Home | Black & Decker | RC550 10-Cup Rice Cooker | Rice cooker
Black & Decker RC550 10-Cup Rice Cooker
Problem for Black & Decker RC550 10-Cup Rice Cooker
Rice cooker
By srilu on Aug 22, 2007
I brought the cooker 2 months ago and in the morning i see no light in the cooker... and looks like it is not working at all...
this is my second cooker in past 8 months..
please help...in case i have warrantly where can i get it repaired
Best Solution
posted on Mar 11, 2008
Helpful)
Ammulu11
Rank: Apprentice
Rating: 89%, 4 votes
I have a Black & Decker rice cooker which shows no light in it when connected to the power outlet. The power plug from the rice cooker is attched to the cooker, so cannot be disconnected. Please advise me on this problem. Thankyou.
Was this helpful?
Yes
No
Solution #2
posted on Nov 30, 2007
Helpful)
VINCE-C
Rank: Apprentice
Rating: 85%, 4 votes
First you have to make sure that the power outlet is working fine using a Multi Tester. Next is disconnect the Power Plug from the Rice Cooker and test continuity within the cord.  make sure those two are both working good.  next step is to open the Rice Cooker Bottom.  Again using a multi tester, Test the continuity of the Thermostat, make sure multi tester setting is on the ohm setting. reading should be zero, if reading is higher than 200 ohms, the thermostat is defective.  Which is the reason why your cooker is not turning on is due to an open in the circuitry.  Check warranty with the store you purchased it from or the manufacturer of the rice cooker.
Was this helpful?
Yes
No
Popular Solutions for Black & Decker RC550 10-Cup
Questions and Unsolved Problems for Black & Decker RC550 10-Cup
Do you recommend Black & Decker RC550 10-Cup Rice Cooker?
Answer
Answer
Need cooking instructions for black & decker rice cooker
Answer
Describe your Black & Decker RC550 10-Cup Rice Cooker Problem need replacement bowl
Answer
Decker rice cooker not working I have checked with outlets and then the "COOK" LED is not... (More)
Answer
It turned on fine, indicator lights, etc. Five minutes later it had shut off completely, no lights,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Black & Decker RC550 10-Cup...:
Top Rice Cooker and Ste... Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Rice Cooker and Ste... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
