Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
It is the lacie 250g, not booting up
Just not being reconised
  • 254 Answers
I'm giving you the same info as previous inquiries. Take a look here, problems are explained- unfortunately they don't suggest any easy fixes. These external drives, according to this site, and my own limited experience, are merely a standard drive in a housing with the proper adaptive circuitry for USB/Firewire connection. A couple of possibilities: open the housing, check the connections to the drive. I've seen one drive where the IDE interface cable wasn't seated properly. If you have some tech savvy, you could remove the drive and hook it up in a standard desktop PC, then see if it can be accessed. If what the above link explains is the problem with your drive, a simple solution looks bleak. You might also look on the 'net for drive diagnostic software. If you do open the case, note the drive brandname (Western Digital, Maxtor etc) and go to their respective website and download their diag. software. Unfortunately, none of this may help you get your data.
Posted on Aug 22, 2007
Lacie serial number 1214802236941cr
Try connecting the LaCie to another computer. If this still does not work then the LaCie is faulty.
Nov 20, 2012 | LaCie External USB 2.0 500GB 7200 RPM 500...
My LaCie hard drive is listed in preferences but it does not boot. Your suggestions?
Have you ensured the Lacie HDD is bootable? IMC, external drives that does not contain boot files or not-formatted in bootable mode cannot boot your device.
Try formatting your Lacie drive into bootable mode. Right click -> Format -> Check "make device bootable" and click start. THis shoudl help.
Mar 05, 2011 | LaCie Computers & Internet
If I try and format my LaCie drive through my computer its capacity shows as 9.99 MB why is that if I do format it (NTFS) will it have the correct capacity of 250G
You may have two or more partitions on this hard drive. If you delete all the partitions and then format the hard drive then you will have the full unformatted 250 Gb capacity.
Sep 24, 2010 | LaCie (300770) 250 GB Hard Drive
When my lacie external hard drive is connected,my
Check your BIOS > StartUp sequence
Maybe the USB boot option has much higher priority that HDD boot. Try exchanging their priority and then reboot, with your external HD connected to pc.
Jan 03, 2010 | LaCie (300951U) 500 GB Hard Drive
LaCie d2 200GB on my Pc (windows xp) via USB 2.0 doesn't show
the situation here is ahppening to all external sata or Esata drives what happens is the external closure has a usb controller when this dies the drive doesn ot spin up or does not reconise simple solution buy a external drive encloser and transfer the drive to it and that will work. thanks and please rate.
Nov 24, 2009 | LaCie d2 (300769) 200 GB Hard Drive
Same problem
uninstall the driver and reinstall it or do a driver rollback,via your device manager(XP)
Sep 01, 2009 | LaCie (300770) 250 GB Hard Drive
Computer will not boot with Lacie Desktop Hard Disk connected.
You can enter the bios on bootup by pressing a special key to force your computer to go into BIOS mode. What key this is varies by computer, often it is F8, F10, sometines F11. Anyway, use the key for your computer, and change to boot modus to not first boot from USB.
Dec 15, 2008 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Dropped hdd beeps wont be reconised by computer
What kind of beep is that? Anything similar to these sounds: ?
Most likely the spindle got stuck. That's really bad.
Oct 10, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Can't access my lacie external hard drive
I would first plug it in to a different PC, this will tell you if the problem is the Lacie or Windows Vista.
if it works on a different PC then remove it from Device manager or go to the Lacie website for Vista updates.
If it does not work on a different PC then there are 3 possibilities
1. the drive got cleared data lost
2. the enclosure is bad (I would bet on this)
3. the drive is bad
purchase a USB enclosure, remove the drive and install it in the new enclosure plug in and test.
Hope this helps
thanks for rating
Jan 09, 2008 | LaCie (300728U) 250 GB Hard Drive
Hubs don't work on LaCie minin 250 GB Hard Drive
there is not enough power coming through ports each device re-quires 1-5 volts to run and if your mac has not got enough power to boot all devices then sadly all things pluged into will not reconise and with mac the os is not properly designed for it now if you got yourself an external usb 2.0 hub powered then yes all devices will be seen in mac windows firewire is unsafe at moment for this to happen ask them what system they had had configuration on. hope this has helped
Apr 08, 2007 | LaCie mini (300998U) 250 GB Hard Drive
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
78 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
