Question about Mitsubishi WD-57732 Projection Television
Error Message When the set comes on it states the TV will shut down in a few seconds because the airflow is blocked. There is no blockage and the lamp door is secure. The TV is 3 1/2 months old. Some direction and advice would be appreciated.
  • Anonymous Mar 11, 2008
    tv is one week old. error message says fan is blocked & it will shut down. nothing is blocking the lamp or the fan.
    Genius:
  • 1,153 Answers
. Set shuts off after displaying the message "TV will shut down in a few seconds. Please check if the air flow is blocked." After shutdown, it may have a yellow status LED, self diagnostics indicates error code 38. To repair, replace the Lamp Thermal Sensor with the new version, part # 299P313010A. The sensor is located on the Lamp Cartridge Housing. See Service Tip VS-72B. Under rare circumstances, when a replacement thermal sensor is not available, refer to the original Service Tip, VS-72 (page 2 and 3 of VS-72B) If error 3-4 then this maybe problem:. Check to see if the lamp is on when the unit is off (in standby) if it is components on the Power PWB... K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects ... deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049010, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010. See Service Tip VS-73 2. If the lamp never lights suspect the Lamp part # 915P049010
Posted on Aug 22, 2007
SOURCE:
Area around TV is clear, nothing is blocking TV or air flow. When we use the TV we frequently get this message: The TV will shut off in one minute. Check to see if air flow is blocked. Happening more...
you need a new power supply unit these after some time get old and start over heating causing the tv to heat up intermediately if you take it to a repair shop and have that replaced it will be like new again
Feb 25, 2011 | Mitsubishi WD-52525 52" Rear Projection...
My tv monitor says "TV
YOU NEED TO REPLACE THE THERMOSTAT ON YOUR SET TO CORRECT THIS ISSUE .
Dec 14, 2010 | Mitsubishi WD-57732 Projection Television
Have a mitsu wd-52631 - get message "tv will shut down in a few seconds - chk for air flow blockage" then shuts down - wil turn on after sit for several hours. No blockage evident.
Well....the reason you are getting an "airflow message" is that there is a thermal sensor on the BACK of the lamp cage, and the connections on it get to be "intermittent" after awhile...and when this happens...the computer thinks that the lamp is overheating due to a dirty filter or fan--and shuts down the set.
It is a small, white plastic sensor, with 2 wires on it, that go to a connector and it has a black and red wire(usually) in a twisted pair that connects to the sensor connector. The connectors need to be REMOVED and the sensor HARD-WIRED (directly connected to) the other pair of wires. IF you have done some electrical work before...this is easy. You only need about 3" of spare wire to patch in between the sensor and the other connector, after you cut the connectors off. BUT...if you do NOT have repair experience...I suggest you call a COMPETENT, FAIR tv shop in your area, if you do not have a service plan...and tell them you have a mits. set that needs the "airflow sensor problem" repaired . this CAN be done -in-home, in about an hour or less, and for under 300, including service call.
Oct 12, 2009 | Mitsubishi WD-65731 65" HDTV
Error / problem message
these are on mitsubishi's recall list you need to get in touch with mitsubishi and have them find a authorized servicer in your area to come put a thermal sensor in your set.
Aug 12, 2009 | Mitsubishi WD-57732 Projection Television
TV turns off because of air flow
It is probably a bad temp sensor inside the TV. My 73" started shutting down before it was a year old. I moved it way out from the wall and it got a little better. A tech was just out to change the bulb under an extended warranty and he said there is a service bulletin about the temp sensor. If your TV is out of warranty you might call Mits and see if they will cover the sensor replacement. Tech said it takes about a 1/2 hour in the home to change it...
Apr 20, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Error Message
If the set is only 3 1/2 months old, you should still have warranty coverage. Opening up the unit will void the warranty, so don't open up the set. Call for warranty service. In all probability, the air flow sensor is defective. The message you are seeing is a result of the air flow not being detected or not sufficient. In any case, this is a covered problem and should cost you nothing to fix.
Dan
Mar 20, 2009 | Mitsubishi WD-Y65 65" HDTV
Error message
Good Day, drdeath57;
Make sure your air vents are clean but more than likely you should suspect the TV's Lamp Thermal Sensor
Aug 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
Dec 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi dlp tv model number wd57732 purchased 2-20-2007
i had the same problem on 10/24/07 and i called a Mitsubishi warranty company near me and they came out and replaced the Sensor part # 1299P313010A. No problem since
Jul 30, 2007 | Mitsubishi WD-57732 Projection Television
Mitsubishi WD-57732 Projection Television Logo
519 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
