posted by Marto on Aug 22, 2007
Hello, I have a Motorola DC 800 adapter. I'm trying to transmit music from my pc and the audio gets there by two seconds (it comes and goes every two seconds) Does anyone know what can be the problem?
1 Other User Has The Same Problem
Comment by chong06, posted on Feb 12, 2008
I have paired my Motorola DC800 to my lap-top through internal Bluetooth. And, the other end of the DC800 is connected to my sound system.
But, there is still not music coming out? How do I "push" the music in the laptop to the blue tooth?
Thank you.
Regards,
C.H. Chong
Solution #1
posted on Jul 21, 2008
I worked on this problem for 3 days and finally the Netstubler software did it for me. Thanks a bunch!!
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 05, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
The DC800 is a Bluetooth A2DP device. It works on the 2.4 GHz range like WiFi, but it's not a WiFi device.
@marto: Most likely you do not have a stable Bluetooth connection. Move your DC800 away from other 2.4 GHz devices like WiFi access points and microwave ovens. Also don't put it on a metal shelf if you can avoid it, and reduce the number of objects between it and your laptop.
@chong06: You need a Bluetooth stack that supports A2DP (Bluetooth stereo audio) IVT BlueSoleil does, as does the Widcom Bluetooth stack. The DC800 will connect and pair like Bluetooth Stereo Headphones (note: not headset or hands-free - those are different profiles).
Solution #3
posted on Sep 12, 2007
If this is an RF transmitter working within the WiFi range that might be your problem. First find out what channel you adapter is broadcasting on. Do this by logging into it. Then on your PC get a program called Netstumbler, and load it on your pc then turn on the program it will go out and find all of the access points around your area. It will also list the channels they are on. There are 14 channels but only three can be used channel 1 channel 6 and channel 11 find the channel that is least used and set you adapter to it. This should work.
Let me know if this helps.
Thank you,
Shuttle83
Thank you,
Shuttle83
Suggest a new solution for this problem
Post a New problem for Motorola DC800 Wireless Adapter
Email this problem
Email this problem
Can you Help with these Wireless Adapters problems?
Repair Service
Find Wireless Adapter Repairman Near You:
