Question about Panasonic Lumix DMC-LC43 Digital Camera
Lens stuck I have a panasonic DMC-LC43 camera and the lens is stuck out. When I turn on the camera I hear a clicking like it is trying to fix but then I get a system error message. Any idea?
  • 641 Answers
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Posted on Sep 03, 2007
Lumix dmc-fx150 lens stuck
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
Mar 15, 2011 | Panasonic Lumix DMC-FX150 Digital Camera
The lens of my DMC-FS20 is not moving correctly (it comes out when switched off and in when switched on) and I am unable to press shutter. A message is displayed telling me to switch off and on again, but...
Good day,
Regards
15073327
Jan 25, 2011 | Panasonic Lumix DMC-FZ7 Digital Camera
Stuck Lens
It seems that the lens is stuck.
If you can repair it i have the repair manual, if not i can repair this problem, I'm not shure if i allowed to send our repairadress in the Netherlands we replaced a few gears or repair the damage into the lensunit.
Mar 27, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Lense stuck out and can't take pictures
In all probabilities, the lens barrel must have tilted, preventing the lens from retracting into the barrel. It could also be possible that some dust particles got stuck in between the segments of the lens barrel. Check for these. Try to straighten the barrel without using much force, and try to remove any dust particle that got stuck between the segments.
Jan 14, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Trying to fix a damaged lens unit
lens parts can be purchased seperatly, so check witch parts need replacing and get a lens assembly diagram.
May 28, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Camera that keeps shutting off
Hey layneD,
What is most likely going on is that something stuck in the lens obstructing its movement (i.e. a piece of sand), or the lens has moved out of alignment. You could try removing the batteries and waiting a minute and then reinserting them. Another option you could try is putting the camera on a flat surface with the lens pointed upwards, and then hold the shutter button down and while doing this turn the camera on. One more thing you could try is blowing compressed air into the lens to try to dislodge anything that might be stuck in the lens. If none of these options work I would have it looked at by an authorized service technician such as bringing it to a Geek Squad® precinct at a Best Buy™ store and they can send it out for service. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 26, 2008 | Panasonic DMC-FX07 Digital Camera
Fix a lens on my dmc-fx9
It sounds like you have a gear problem in your lens. If you need some good used parts for your FX9 you may want to contact a guy in South Carolina who has lots of parts for all the Panasonic Cameras at reasonable prices. I think his email is gerald.ray@aa-ark.com
Nov 07, 2007 | Panasonic Lumix DMC-FX9 Digital Camera
System error
hi the problem that causing this is: there is some pressure to the lens did it fell? probebly there is a fault in the lens sorry cant help good luck
Mar 20, 2006 | Panasonic Lumix DMC-LC43 Digital Camera
Panasonic Lumix DMC-LC43 Digital Camera Logo
1,001 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
