Question about Visonik V900XD Car Audio Amplifier
Power and led on but yet no sound
My amp turns on and the led turns on as well as the fan when it is grounded. but on the side where you connect the rca cables there is 2 more leds. one says power and it is green and the other is red. the red one is the one lit. there is no sound coming out of the system. the battery is supplying about 13.8 constant volts and im running with 4 guage power and ground. any help is appreciated.
  • rub3414 Aug 22, 2007
    took out the box the subs are correct. the connection from the sub to the amp is correct. i disconnected the power completely and removed all fuses for about 2 hrs. connected everything together and still went into protect. it doesnt even start on green led power. it starts automatically on protect.
  • rub3414 Aug 23, 2007
    disconnected every wire and he fuse. plugged in the power ground and remote wire. put in fuse. turned on car and saw the power led light up but then faded out and the prot led lit up instead. the speaker cables and the rca were disconnected. what can it be is the amp fried, but why would it go into power mode if its fried?
  • 113 Answers
Red means protect, check speakers first then disconnect all power,try again in 20 min
Posted on Aug 22, 2007
  • oscar herrera Aug 22, 2007
    lets try something again,disconnect power cables,short between terminals G&P G&R (amp)may see a little spark but ok then try reconnecting again but without rca or speakers.If amp still goes in prot you may have some blown fets or output semiconductors.
    note:most amp starts in prot then green ok
I have a Directed d2400, it turns on and sounds great but when I shut off my car the amps esp light stays on and the top blue leds also stay on. For some reason when I connected my ground wire it sparked a...
So it is receiving power but not turning off? Sounds like the sense cable is not connected correctly. Amps have a sense cable that determine whether or not the head unit is powered on. They use this sense to power on or power off. If the sense cable is connected correctly and is getting the correct voltage, then the relay may be broken.
May 14, 2014 | Car Audio & Video
My Friend put A Rockford Fosgate P250.2 Amp in his car and while hooking it up he forgot to connect the ground but still got power to the amp but no sound from the subs and the thermal light is on. so he...
Your friend has damaged his amp. The power light coming on means that the amp's power indicator LED is at least working. That light is only there to tell you that the amp is receiving power on it's 12 volt rails, not that it's necessarily using the power in any way other than warming up the amp's internal circuitry. When you say the amp gets power, I'm not clear on whether you mean the amp works in that fashion, or there's just a red LED glowing but nothing else happens. The amp needs to be repaired, and I would suggest to him to not apply power to it again until it is checked by a professional. The power supply has probably been damaged, and it's possible, depending on how the amp was mounted, that it was searching for ground through the amp's chassis if it was screwed into metal at its mounting location. All that seems certain as of now is that the LED works, but nothing else, unfortunately.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Jul 02, 2017 | Rockford Fosgate P3001 Car Audio Amplifier
Is the brutus amp blue led light suppose to stay on when the car is off?
No. The LED should be off when the radio is off (amp turns off as well)
It sounds like you have constant 12volts applied to your remote turn on lead. The amplifier will have 3 connections for power:
1. 12volt constant
2. chassis ground
3. 12volt switched power - this wire should come directly from your head unit. It only sends 12 volts when the radio is on allowing to amp to power up only when the radio is on.
Dec 22, 2010 | Hifonics Brutus BXi 1206D Car Audio...
No sound
What brand of reciever are you using. Most pioneers have a floating signal ground and the shield of the input at the amp needs to be connected to chassi ground. Also if you had a previous amp failure and the power ground in your old amp opened the current to power the amp will flow through the signal ground of the reciever and burn the copper trace on the circuit board in the reciever. test this by connecting signal cable shield to car reciever chassi.
Aug 29, 2009 | Kenwood KAC-8401 Car Audio Amplifier
Amp wont turn on
New amp sounds messed up... grounds are bad and sometimes the amp tries to draw power but cant... So it immediately goes to protect... All jacked up... Audio specialist could help... Repair shop if local ..
Nov 04, 2008 | Kenwood KAC-9102D Car Audio Amplifier
My amp has power the led is on but no sound
See what happens if you apply a temporary ground connection to the RCA input jacks ground connection while it is running. You might want to turn the volume down before you do this just in case it works.
Jun 25, 2007 | Performance Teknique ICBM-894 Car Audio...
Problems with Infinity Amp 611A
are you running a large ground wire directly to the battery negative terminal?
Jun 03, 2007 | Infinity Reference 611a Car Audio...
No Sound coming out of amp to subwoofer
check the fuse box and make sure there is no loose connection there. also check the wire that feeds power to that amp. good luck
May 23, 2007 | AudioBahn DUB Mag Audio DUB1002 Car Audio...
Amp isn't putting out any sound
I have a Digital Audio model-DA2200W, Was listening to my tunes loud as always....then the subs quit bumpin...checked the subs cuz i thought i blew em...theyre fine...The power on the amp is still on...green light and all..just no output..I opened it up to see if anything looked burnt looks fine...is it toast or can i fix it??
May 25, 2006 | Power Acoustik LT-980/2 Car Audio...
Visonik V900XD Car Audio Amplifier Logo
144 people viewed this question
Top Visonik Car Audio & Video Experts
Dalynn Turner
Mike Duncan
Mike Duncan
Joe Alexander
Joe Alexander
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
