Question about Cecilware EL-250 Deep Fryer
Oil doesn't stay hot
The oil in my Cecilware El250 starts to get hot but then stops, even if I push the reset button, it still doesn't get hot.
  • 625 Answers
Check the thermostat bulb that's in the oil. make sure there are no kinks in the tubing as there is a gas inside the cappillary that expands when it is heated. it connects to the thermostat inside the unit. the thermostat has a thin diaphragm inside that presses against a switch to turn the elements on and off.
Posted on Aug 22, 2007
SOURCE:
How to turn of change engine oil light on 2011 ford focus
From FocusFanatics online - -
Resetting the oil life monitoring system
1. Turn the ignition key to the on position. Do not start the engine.
For vehicles with push-button start, press and hold the START/STOP
button for two seconds without pressing the brake pedal. Do not attempt
to start the engine.
2. Press both the accelerator and brake pedals at the same time.
3. Keep both pedals fully pressed.
4. After three seconds, the Service: Oil reset in prog. message will be
displayed.
5. After 25 seconds, the Service: Oil reset complete message will be
displayed.
6. Release both the accelerator and brake pedals.
7. The Service: Oil reset complete message will no longer be
displayed.
8. Rotate the key to the off position.
For vehicles with push-button start, press the START/STOP button to
turn the vehicle off completely.
Jul 07, 2012 | Ford Cars & Trucks
Maint. req. light blinks 10 times after start up?
When a Honda Maint Req light blinks, but then stops, it is telling you to change your oil. If you don't change it, eventually, the maint req light will stay on. Here is how you reset the maint req light: 1) Turn they key to the II position
2) Turn the key to the off position, and push and hold in the odometer reset button
3) Turn they key back to the II position, while still holding the odometer button.
4) After about 10-15 seconds, the light should go off.
If that doesn't work, try it this way: p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Verdana}
With the igniition off, press and hold the odometer button, turn the key to the "on" position, but do not start the car. Keep the odometer button down until the oil light begins and ends flashing. Turn the key off, and then start car to see if it worked or not.
May 08, 2011 | 2005 Honda Element
Hello, I have a cecilware fryer that looks exactly the same as the FMB 40 model.I don't know the model # because all info has been previously scratched off the label.The pilot light won't stay lit to light...
PLEASE DO NOT TRY TO FIX THE PROBLEM YOURSELF. You should hire an authorized service company to evaluate and fix the fryer.
Cecilware had a well known problem with their thermopile F178A. There was a recall on it last year. There are a few that are still in the field. It's possible your fryer might have one installed in it.
Their website doesn't have the manual posted. You will need to call them. 800-695-4500
Good luck
Apr 13, 2011 | Cecilware FMP40 Deep Fryer
I have a Cecilware EL250 deep fryer that starts to heat up and stops. I feel it needs a new thermostat. What is the thermostat model number, how much does it cost, and where can I buy it. I live in...
Hi there.
You will be able to find the nearest authorized parts and service dealer in your area when you visit http://www.grindmaster.com for your Cecilware Fryer.
Feb 18, 2011 | Cecilware EL-250 Deep Fryer
I had the oil changed but the change oil light is still on, how do i reset the computer? 2000 oldsmobile alero
How to Reset the Change Oil Light
After changing the engine oil, the system must be reset.
With the ignition key to ON, push the RESET button
located in the driver's side instrument panel fuse block. The
CHANGE OIL light will start to flash, press and hold the
RESET button again. The reset is complete when you hear
the chimes sound and the CHANGE OIL light goes out.
Oct 25, 2010 | 2000 Oldsmobile Alero
2007 ford 500 oil warning light comes on and just had the oil and filter changed 700 miles ago,62000 mile on car .light comes on when started ,push reset and it goes off and stays off until the next start...
When they changed the oil they did not reset the light. The car needs to be told when the oil is changed.
when the warning comes on press the setup button. it should say press reset if new. Press the reset button. It should say if new oil hold reset. Press and hold the reset button until the display changes to oil life set to 100%.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Oct 12, 2010 | 2007 Ford Five Hundred Limited Sedan
Oil change light stays on after oil change
1. Turn ignition switch on but don't start the engine. Push ENG MET button on the trip monitor ONE time.
2. Press ENG MET one more time within 5 seconds. Within 5 seconds press and hold the RANGE button (90-94) or the GUAGE button on 95 Vettes, you will see the light start to flash
3. When light stops flashing the CHANGE OIL LIGHT has been reset
Apr 21, 2009 | Chevrolet Corvette Cars & Trucks
Wells deep fryer won't heat
Is the oil coll and it still doesnt reset?If so the hi limit is bad,which is the reset.If you gain acess to it you will see 2 wires.Connect these wires and it should heat.HOWEVER this is a saftey device that prevents the oil from getting too hot and catching on fire.
Mar 22, 2009 | Wells F-686 Deep Fryer
Change engine oil message stays on
the Change Engine Oil message is diplayed in the driver information center when the oil change is due ,,,,, to RESET display message , press the INFO button to display the ENGINE OIL LIFE message , ,, Press and Hold the RESET button untill 100% ENGINE OIL LIFE is displayed.
Dec 23, 2008 | 2001 Cadillac DeVille
Cecilware EL-250 Deep Fryer Logo
168 people viewed this question
Top Cecilware Kitchen Appliances - Others Experts
Joe Palazola
john h
Treefrog15
Treefrog15
Are you a Cecilware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
