Question about GE JKS05 Electric Single Oven
F4 Hi, My oven keeps on beeping and have a flashing F4, the door will not open, its lock, Usually it does that when its self cleaning but for somereason its locking it self but its not generating heat,which is a good thing. I don't have the owner's manual but i need to know how to fix this problem... what does F4 mean. Please some one give me an explination or a solution. Thanks
    President:
  • 878 Answers
Luvin, F4 is a shorted oven sensor. Under 950 ohms. Should read 1060 ohms at room temp. The sensor is located in the upper left hand corner of the rear oven wall. Remove the 2 screws and it will pull out enough to remove the connector. Catriver.
Posted on Aug 22, 2007
SOURCE:
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
I'm trying to self clean the oven. I am following steps in the manual- however, when I press start to self clean, the door lock light flashes, then beeps and the oven turns off. The manual says the door...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 23, 2010 | GE JTP15 Electric Single Oven
F90 code flashing and i cant reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected]#$%
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Dacor CPO230, can't get lock to engage for self cleaning. I follow step clean symbolcomes up door lock moves into locked position then beeping starts and the word door flashes and the lock opens up.
For some reason the oven thinks you have a door that is not shut all of the way. Check the locking slot to make sure that there are no obstructions. Make sure that you are only doing one oven at a time, and not trying to cook in the other. Make sure you have no racks in the oven. Try pushing lightly on the door when the lock engages. For some reason your lock isn't engaging fully and that's why door is flashing. Good Luck
Below is from the owners manual for your oven.
Oven does not self-clean Door not shut tight Check for obstructions. Close door tightly
Oven set for delay timed cleaning Oven will start to self-clean at preset time.
Press CANCEL/SECURE to return to
normal operation
Double ovens only: Other oven is on. Turn off other oven.
May 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
My self cleaning oven door will not open, and keeps beeping and
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$%^@#
Apr 19, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Stove door locked and continues to beep and flash code F9
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$%^^%$
Mar 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door lock lites keeps flashing but the door is not locked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%[email protected]#$%
Mar 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven lock will not open
my self cleaning oven door will not unlock what do I need to do?
Jan 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2008 | Frigidaire 27 in. Electric Double...
GE JKS05 Electric Single Oven Logo
210 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a GE Oven Expert? Answer questions, earn points and help others
