Its because just this morning i always got blurred shots, the cam didn't focus into the subject, then i tried different settings. Auto and Manual focus, I accidentally rotated that smaller lense, then there it is. Will it have a further damaged into my cam? Please reply!! Is this normal? I just experienced it now.
Hello,first off,please do read through the manual that came with the camera,and at first have it close by as you go through the basic's of turning on the camera to all the way to the medium-to-advanced level guidance from the manufacturer.what you do need to do is,simply leave any control's(buttons/switches etc)well alone,until you are quite conversant with their purpose.it may well sound obvious to the casual browser who happens to read through my notes,but they are important.with the focusing ring,it may well be ok,and not suffered any undue damage.when you have gained a little expertise with the various controls,aim your camera at a distant object,and focus there with the auto focus feature,keeping your finger on the button,have a look at the barrel,to see what distance scale it has rotated to,and see if it is approximately correct,or simply measure from that point with a builders tape measure.hope that helps, cheers.
SOURCE: Nikon DX AF- S Nikkor 18-55 mm lens won't Auto focus
Is the switch on the side of the lens set to manual or auto? Sometimes it's the little things like this that we don't notice.
SOURCE: Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED AF-S DX
Seems as if you're snapping the shutter before the lens has focused. Have you tried manual focus or single-server auto focus?
SOURCE: Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
SOURCE: My Nikkor AF-S DX VR 18-200 stopped focusing
the lens internally has a electrical circuit ribbon that contracts when you adjust the lens everytime. They are prone to get crease causing a short in the auto mode.b It can be checked and replaced bt most camera technicians
