Question about RCA P52926 52" Rear Projection Television
RCA Home Theatre Model # P56927, Serial # 026451246
Picture quality looks like double vision or shadowed.
  • goombah1979 Jun 18, 2008
    I am having the same problem with my tv. It looks like three separate layers of a picture...green, blue and red. I have not done anything to fix it yet. Please let me know what i can do to fix it
    Sergeant:
    Champion:
  • 375 Answers
Your convergence alignment is off,requires reaignment or possible replacement of module,this type of rca projection tv has a fault with the harness feeding the convergence module there is a fix for it,contact you local rca dealer,they must replace the connector because it bows and looses connection over time that creates other faults also/
Posted on Aug 22, 2007
SOURCE:
LC-x50 has double vision or shadowing. What can cause this?
several reasons : 1.check cables, if too long and poor quality you get echoes in signal and shadows in the projected picture.
2.feed the right solution to the projector and adjust in menu pc adjustment the item FINE Sync. native resolution is 1024 x 768.
Jan 16, 2011 | Eiki LC-X50M Projector
Picture sinks from top and rises from bottom. Looks like doubles
You have a convergence problem. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to repair the problem and where to get the parts at the best price. If you need more help please let me know.
Thanks for using FixYa and for the generous rating.
hardrocko
Jun 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 53inch RCA big screen tv, we have double vision
Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if the option has disappeared or not and I can asssist you with how to fix it.
Jun 14, 2009 | RCA D52W23 52" HDTV CRT TV
Ghosting of picture from a Panasonic home cinema system
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
Mar 18, 2009 | Panasonic Televison & Video
Model p46770ck rca home theatre
sounds like a bad flyback on the circut board (a common problem) part is around 70.00 but they will get you in labor
Dec 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Home Theatre Projection TV
Your ICs are bad that control the Convergence. I would quess that the ICs that they have used before have been the cheaper versions. Sanyo are the best the cheap ones only last for a while then need replacing. The sanyo chips cost considerably more than the imitation ones but are worth it in the long run.
Mar 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red Shadow on Picture
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 14, 2008 | Toshiba 61H71 61" Rear Projection...
RCA Home Theatre System 51 or 52"? Chassis # PTK169PAAS
If it is a "minor" convergence problem you can adjust it by going to the menu and scrolling to convergence and follow prompts A cross will appear when you have reached the correct place and you do the minor adjustments as it says. If picture is bowed you have major convergence problems.
Jan 05, 2008 | RCA 32V420T 32" TV
RCA P52926 52" Rear Projection Television Logo
312 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
