My drier stopped working today,but could not find any instructions for it in our rented house, so I cleaned everything in sight including the condenser filter, which I washed in the shower. Seemed to do the job for a few minutes, but when I returned after a 40 min cycle the clothes were not much drier and there didn't seem to be any more water in the tank. Reset the start button and then it refused to go at all. Watched a you-tube video about how to do it. Went back and wiped all the seals but still no dice. Has the condenser gone? Is there another place to clean? There does seem to be another panel to the right of the condenser filter. Does this open?
SOURCE: Hotpoint Condenser Dryer Model CDT00
Either your heater is blow or your thermal cut outs are blown easy to check and replace ...
The are located at the back of the dryer behind the protuding funny shaped panel...
Check the continuity on the t-stats if no present then replace both of them small round things
then its the heater....
SOURCE: Kenmore Elite Elec Dryer Model # 110 62032100
Kenmore Ellite Dryer - Model 110.73952102 Type DDOT - NAT 1206006 - EH22
The Heat does not turn on! It spins and spins but no Heat? Any suggestions and how to fix intructions would be greatly appreciated. Thank you!
SOURCE: Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
