Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Freezer is over-freezing
A while ago I started noticing ice building up on bottom of the freezer and since that time have broken it out, and cleaned out the drain tube so it is clear of ice about 4 times. And the problem is that the freezer is way too cold and freezes our ice-cream and everything else rock solid. I've got the freezer setting all the way down to one and it doesn't change the temp. The refrigerator temperature is okay, but has been slightly freezing the lower two crisper drawers. I've had a fridge repair guy out twice already and he pretty much offered me no good advice but he still got my money for showing up. I've cleaned the grills underneath the unit of dirt and junk like the repair guy suggested, but it didn't do anything. Any suggestions?
  • 1 more comment
  • jralph Aug 28, 2007
    are those parts i could order and change out myself?
  • Anonymous Aug 25, 2008
    Frost build up near vent to bottom crisper drawer from freezer and bottom crisper freezing veggies even when vent door is closed(vegetable position). Freezer/fridge settings are at factory settings. Have noticed also that freezer is colder than usual.
    *Have thoroughly cleaned compressor coils from underneath and behind bottom rear of unit.
  • faith1370 Oct 21, 2008
    My upright deep freezer keeps over freezing the food even though I have the control set to 1.
    Champion:
  • 217 Answers
The possible cause is the temperature sensor or thermostat is not working, maybe its switch is stuck up on ON position, it looks like a wire attached to the area where ice is building up, it is connected to a switch to turn off the compressor thus controlling the operation of your freezer. replace with new thermostat will solve the prob.
Posted on Aug 23, 2007
  • teofilo navarro
    teofilo navarro Sep 04, 2007
    Defrost sensor, thermostat, temperature sensor or switch are the same. aircons, refrigerators and etc. uses this sensor to control temperature thats all.. [:0)
  • 183 Answers
Change defrost sensor. Regards Advisor
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Water under crisper drawers and then leaking outside underneath.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 02, 2010
Buildup of ice on bottom (inside) , drain tube in pan underneath but is always dry.see no reson for ice build up
The drain pipe is most likely blocked. It is a plastic tube about 10mm diameter, as you've probably noticed. Try reaming it out gently with a wire hanger.
Sep 06, 2010 | Whirlpool 247 cu. ft. Upright Freezer...
Ice build up on bottom freezer
Ice build up on the freezer floor alone, with no ice on shelves or food above the floor, usually indicates a clogged defrost drain problem. when your unit goes into defrost, the melt water is intended to go down a drain tube from the freezer to a pan on the outside bottom of the unit, usually near the compressor. Sometimes these drains are clogged with food debris, other times some of the melt water does not completely drain, and freezes - this build up of ice can then clog the drain. You can unplug the fridge, with both doors open and a fan blowing for 24 hours to temporarily remove the ice and water, but it will return most likely, in which case you would need to have the drain cleared out and / or have a drain heater installed by a qualified refrigerator repair service.
Apr 07, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
Mar 05, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Ice building up in bottom of freezer of side by side MSD27 Maytag
Your defrost drain tube is clogged up. Remove the ice and look for the top of a drain tube about 3/8-1/2" in diameter. Once the ice is gone, use a meat baster (turkey baster) full off hot water stuck in the top of the drain tube and blast hot water through to clean it out. Do this several times with about 4 cups of hot water so you don't over flow the drain pan and flood the floor
Dec 20, 2008 | Maytag MSD2756G Side by Side Refrigerator
Fan in freezer - evaporator fan?
HI. thanks for the question. yes the fan in the freezer must be replaced.and also the drain tube in the freezer, is clogged. cut power to the fridge. remove back panel . replace the fan motor . also clean ice build up. clean drain tube, from freezer to the drain tray, at the back, near the compressor. thanks the appliance doc. please rate my answer. thanks
Oct 07, 2008 | GE GTS22WCP Top Freezer Refrigerator
Kenmore Refrigerator Mod 70162990
It is under the evaporator you will have to remove the back cover... let me know if you want to do it and I will step you thru it...
Sep 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice at the bottom of the freezer
bottom of rezzer compartment is supposed to be frozen( depending on timeof cycle) i wouldnt point to a defrost problem unitil the ice build up is hindering refigeration, its quite possible that thte defrost drain has just frozen itself over, and needs to be cleared to allow defrost water to go into the drip pan under unit
May 02, 2008 | Maytag MSD2756GES Side by Side...
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Maytag side by side, bottom freezer compartment had daily ice build up
I had the same problem with mine a couple of months ago. There is a drain which gets plugged. You have to remove the contents of your freezer, and then look at the back area of the freezer. The panel that's on the back is removable. Once it's removed, you will see a drain at the bottom. Mine was clogged up with debris, and was covered with ice. I poured warm water over the drain, soaked it up...did this a few times to melt the ice, then I worked at cleaning out the drain. Mine wasn't plugged too badly, I ended up having to blow air through the drain using my air compressor, to be positive that it was clear of debris. You could poke something down the drain, but it won't go very far because there is an elbow on the drain tube(visible on the backside of the unit itself)
If you get it cleaned out, it should be fine. Mines been great ever since I cleaned mine out...no more puddles on the floor.
Feb 04, 2008 | Maytag MSD2454G Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
3,281 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
