Question about GE JGRP17 Gas Single Oven
Oven turns off F3 flashes
The oven turns itself off and flashes F3. The turn off is random
  • Bob L Aug 22, 2007
    This is a gas oven
  • tom m Oct 29, 2008
    yes
Not sure why it is so expensive for you folks but I live in Edmonton and got the part for 44.50 plus tax at Reliable Parts
Posted on Dec 31, 2007
I replaced the sensor.  Got the part from GE direct for about $59.00.  As you indicated it was ot a hard install.  However the oven still comes up with the F3 error.  Thanks for trying.
Posted on Oct 12, 2007
    President:
  • 331 Answers
Bob, an F3 error code denotes a failed oven temp sensor. See below.
F3 Open oven temperature sensor circuit Replace oven temperature sensor
The repair is pretty straight forward, but you should have the replacement part in hand before you begin. The part number is WB21X5301 and retails for about $95.00. I just found one online for $72.60!
The sensor is located inside the oven cavity mounted to the top of the rear wall. Remove the 2 screws and slide it out of there. The sensor has a plastic connector connecting it to the main harness behind the oven. Pull this carefully through the hole. If you can't get the plastic connector through, then you'll have to pull the oven and do this from the back... alot more work but still do-able. Simply disconnect the old sensor from the plastic connector and install the new one. Then feed the wires back into the oven and re-mount the new sensor.
If you don't have to pull the oven, the job should take about 20 minutes and all you need is a 1/4" nut-driver or socket.
If you have to pull the oven, re-post and let me know... I'll walk you through it.
There ya go!
Posted on Oct 11, 2007
  • Tracy Farrell
    Tracy Farrell Oct 13, 2007
    Bob, according to GE, the F3 error code indicates a failed sensor. Since it's been replaced and you are still getting the error code, there are 2 things left to do.
    DISCONNECT POWER TO THE UNIT! SHUT IT OFF AT THE BREAKER IF YOU HAVE TO!!
    1.) Pull the oven out and remove the rear panel and front control panel. Check all wiring connecting the sensor to the ERC (microcomputer). Look for any loose connections/breaks/tears/crimps in the wiring (if one of the sensor wires is shorted to ground or broken, the ERC will generate an F3 code. It's rare but it happens). Check continuity with an Ohm meter if you have one.
    If all of this checks out OK...
    2.) You have a failed ERC. I'll need the complete model number and Serial number to get the part number for you
SOURCE:
Oven will say F3 and shut down what does F3 mean no book?
Kenmore' F2 or F3 usually points to an open oven temperature sensor. If that is the problem, it's not an expensive repair.
Mar 02, 2014 | Kenmore Ovens
F3 error code
Bad oven temp sensor. If you know how to do so you can disconnect the power and remove the temp sensor. The two white wires to the sensor, ohm it. it must read ~1080 ohms. If not really close to that at room temp then replace sensor.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | GE Profile JT955 Electric Double Oven
Oven was on and all of a sudden I saw flashes of light coming from oven? turned off oven and now oven randomly turns itself on
Does not sound good,
does it give you a error code at all?
the flashes of light sound like a heating element problem, and as far as it turning on itself thats a control issue, I would leave it unplugged for safety reasons.
I am trying to see if I can find some information online about this particular oven.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | GE Profile JTP18 Electric Single Oven
Display on kenmore electric double oven flashes F3 soon after setting temperature and oven turns off
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%%
Jul 19, 2010 | Kenmore 41389 Electric Double Oven
F3 and flashing on Kenmore oven
HI. this is a basic temp sensor issue. the oven control is programmed to cease operations if it dose not receive any resistance signals for the temp sensor during high heat situations.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Sep 18, 2009 | Kenmore Ovens
Kenmore double oven flashing "door locked"
Jul 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F3 blinks on panel
Replace the oven temperatire sensor.
May 12, 2009 | Kenmore Ovens
What does F3 mean from my Kenmore Oven??
f3 is a bad sensor part number WP8053344 this reads the temp. in the oven just like on older ovens had a thermostat.if you look into the oven you'll see it go here and look at picture
https://www.repairclinic.com/PartDetail/Temperature-Sensor/WP8053344/722235
go here to see error codes
http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.html
Nov 13, 2017 | Kenmore Ovens
I have a majic chef oven, when i turn it on it beeps and flashes
Self clean on some older models can cause some issues. F-3 is a sensor error. This could have been damaged by high heat or in some cases if the sensor is ok, the control doesn't know it's there.
Mar 14, 2009 | Magic Chef 9815 Electric Single Oven
GE JGRP17 Gas Single Oven Logo
364 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a GE Oven Expert? Answer questions, earn points and help others
