answers
Video heads are dirty, try using a cleaning cassette, if it won't help, replace the head
Posted on Aug 22, 2007
SOURCE:
HI There I have an old camcorder the Model is a JVC GR-DVL 150E i have some very old footage on the camcorder tapes, i never ever got around to transfering the footage on to vhs video tapes! but now i...
You need to buy USB 2.0 Video Capture Adapter Card to do this action..
Pls visit the URL below as an example..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
EasyCap USB 2.0 Video Capture Adapter Card TV VHS DVD Capture high quality audio and video through your PC's USB port. Capture playback from VHS, Camcorders, TV, etc; capture audio without a sound card! Supports NTSC, PAL, Video format. NTSC: 720 x 480 @ 30 fps PAL: 720 x 576 @ 25 fps.
http://cgi.ebay.com/EasyCap-USB-2-0-Video-Capture-Adapter-Card-TV-VHS-DVD-/360339776240?pt=LH_DefaultDomain_0&hash=item53e5eca2f0
Jun 27, 2011 | Cameras
How can I transfer my 8mm tape to my computer? I need to have the film on a flash drive or dvd.
Assuming that you want to do your video work later (editing,DVD burning)in your PC.
1.Your PC must have video capture device(either built-in or add-on).
2.Properly set your video editing software to able to capture video form your device.
3.Connect your camera to your PC in regular manner,like when you connect it to your TV.
4.Have your camera in PLAYBACK mode.wind the tape to the beginning of the footage you want to capture.
5.Open your editing software.turn on capture mode.
6.Start capture.At the same time,start playing back the footage on the cam.
7.When all footage were captured,click stop capture.
8.Start your editing work.
9.when complete,save it to some uncompressed video format like *.avi for later burning to DVD or converting to other format.
For beginners,I recommend Windows Movie Maker video editing software that should come bundled in almost every computer.It's fast,simple but effective enough for home-movie work.Once your project is completed,save your movie in original .avi format for later burning to DVD,etc.
BTW forget the old-school Linear Editing (on the tape) thing.It's slow,complicate and much less flexible than Non-Linear method.
Sep 03, 2010 | Sony Handycam CCD-TR517 Camcorder
How can i edit the video if i finish filming
Assuming that you want to do your video editing in the PC rather than on the tape.
Aug 07, 2010 | Sony Handycam CCDTRV118 Camcorder
HD footage stutters after captured in Final Cut Express HD 3.5.1
Did you capture as HDV? When you render is it ok? Some times it is best to capture as DV not HDV the quality will be as good (letter boxed) but it means fce is not having to decode the mpg4 compression of HDV in realtime. Can lead to a jolting due to extram RAM usage.
Mar 04, 2009 | Apple Final Cut Express HD for Mac
Heavy pixalated playback .. VX2100
Try to clean your heads with a video heads cleaning cassettefor ten seconds and try to read your tape.
If it doen't help, your footage is corrupt.
Dec 16, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Mini DV tapes getting distorted on playback
It sounds to me that the damage was created prior to you attempting to capture the video.
There are several ways to help prevent these issues.As a rule I would suggest only to use miniDV cassettes to record only once, as they are prone to errors such as you describe.  Also, keep the tape heads clean and inline. tape heads have a limited mileage and need to be replaced after a while.
We all become victim to the mosaic problems you describe, and it can be repaired on the computer, although it is a painstaking manual process.
If you have footage that is damaged in this way and you really feel you need it repaired, please contact me, I will be happy to offer my services.
Dec 11, 2008 | Samsung SC-D67 Mini DV Digital Camcorder
Tape will not eject / Battery full
while the eject process is trying to happen remove the battery and replace it. keep initiating the eject process and removing the battery and it should finally eject. If you attempt to use the camera again put in a new tape so you don't lose a tape that contains footage you may want to save.
Dec 07, 2008 | Canon ZR100 Mini DV Digital Camcorder
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
JVC GR D250U
This camcorder should not require a driver in order to capture the footage. Start up your capture software, power-up the camera in VCR mode and then connect the Firewire cable. It should then allow you to playback the tape and capture the contents.
Here is the manual online:
http://resources.jvc.com/Resources/00/00/94/LYT1353-001A.pdf
If you need a simple program to capture the footage look to: http://www.virtualdub.org/
Your video-editing software (including Windows Movie Maker) should also capture the footage.
Nov 17, 2007 | JVC Everio GZ-MG21 Camcorder
Putting video footage on my computer
To get your footage into the computer from DV tape you need a four pin firewire (IEEE1493 or iLink) cable from the camera to a six pin cable into the computer. USB will not do a proper job, it's for downloding photos or as you already mentioned, Web caming.
Sep 15, 2005 | Panasonic NV-GS50 Mini DV Digital...
Panasonic Palmcorder PV-GS9 Mini DV Digital Camcorder Logo
62 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
