Question about KitchenAid KHTU165RSS Stainless Steel Kitchen Hood
Kitchenaid vented hood model KIRD801xss
Retractable(pop up)downdraft vent system just stoped working. Pushed the start button, but no sound or movement. Did not take out filter (that according to the manual can lock the system. It just doesn't pop up. The circuit breaker did not tip off, nor the receptacle -where the cord is pluged into- went bad (a lamp plugged into the same receptacle is working). There is no loose wire within. What to do? Thanks for any advice.
  • potter168 Mar 11, 2008
    I have the same problem. My Model is KWCU380JSS1. One of the motors was broken. I replace with a new one. All connections are correct. But both motors don't run at all, while the lights work fine.
SOURCE:
  • 288 Answers
SOURCE: Kitchenaid downdraft retractable vent
check for power going into the switch. (you need a meter) If the switch is set to "on" there should be power going in and out. Find a good ground or use the white wire to test. If there is, just follow the path of electricity. If you do not have a meter this is next to impossible to do.
Posted on Mar 06, 2008
Treefrog15
  • 130 Answers
SOURCE: Kitchenaid KDRP463LSS - No electricity to oven
Pull the range, remove the back cover and locate the thermal switch and the oven TOD. Check both parts for continuity. Replace any of them if it's open.
The thermal switch
partimage.aspx?imgid=z3bqljffahrfnza4nzu3os9mufcvc290b2hwdhjhcc8%3d
The oven TOD
partimage.aspx?imgid=z3bqljffahrfmja4mdazoc9mufcvc290b2hwdhjhcc8%3d
- The part number for the thermal switch is AP3799085
- The part number for the oven TOD is AP3086326
Posted on Dec 23, 2008
SOURCE: Range element does not work
Model KERC500Y Standing in front of stove the Left front
burner won't heat.
Posted on Mar 24, 2009
SOURCE: KitchenAid electric range KERS807SSS02 -in the
We have a Kitcheaid gas stove and have had 3 new thermostats installed. After the 3 time it finally did it's first full cleaning cycle.
So three service calls later, (first was after the warranty) and three thermosats and over $500 and the stove has done it's first full cleaning.
Lots of examples of this same problem but it seems no recall on the stoves.
Posted on Jan 12, 2010
SOURCE: Kitchen Aid downdraft hood stuck in retracted position
The filters need to be seated properly to complete an electrical safety circuit. This keeps the unit from operating without the filters. The best way I have found to fix them when they get dislodged in the closed position is by using two spatulas. The first is used to move the filter forward a bit and the second is used to keep it pushed tightly forward to complete the circuit.
Posted on Nov 25, 2010
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
Kenmore retractable vent keeps randonly going up and down , sometimes for 6-7 times before it will stop.How do we fix it?
I hope you have the $400 appliance insurance. I had the same problem in a new house purchase. First the downdraft wouldnt work, and then wouldnt stop.
It was a micro switch and motherboard issue. Took four visits by the (insurance paid for) techie to get and fit the right part. Good luck
Mar 08, 2014 | Kenmore 36" Telescopic Downdraft Range...
Which is the best pop up down draft vent system? Do you have any reviews?
I wish I could offer some help but I am trying to solve the same question. There are almost NO reviews out there on the internet for any downdraft vents. There are also NO noise ratings on the fans (though ceiling fans all have ratings). It would seem that the taller the vent, the better positioned it is to draw off cooking fumes but other than that and the power of the motor (and perhaps ease of cleaning), I've no idea how to select a unit. HELP!
Aug 28, 2010 | KitchenAid KHTU165RSS Stainless Steel...
Retractable vent stuck
after struggling for hours to remove vent for cleaning, I just happen to pull frong panel forward, and that release the vent so that i could clean it. No big deal. Simple
May 29, 2010 | KitchenAid KIRD861HSS Kitchen Hood
Apr 03, 2010 | KitchenAid KIRD861HSS Kitchen Hood
My viking downdraft vent isn't working. I didn't
The halogen light have all gone out (3) is there a fuse and is it hard to find or replace
Dec 20, 2009 | Viking Kitchen Ranges
Downdraft vent won't stay down. Push the button and it retracts normally, then pops right back up?
check your bottom limit switch - i'm guessing its bad. the unit doesn't stop operating til it trips a (working) limit switch, if the switch is bad it'll cyle right past it and go back up until it hits the top limit switch (again).
Aug 27, 2009 | KitchenAid KIRD861HSS Kitchen Hood
My 7 1/2 year old Thermador CVS36RB Cook 'n' Vent won't retract
sears labor is 137 plus parts. that is something that would need to be looked at. it could be a few different things. if he is handy he can open it up to see if anything is misaligned or broken. the vent may even just be a little crooked and once straight may go up and down like normal
Nov 22, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Your drive motor arm is not making contact with either of the two limit switches at 6 and 12 positions. Your arm may be loose, gear stripped, broken bracket. Turn off the power at the breaker panel and remove the vent pipe cover box (4 nuts) see what is going on inside. Tellstar
Mar 01, 2008 | KitchenAid KHTU165RSS Stainless Steel...
Kitchen Ranges Logo
224 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
