I have sent a scan consisting of 22 pages to my User Box. There is a mixture of A4 and A3 sheets.
I go into my User Box, but the scan isn't there. I have done this before and they showed up just fine.
I am connected to the copier network and can print.
I'm not sure what the problem is.
Any help is appreciated, thanks.
Do you have Microsoft Office?? If you do try this:
First, gather the paper you want to scan. If your scanner has anADF, you can load a stack of pages at a time. The first time you scan,Document Imaging detects the ADF for you.For more information about the ADF and whether your scanner has one,see the documentation that came with your scanner. You will also want to sort your paper; if you have color pages thatyou want scanned in color, sort these in a separate stack from theblack and white pages. Load your first page, or first stack of pages(with an ADF) in your scanner. Then, start Microsoft Office Document Scanning (the scanning component of the Microsoft Office Document Imaging program.)
On the Windows Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Scanning.
Tip If Microsoft Office Document Imaging is already running, you can start the scanning component by clicking Scan New Document on the File menu.
Set up your scanning optionsIn the Scan New Document dialog box, do one or more of the following:
To view your scanned file(s) in Document Imaging after they have been scanned (recommended), select the View file after scanning check box.
If your scanner is equipped with an ADF, click Scanner, and then select the Use automatic document feeder check box.
If your scanner is equipped with an ADF and you have double-sided originals, select the Original is double sidedcheck box to scan both the front and back of multiple pages. Place thepages in the feeder so that the page fronts are scanned first.The Microsoft Office Document Scanningdialog box will appear after each scan, allowing you to turn the pagesover and scan the page backs. Document Imaging automatically collatesthe pages in the correct order after scanning is complete.
If you have a true duplex ADF (one that automatically scans both sides of the page), do not select the Original is double sided check box. Instead, in the Scan New Document dialog box, click Scanner, and then select the Show scanner driver dialog before scanning check box. When your scanner driver dialog box appears during scanning, select the proper duplex settings.
If you want to scan pages manually, select the Prompt for additional pages check box. Office Document Imaging will pause after each page is scanned, allowing you to place the next page in your scanner.
By default, optical character recognition (OCR) is performed onyour document during the scanning process. Although performing OCR addstime to the scanning process, it also has the following benefits:
When you open the scanned document in Microsoft Office DocumentImaging, you can search for recognized text in the document, copyrecognized text in the document to another document or program, andsend recognized text in the document to Microsoft Word, withoutperforming OCR manually.
You can have your scanned files saved with an automatic filename based on the first words on the page (this is the default.)
To turn off OCR during the scanning process (you can perform OCRmanually in the document in Document Imaging after scanning), do thefollowing:
In the Scan New Document dialog box, select the preset you want to use, such as Black and white.
Click Preset options, and then click either Create new preset (and then type a name for the preset), or click Edit selected preset.
On the Processing tab in the Preset Options dialog box, clear the Use OCR to recognize the text of the scanned image check box.
Select location, name, or file type for the scanned filesPart of the scanning process is to save a scanned page to a file. Bydefault, when you scan multiple pages, the pages are saved in one file.If you want to save each scanned page as a separate file, select thenaming convention for the scanned files, or change the location or fileformat of the scanned files, do any of the following:
Do one or more of the following:
To save each scanned page as a separate file, select the Save each page as a separate document check box on the Page tab.
To change the location for the saved files, click the Change button on the Output tab, and select a location.
To select the way the individual files will be automatically named, click one of the File Name options on the Output tab. (If you have turned off OCR during scanning, you will be unable to use the Auto name based on first words on page option.)
To select the file format the scanned pages will be saved in, click the Advanced button on the General tab, and select the options you want.
Click OK.
Scan your pages
In the Scan New Document dialog box, make sure the preset you want to use is selected, and then click Scan. If you selected the Original is double sided check box or the Prompt for additional pages check box, the Microsoft Office Document Scanningdialog box appears periodically to let you know that the scanner hasfinished. You then have the option to continue scanning (place anotherpage in a scanner that doesn't have an ADF) or turn your page or pagesover to scan the other side. Arrange your page or pages as desired, andselect the option you want to continue scanning.
When all pages, all sides have been scanned, click Done in the Microsoft Office Document Scanning dialog box.
To scan additional pages, review the Get started section above, and then repeat the instructions in this section (Scan your pages.)
Organize pages in the saved file(s)Now that you've finished scanning, it's time to take a look at theresults. If your scanned pages are not open in Document Imaging, do thefollowing:
On the Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Imaging to start Document Imaging.
In Document Imaging, click Open on the File menu.
Locate the file you want to open (by default, the scanned page(s)is saved to the My Documents folder with an auto filename based on thefirst words on the page, such as Page1of.tif) and then click Open.
Repeat steps 2-3 until all of the files you need are open.
You now have an online version of your stack of paper. Here are a few tips to get you started organizing pages.
Copy a page to a new document In the thumbnail pane, select the page you want to copy. On the Page menu, click Copy Page. Switch to the Document Imaging document into which you want to insert the copied page. In the thumbnail pane, select the page that precedes the location where you want to paste the copied page. On the Page menu, click Paste Page.
Delete a page In the page pane or the thumbnail pane, click the page you want to delete. On the Page menu, click Delete Page.
For more information about scanning or organizing pages, see Microsoft Office Document Imaging Help. The papers that were once cluttering your desk have now beentransformed into electronic documents. Within these documents, you canarrange pages, move pages to different documents, delete pages, printpages, add annotations, copy text to other Office programs, or send apage to someone in email. And still have room on your desk for yourcoffee.
check the server settings, maybe user authentication is needed, check from server side, what the printer is trying to do and where it fails. check printer e-mail settings, try these setting in computer.
The printer will support the following media sizes:
Roll paper (width) - ISO: A3, A2, A1, A0, JIS: B2, B1, ARCH: 24", 36" Others: 10", 14", 16", 17"
Cut
sheet - ISO: A4, A3, A3+, A2, A1, A0, B4, B3, B2, B1, DIN: C4, C3, C2,
C1, C0, JIS: B4, B3, B2, B1, ANSI: 8.5 x 11", 8.5 x 14", 11 x 17", 13 x
19", 17 x 22", 22 x 34", 28 x 40", 34 x 44", ARCH: 9 x 12", 12 x 18", 18
x 24", 24 x 36", 26 x 38", 27 x 39", 30 x 42", 36 x 48", Photo: 20 x
24", 18 x 22", 14 x 17", 12 x 16", 10 x 12", 10 x 15", 8 x 10", 16 x 20"
(US Photo size), Poster: 20 x 30", 30 x 40"
IF you are using CapturePerfect 3. version, you can select "Auto detection" for page size, and under 'more' select 'image size' instead of guide plate. Also you may have to select option '1' under user code U10 in case you want to scan pages over 17 inches long. (Press Newfile and Countonly simultaneously, press 'newfile' till you get U10, press 'countonly' and select 1. This will enable scanning upto 1 meter long).
CP3 has "Skip Blank page option", this helps you to automatically delete blank pages on the back side and scan only those with data.
S. Mohan, Chennai, India
I think because A4 ist a default size, maybe you most set the printer to print or copie in A3 every time. Normally it most work every time, but try it out.
Hi
Your printer is not made for A3 it only for A4 so how are you getting a larger size than an A4 I not understand?
But if you need to print different sizes you need to get an Art or a paint program on your PC that what do, I use Paint Shop Pro to do my scanning on and I can print any size from 1 inch up to an A4.
If you ever think of getting art program of such then makes sure it has tools on it to scan then you can do all sort sizes.
Anyway I have put a PDF manual for your printer on my website for you to look at or download Hope it will be some help for you.
Have you set up the page as A3? If so, should be ok if you set the printer paper size to A3. If you set up the page on A4 you will need to tell the the printer to 'scale to A3' and it's best to say you want to preview before printing
Hello, you can print a calibration sheet from the front panel of the printer. Hit menu on the panel of the printer and scroll down to calibration printer and hit ok. Then hit ok on print calibration page and it should proceed to print a calibration page. After it is done printing, it will tell you to scan the calibration sheet.
