Question about HP Series 4L Toner Printer
Dont know how to manually feed paper
The paper cassette feed isnt working. Just want to manually feed paper but dont know how. I am not a tech. FamilyguyT
  • 98 Answers
Follow instructions on the following link (look in the Manual Feeding section of the document): http://www.nefec.org/UPM/printers/mhp4l.htm#Paper Good luck, hope it helps.
Posted on Aug 22, 2007
How to replace pickup rollers
This should help. Good luck !
Cassette (Tray 2) paper pickup and feed rollers
To remove the paper pickup and feed rollers
1 Remove the cassette.
2 Locate the two rollers on the bottom of the paper pickup unit (above the cassette). The pickup
roller is the smaller roller, and the feed roller is the larger roller.
3 Pinch the tab on the end of the cassette pickup roller (callout 1), and pull the roller out.
4 Pinch the tab on the end of the cassette feed roller (callout 2), and pull the roller out.
Figure 6-24 Removing the cassette pickup and feed rollers
Note Always replace the cassette pickup roller and the cassette feed rollers at the same time. Also replace
the separation roller (located in the paper cassette) when replacing these rollers
Aug 14, 2014 | HP Color LaserJet 4600n Printer
My printer isnt feeding paper and it has plenty in the shoot
You may have a piece of paper jammed somewhere, open inspection hatches and check
Jul 23, 2014 | Canon Pixma MP600 Printer
Paper feed results in a clicking and no feed
This sounds as if the paper pick up assembly is not lifting the paper-up to meet the rollers. This is like a ratcheting sound when lifting. When the paper gets high enough it hits a sensor arm and the copier will indicate paper in the cassette. If it doesn't lift it will quit but will never indicate paper in cassette. Does the other paper cassette feed? I know I've had to replace the paper pick-up assembly before because of this problem and is very expensive. Good luck.
Sep 27, 2011 | Canon imageRUNNER 210S Copier
Printer Canon LBP3300, When was printer it show "Load custom paper in manual feed slot". Have try to slot manual feed but also cant work. Please help to solve this problem. thanks
Load Legal paper in Cassette 1.
If you want to print using only one piece of paper currently loaded in the Manual Feed Slot, click [Resolve Error].
If you want to feed paper from the cassettes, remove the loaded paper from the Manual Feed Slot.
Dec 14, 2010 | Canon LASER SHOT LBP 3300 Printer
I cannot get the paper to load into the printer
I had an issue with the cassette tray paper feed. I loaded paper in the rear tray, manually used the printer properties button to make it print from the rear tray and printed from there. The next day I manually did the same thing but forced it to print from the cassette (bottom) tray. It worked fine today. It no longer thinks that there is no paper and the rollers are picking up the paper edge for proper feeding of the paper. I did not go through the roller cleaning procedure but I would do that if switching back and forth manually between trays doesn't work.
Sep 20, 2010 | Canon MP560 All-In-One InkJet Printer
I cant find my manual how to i place the paper underneath so it feeds through the bottom
You can use the paper cassette located at the bottom of the printer, on the front when the output paper tray is closed concealing the paper feed switch, the usb port and the cassette lamp.
1 Gently pull out the cassette from the printer.
2. Remove the cover from the cassette.
3. Place your paper in the cassette tray.
a. when using A5 or larger sized paper (non standard sized paper, pinch the tab and extend the cassette if needed.
b. legal sized paper is not loadable in the cassette
4. Do not load paper above the load limit mar4k.
5. Make sure the print side of the paper is facing down.
6. Align the paper stack against the right side of the cassette
7. Slide the paper guides so they fit the loaded paper stack.
8. The paper cassette will hold up to 150 sheets of plain paper, however you do not eant to stack any more than 50 sheets in the Paper Output Tray.
9. Reinsert the cassette into the printer. Then set the cover on the cassette. Now make sure the cassette is pushed al the way into the printer. (If long paper was used and the cassette was extended iy will now extend beyond the front of the printer
10. Prepare the paper output tray by opening the front cover and pulling out the tray extension until extended completely.
11. Press the paper feed switch so the cassette lamp lights.
You can slo select the paper source with the printer driver if you prefer .
Mar 07, 2010 | Canon Office Equipment & Supplies
False ricoh 1224c paper jam warning
check tthe clips retaining teh feed rollers havent sliped off if it isnt picking up from tray take the tray at top out and then watch from above to see if the rollers are turning to feed paper.. if the lifts out check the side door guide isnt out of plavce check the end paper guides as well//check when you take the tray out look to see there is any paper stuck at the back where the tray sensors ares can cause a lift motor error aswell
Mar 24, 2009 | Ricoh Office Equipment & Supplies
Keeps saying no paper in tray although paper is in tray
I encounter that problem before, after I checked the sensors, feed unit and mechanism nothing is wrong or broken but still NO PAPER indicates on the display .I only noticed with the machine is the cassette tray or the paper tray, when you try to pullout the cassette tray and look at its left side, there is missing parts on it. There is a spring and actuator on it that will engage on the feed unit drive. Try to find the same machine and look at the cassette tray to see the missing parts on it. You can buy a new cassette because the parts that is missing maybe not available.
Feb 19, 2009 | Brother DCP-8065DN Black and White Copier
Feed switch unresponsive
your case seems the cassette feed unit can not detected by cassette unit sensor which locate around the paper input roller area.you need to check
1) the cassette push in the well position which can touch the sensor well egnough
2) find out this sensor and adjust the sensor sdander position (more sensitive).
Feb 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA ip4000/paper jammed problem
Tackler- I dont think I have a solution but I know that the cassette should stick out about 5cm i.e. the cover just fits on nicely. I found with mine sometimes it needed a firm (but not hard) push in as obviously some sensor was not being tripped and it would just not pick up the paper in the tray. Have you tried using the top down feed? At least if that works you can print (and you can stack up a couple of pages).
Oct 22, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
HP Series 4L Toner Printer Logo
83 people viewed this question
Clive
Clive
