Question about Ovens
What does the error code F1 indicate, on a Wolf Oven?
My oven keeps beeping and giving me an F1 error code. This, first, happened, after self-cleaning, a year or so ago. Now, it occurs, for no reason, when I preheat my oven, when I'm in the middle of cooking, and just about any time it feels like it,. Help, please!!
  • 3 more comments
  • rubinof Mar 25, 2009
    My oven is a Wolf Model # SO30U/S Serial # 11198515-2 This oven keeps giving me an F1 error code. Then, the oven refuses to work, and keeps beeping. HELP!!!!! Thank you!
    Wolf Model # SO30U/S Serial #11198515-2
  • Sean and Lil Apr 06, 2009
    This happened to us for the first time tonight. We hit the off button three times before it stopped coming up. We had finished a convection roast cooking about 1 hour previous to the error code F1 appearing with the beep on both the oven used and the non-used oven.
  • Michael Masters
    Michael Masters May 11, 2010
    Hi, if possible, i will need the complete model number and brand name of this oven so that i may assist you further. Thanks
  • Stephy Kosger
    Stephy Kosger Apr 22, 2014
    I got The same error code after Cleaning And while The oven was preheating. Unfortunately I turned the oven off before reading this and now cannot turn it back on. The sequence given here did not work for me. Help?
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Posted on May 22, 2009
  • Wendy Thoren
    Wendy Thoren Oct 21, 2016
    Thank you! Worked like a charm
All - Thank you for the post to the resolution to this problem. We have a Wolf oven and the same thing happens, and it seems it happens every time after we self clean the oven. This resolution worked, but took us a couple tries with the solution, and then realized there is a small clarification to this that might help. In order to clear the error, you must press and hold the Cook Time and Stop Time buttons, and hold both for 5 seconds until the console beeps again. This clears the error, then press Off. Then restart the oven, and it should work ! Thanks again for the tip, this saved us another bill we can easily do without.
Here is the full Sequence Reiterated:
Press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds (be sure its the Temp Button for the oven having the issue). The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode AND HOLD for 5 SECONDs to clear the error register, then press "Off". Now your oven should work properly.
Posted on Oct 29, 2009
  • lblanch40
    lblanch40 Dec 23, 2012
    That didn't wok for me.
  • martyn taubert Mar 01, 2013
    that worked for me THANKS !
F1 Is latch error!
Posted on Nov 01, 2012
  • 163 Answers
F1 is the control board and touchpad.
Posted on Mar 24, 2009
Fisher double oven OD302. Periodically it will start beeping, shut off with no default code
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Jan 09, 2017 | Fisher Ovens
How do I fix my oven door keeps locking up and F1 comes up and starts beeping
Here is a detailed description of this error code. Your control can be rebuilt by fixyourboard.com. See article here on Kenmore/GE F1 Error Code: Oven Failure After Self Clean and F1 Errors
Aug 27, 2015 | Ovens
Turned oven to bake it keeps beeping with message "door"
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
Apr 21, 2014 | Whirlpool Ovens
F3e2 error
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html How to Get GE Oven to Stop Beeping eHow
Jan 03, 2014 | Whirlpool Ovens
Our frigidaire stove or the oven is locked and it just keeps making this beep noise and the oven wont unlock so we really need help unlocking the oven and stoping the been noise thanks
The "F1" error code indicates a failure of the Electronic Oven Control or EOC circuit board. You may find the oven gets too hot, fails to respond to input or acts irregularly when the EOC is malfunctioning or broken. While this code usually indicates a need for repairs.
Read more: How to Troubleshoot a Frigidaire Oven F1 Code ' eHow.com http://www.ehow.com/how_10004808_troubleshoot-frigidaire-oven-f1-code.html#ixzz2EhW21T4n
Dec 11, 2012 | Ovens
F1 code GE profile convection self clean wall oven (95?) oven beeps F1 code oven works when it is on bake etc. when touch key are pressed it goes off but starts to beep again
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Sep 19, 2011 | Ovens
Oven is giving a F1 code and is not working . It beeps even when it is not given a program.
Hi.
The error meaning depends on the oven brand.
On Amana and other brands F1 is a faulty control pad or faulty electronic control.
That may be your case , since the electronic control looks being jammed.
Try tripping the circuit breaker for two minutes (or disconnect power cord). If that does not help, then call the manufacturer at the number listed on the owners manual.
Note: on other brands F1 indicates incorrect temperature , and is associated with a faulty temperature sensor. This normally does not cause the electronic control beeping and not responding.
Regards.
Mar 02, 2010 | Ovens
Wolf Double Oven
Mar 26, 2009 | Wolf Range WKGD-2 Gas Double Oven
F1 Error Code
According to the GE website, F1 usually means a problem with the keypad. You might try my solution for the F7 problem which is similar in nature. Go to the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my solution with more than 1900 folks and most report success.
Please let me know if it works for you at:
hutchipop@yahoo.com
Good Luck,
Powerman
Jul 16, 2008 | Ovens
Ovens Logo
7,032 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
