Question about RCA F32665 32" TV
PICTURE IN PICTURE TV RCA
I would like to know, how the PIP works. what function do I need to use? Thanks Regards Josue Gonzalez
  • 398 Answers
The PIP puts a smaller picture on your main picture. Usually, the smaller picture is generated by a second source, such as a VCR. The VCR must be connected to the main cable signal and connected to the TV through the red, white, yellow RCA jacks. The VCR picks the smaller picture whilt the tuner in the TV picks the main pucture. The PIP circuits digitally add the smaller picture to the larger picture. The PIP cannot be used to veiw 2 different channels at once on satellite systems because the satellite receiver sends only one channel to the set at a time.
Posted on Aug 22, 2007
SOURCE:
How to work a sony 40 in projection tv's picture in picture feature
Locate PiP button on TV remote and press it to turn on picture in picture function and again press the same button will turn off PiP feature.
Hope this info will help you.
Thanks.
Nov 28, 2009 | Sony Televison & Video
The tv screne picture on my insignia tv is off centered and is split in two
I suppose your TV has a PIP function.
  • check if u have a PIP function on your remote control or
  • Go to the Menu n in the display see if u can see the PIP function or the Aspect Ratio function like 4:3 or 16:9.
  • You have to switch it to standard or normal view to change to one full picture.
Jun 04, 2009 | Insignia NS-LCD19 19 in. LCD TV
Getting vga pic
ck for correct input. composite video on tv.
Aug 03, 2008 | RCA F26317 TV
RCA Home Theatre - Tuner problem
you may coldsolder the tuner first before replacing the new one,maybe it can works.
Apr 30, 2008 | RCA TruFlat 27F520T 27" TV
Tube tv bouncy picture
I've seen this problem before, would need your model #, meanwhile is your picute bounce when you hit the if pack, or pip module, if it does that were your problem is. these or your silver cassing, standing upward.
Regards
What About Bob
Feb 18, 2008 | Televison & Video
PIP
Let me know what you find out, I have a similar problem. I can get the PIP screen to come up but it will not allow me to have it on an input that actually shows a picture - just blue screen.
[email protected]
Dec 31, 2007 | Vizio L32 32 in. LCD HDTV
Magnavox pip
PIP requires either multiple tuners, or another video source. It sounds like your tv lacks another tuner. Does the tv have inputs for, say, a vcr? If so, connect a vcr to it, play a video, and then select PIP. It should display the video and tv simultaneously.
Nov 13, 2007 | Televison & Video
Can't get second picture in Picture-in-Picture (PiP)
Watching two separate tv channels at the same time requires two tv channel sources,i.e. a split of some kind. For instance,the cable coming in thru the wall is split-half to tv or vcr/dvd combo and then to tv,the other half to cable box,then out to tv.If what I described fails,then you may have an actual tv failure.PIP video is generally a separate circuit from standard video.An expert tech w/service literature should be able to help. Let me know if you need more assistance.
Sep 16, 2007 | RCA HD52W56 52" Rear Projection HDTV
PIP function
The Main Picture will eventually go out or at least become distorted. Generally the PIP circuit can be repaired by replacing a couple of capacitors. Probably a job for a Pro but it will need to be done at some point.
Apr 21, 2007 | Mitsubishi VS-45605 50" Rear Projection...
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Jan 23, 2007 | Sony KV-35V35 TV
RCA F32665 32" TV Logo
265 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
