Question about TruTech PLV16320 Television
TruTech 20" Flat Panel CRT Television
I bought this TV from target for my dormroom, and am having some trouble getting it to program in my cable. I have 90 channels that I can access, its just I have to type in each channel. When I go to menu and then memorize channels, it starts at 2, and adds 2, 3, 4, and then it gets to channel 5(which I dont have) and stops. I cannot get it to go past channel 5 and thus cannot scroll through all my channels. I am wondering if you can help me fix this, or is this just a problem with the TV? I appreciate any help, thanks, Nick Zinser
  • rnzinser Aug 22, 2007
    There isnt a way to remove a channel, there is a feature on there called "channel skip", and I had it on, although I have tried numerous times with it on and off and I am having no such luck. I had purchased this TV at home and used it for a few days before moving into my dorm, and it programmed the channels fine and all was well. When I got into the room, my cable was sort of activated in parts, meaning at first I got nothing, then local channels, then the rest. I programmed it for those 3 local channels that came in, so I am wondering if its still stuck in that mode. Is there anyway to reset the TV?
    Genius:
  • 1,153 Answers
Is there anyway you can lockout channel 5 or delete it and then scan again? If this do not work after it programs the 3 chan. then see if you can manually add the other and then try to surf throu with remote.
Posted on Aug 22, 2007
SOURCE:
I have a TRUTECH TV that I bought with no remote, I have this Onkyo Chad remote and I need a number code for it to connect. Where is the number code???
This tv brand name TRUTECH tvs are specially made for Target Stores only merchindise,very limited brand name tvs,so there no universal codes exit for most of the tvs universal remotes out there.Try website like Remotes.com to buy the tv original remote.I bought one of this tv too from Target Stores.I did some research for this tv before,tvs was made for Target to trying to corner their own brand name for a little nit in the LCD tvs market.
Jun 17, 2011 | TruTech PLV16190 Television
Who make trutech tv
This tv special made for Target and sell mostly buy Taget stores only.Don't buy this tv brand and make,because later on tv have problems.It is impossible to find spare eclectronic board parts for this tv.
Jan 15, 2011 | TruTech PLV16190 Television
Trying to get a remote that was missing when purchased TV/DVD
if the unit has a warranty try to get target to give you the missing part.This product is their house brand. Hope this helps you with our problem.
May 17, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Trutech sd tv 20". trying to program channels and screen is black and says " now scanning" and it will not stop
Check your owners manual for instructions on how set-up your television for channel selection. This should tell you how to use you television with the antenna only, and how to use it with a cable set-up. If you are still having a problem, check the troubleshooting section and see if they have any solutions there. If all this does not work for you , then contact customer service for the television and cable companies for technical assistance with your problem. I hope this helps you with your problem.
Jan 26, 2009 | TruTech PLV16320 Television
I have a flat panel trutech television I bought last year and have lost the remote and the power on button does not work how can I program a universal remote if I cannot turn on the tv????
Depending on what type of remote you get, you should be able to program it without needing the power button on your TV. The way most of them work, you type in a code on your remote and press power and if the code was the right one, your TV will turn on. If not you try a different code. I would recomend going with the Philips PM725S universal remote. You could find one for $10 online
Dec 22, 2008 | TruTech PLV16320 Television
Trutech t2000-d remote control codes
I have the same problem as well. I bought 3 different remotes and not one will work with the tv. Although all 3 gave Trutech codes (1116, 1504, and 1713).
Feb 02, 2008 | TruTech PLV16190 Television
HD?
cannot program the tv to verizon FIOS
Oct 28, 2007 | TruTech PVS31170S1W 17 in. LCD Television
Hello
If your TV is an LCD (flat/thin panel), then it's 19", not 20". Support for that TV is at http://www.1800customersupport.com/trutech. But, if you have a Trutech tube TV, then it won't be listed on that website, and they won't be able to help you. In that case, call Target Customer Service (1.800.440.0680), and they should be able to put you in touch with the manufacturer, who can sell you a new remote control.
Aug 26, 2007 | TruTech PLV16190 Television
Owner manual
Just go to the company website and look under support and find their online manuals you can buy or possibly download or request another one.
Aug 07, 2007 | TruTech PLV16320 Television
TruTech PLV16320 Television Logo
138 people viewed this question
Top TruTech Televison & Video Experts
Steve Allison
Steve Allison
Eric Rotmil
Eric Rotmil
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
