Question about Garmin StreetPilot C330 GPS Receiver
Help My garmin died. First the battery, (I have a new one on order) then the signal died. I opened it up and there isn't anything loose. Can an antenna just go bad? Could this somehow be connected to a bad battery?
This how the antenna should be installed
Posted on Feb 29, 2008
If they don't give you a new one under warranty I found an DYI GPS repair guide,so you can do it yourself too, not that difficult. The part is on Ebay. Also, there are third party Garmin repair services that will fix it for cheap.
Posted on Jul 21, 2010
My battery died also.... garmin says you have to send it back to them and if the warrantee is out, it is a flat fee of $150.00
I just went to you-do-it electronics in Needhan, MA they are on the internet. I ordered the battery (special Order) for $36.00 the unit opens fine and the battery comes out. the new battery has the open wires to resolder to the 2 speakers. so it is duabale. I have to wait 4-5 days for shipping.
Jeff
Posted on Jul 31, 2008
When you opened the GPS to check the battery there's a plate under the covers that keeps you from opening the unit all the way, because of the wires. Make sure you place that plate back in the correct location, because that's the antenna. It should be at an angle inside the top of the cover.
Posted on Jan 05, 2008
It is very unlikely that the antenna has just gone bad when you opened up the gps unit did you notice if the battery had started leaking if so to what extent the electrolytes that leak from batteries is very corrosive and can destroy pcb's in no time at all if the battery was ok then it should just be a case of fitting the new battery gps systems can take up to five minutes to track satellites
Posted on Aug 27, 2007
Jul 08, 2011 | Garmin nuvi 780 GPS
May 10, 2011 | Garmin Rino 110 (14 Channels) 2-Way Radio
Aug 10, 2017 | Garmin Rino 120 GPS Receiver
Oct 17, 2010 | GPS
Jul 25, 2010 | Garmin StreetPilot C330 GPS Receiver
Dec 12, 2009 | GPS
Jul 03, 2009 | Tomtom ONE GPS Receiver
Nov 29, 2008 | Garmin StreetPilot C330 GPS Receiver
Aug 26, 2008 | Garmin iQue 3600 GPS Receiver
Oct 21, 2015 | Garmin StreetPilot C330 GPS Receiver
361 people viewed this question
yes, I had the same problem. I am trying to send it back. Very unhappy!
Garman C330 died also and won't recharge in the vehicle. I already checked and replaced the fuse in the vehicle it still will not recharge???
garmin showed low battery after only 2 hours use and won't charge
The first time Garmin C330 battery had around 8 hrs of life as claimed by manufacturer...BUt after that whatever amount of recharge you do, battery is not functioning..but the apparatus works with wired connection. Dont know whats wrong....
My C330 will not work when plugged in, or on battery it turns on for a second or so and then turns off. I can hold my finger on side button to keep screen lit, but as soon as I take my finger off it goes off. The unit is about a year and a half old.
