Question about HP Office Equipment & Supplies
The printer will say out of paper..it is not..it appears
The bottom rollers are not feeding the paper thru. thanks it is a hp photosmart 8050..3 yrs old
  • annieo18a Mar 24, 2009
    it is not grabbing the paper
  • Juanita Vega
    Juanita Vega May 11, 2010
    have you checked to see if it is even grabbing the paper?
  • HP Master
  • 685 Answers
Sounds like it needs to be tightened
Posted on Mar 24, 2009
SOURCE:
I have an HP 8050 and it says out of paper and it is not out of paper
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer......
Good Luck!!!!!
Sep 23, 2011 | HP Photosmart 8050 InkJet Printer
My hp c5280 is not printing all the text lines in my documents...some are getting squooshed or are not appearing at all...anything I can do? (It's almost as if some lines of text are getting...
Its sounds like possibly the paper feed rollers are warn and the paper maynot be feeding though smoothly which could cause problems like your experiancing.
Thanks
May 05, 2011 | HP Photosmart C5280 Printer
It will not pull paper on its own - I always have to press ok becasue it does not detect the paper - that happens for every sheet. Sometimes it will pull the paper a little then say there is a paper jam. i...
This is a problem that can be many things. To eliminate springs and or roller problems. Put rubbing alcohol on the center feed roller. It is usually black and made of rubber. It is located above the paper being pulled. If it grabs the paper after that it is worn out or very dirty.It should pull the paper after you get it clean.
Aug 30, 2009 | HP Photosmart 8050 InkJet Printer
Calibration error how do I fiw it or reset it on
Try to check inside the printer. the sensor maybe blocked by small paper thats why paper jam error appear.
Aug 13, 2009 | HP Photosmart 8050 InkJet Printer
Paper in tray, but printer said, "Out Of Paper" Photosmart 8050.
This site ******* sucks. The whole ******* thing is just ads. ******** ********!
Aug 06, 2009 | HP Photosmart 8050 InkJet Printer
With HP Photosmart D7260 Printer, I get "out of paper" error, paper tray full, feed rollers leave skid marks on paper" I have tried other paper (HP Premium Ink Jet paper, Avery namecard stock, HP Premium...
Perhaps you are loading too much paper into the tray. Please try to work through the steps in this troubleshooter and see if it has any effect. If not, please report back with the results and someone will be happy to assist you.
HP OOPaper
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 02, 2009 | HP Photosmart D7260 Printer
Hewlett packerd 3310 won't paper feed. You can feed one paper at a time and use the end of a number a small pish stick to help feed it thru the paper tray!
Most likely either the pickup roller or the feed roller is worn, damaged, or excessively dirty.
You need to purchase a "paper feed cleaning kit" either from your regular HP store or from an HP online retailer. Then go here to get the step-by-step procedure. Instructions vary according to your operating system.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=29302&lc=en&dlc=en&cc=us&lang=en&product=439491
If this does not correct your feed problem, you need an HP certified technician to disassemble the printer and physically examine the parts. They may require replacement.
Mar 25, 2009 | HP Photosmart 3310 All-In-One InkJet...
Can't Print
HP Paper Feed Cleaning Kit - Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00754199&lc=en&cc=us&dlc=en&product=439488&rule=584&lang=en
ou may not have the paper width set snug to the paper to feed correctly.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00553862&lc=en&cc=us&dlc=en&product=439488&rule=584&lang=en
Consult http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00601439&cc=us&lc=en&dlc=en&product=439488 regarding "out of paper" errors Paper cleaning kit is included in this article.
Apr 19, 2008 | HP Photosmart 3210 Printer
HP Photosmart 8050 printer won't load paper.
hello SuperVicky, rollers on the printer do not go that often on the other hand the usage of the printer is a factor ie how much printing you do or age if old. Normally paper roller should allow you print quite a few thousands before wearing out. what i will advise is to look keenly in the printer shuold in case you have any particules in the paper path of the printer or after paper jam it is possible to have a residue left in the printer. all these can be a problem.
Aug 10, 2007 | HP Photosmart 8050 InkJet Printer
139 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
