Question about Apple iPod shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A)
Ipod problem i recently moved to a new house and no longer have the old computer that has my music and info on it.. my question is , is there anyway i can sync it to the new computer.. the new computer has i tunes already?
  • Anonymous Jun 11, 2008
    hi a have the same problem can you help me ? write to my email [email protected] thanx any way.
Ipod is not playing the songs . ipod showing green and orange lights
Posted on Dec 14, 2007
I have ipod shuffle a1204 no playing
Posted on Oct 16, 2007
SOURCE:
My ipod is a good 5 years old but it has 5000 songs on it. ive gone through computers and no longer have any sort of itunes with my songs in it. you can navigate to any page of my ipod and it even goes to...
I have used Yamipod to get music from an iPod that I purchased on Craigslist. You can download the free application at the link below for Windows, Mac and Linux.
http://www.yamipod.com/main/modules/home/
Good luck.
Jan 11, 2011 | Apple iPod nano
Tip
How to use your iPod to move your music to a new computer
***** THIS DOSE NOT WORK WITH IPOD TOUCH OR IPHONE*******
open itunes connect ipod
from the summer page at the bottom
put a check next to manually manage music and video
ok - close itunes
go to : start > my music > itunes
right click on itunes folder and select copy
go to : start > my computer > choose the drive of the ipod > then right click >Paste
take your ipod to a new cpu
connect ipod
go to : start > My Computer > choose the drive for the ipod > find itunes folder > right click on it choose cut
go to : Start > my music
If there is an existing itunes folder in here delete it unless there is music in the library - this will remove the existing library
right click > paste
after you paste it - restart the computer
( download itunes if you have not already )
open itunes and all your music and playlist will be here
if you get a message the the library was created from an old library then follow this step to resolve
http://support.apple.com/kb/ht1451
on Apr 15, 2010 | Computers & Internet
Transfer music from one ipod to another
I recommend you am iPod to iPod/Computer/iTunes Transfer which can transfer your iPod and iPhone music, video, playlist, photos back to computer and iTunes.
If you own more than one iPods, AVCWare iPod to iPod/Computer/iTunes Transfer can simultaneously manage all the iPods in the same interface, you may transfer files among these iPods by drag-and-drop.
Hope it helps!
Apr 12, 2009 | Apple iPod MA446LL/A MP3 Player
IPOD how to move music
hi,
Follow these steps it will help you to copy music to pc
Open iTune
confirm that your iPod is configured to enable disk use. Essentially this means that your new computer will recognize your iPod as a USB device device or a external drive.
Step2
Enable disk use if necessary. Connect your iPod to your old computer and open iTunes. When iTunes has loaded, select your iPod and display "Preferences" in the main window.
Step3
Click on the "Summary" tab and select "Manually Manage Music." You should see a check mark in the box next to "Enable Disk Use." If you don't see it, then just check that box yourself. An alert will display informing you'll now need to manually unmount the iPod as well as ejecting it in iTunes before disconnecting it from the computer.
Step4
Hit "OK" and click "Apply Preferences."
Consolidate Music
Step1
Move all your music to one place to make the transfer easier.
Step2
Navigate to the iTunes Preferences menu. In Windows, this menu is located in the Edit menu, while on a MAC it's simply it's own menu.
Step3
Go to the "Advanced" tab, then "General." Check the box next to "Copy Files to iTunes Music Folder When Adding to Library" and click "OK." iTunes will copy all of your music to the hard drive of your computer. This shouldn't be a problem unless you don't have enough disk space.
Step4
Go to the "Advanced" tab and then "Consolidate Library." Read the message that warns you that this step will place all your music in the iTunes folder and that it can't be reversed. Click "Consolidate."
Determine Storage Capacity
Step1
Make sure there's enough space on your iPod to hold the iTunes music files. In essence, you will be using your iPod as an external storage drive to bring your iTunes library to the new computer. Without a large enough storage capacity, this can't be completed.
Step2
Determine how much space is available by opening iTunes on your old computer and checking the size of the library. Click on "Music" and make note of the amount of space your library takes up. Then connect your iPod, click on it in iTunes and note the amount of free space indicated at the bottom of the pane.
Step3
Calculate to make sure that the amount of available space on your iPod is greater than the space required by the iTunes library. If not, you'll need to free up some space.
Step4
Free up space by clicking on your iPod in the Source pane and then clicking on "Music" or otherwise navigating to the contents of your iPod. Click on any song in the main library window and go to "Edit, then "Select All."
Step5
Be prepared to lose any music not contained by your iTunes library if you haven't been updating automatically, because that music isn't on your computer and will be deleted. However, if you've been updating, there's no need to worry. Press your keyboard's "Delete" button and click "Yes" when you receive the confirmation message.
Copy and Backup
Step1
Exit from iTunes and locate both your iPod and your iTunes folder. On a Mac, the iPod should be visible on the desktop and the folder is "/Users/username/Music." In Windows, the iPod is located in "My Computer" and the folder is "\Documents and Settings\username\My Documents\My Music\." Drag the folder to the iPod and wait patiently as the data transfers.
Step2
Copy your iTunes folder to your iPod. Drag the folder to the iPod and wait patiently as the data transfers. When it's done, eject the iPod from iTunes and disconnect the iPod.
Step3
. Connect your iPod to your new computer and backup any music that's in your new iTunes library. Go to "Preferences," "Advanced" then "Reset." Click "OK." Then navigate to "Advanced," "Consolidate Library" and click "Consolidate."
Step4
Copy your music to your new computer. Locate the Music folder on your new computer--it will have the same name as on the old computer--and drag the iTunes folder from it to the desktop. Find your iPod, double-click to open it and drag the iTunes folder copied from your old computer to the new computer's iTunes folder.
Step5
Wait as the music is copied to the folder and then open iTunes. The music and all of its accompanying information should sync without problem.
Dec 15, 2008 | Apple iPod nano 3rd Generation
Music no longer on ipod
What youve probably done is unselected the playlists that was previously on your ipod so you could sync the new playlists. By doing this the ipod would automatically delete the old songs off your ipod and then sync the new ones. I'm guessing youve managed to upload new songs onto your ipod?
It could also be your using a different computer and by syncing the ipod to a new computer it would automatically delete previous playlists.
I suggest using a programme called sharepod where you dont need to use itunes and is much more simpler. The link is below.
sharepod
Nov 26, 2008 | Audio Players & Recorders
Grays songs in ipod when connected to Computer
You need to set your iPod to update manually, instead of syncing automatically when you plug it into the computer.
To do this, plug your iPod into your computer, and on the iPod info screen that pops up in iTunes when your iPod is connected, click "Manually Manage Files."
You'll now have to click and drag your songs from your library to your iPod, but now you can also play songs on your computer directly from your iPod and delete songs from your library without deleting them from your iPod at the same time.
Hope this helped!
Sep 05, 2008 | Apple iPod MA446LL/A MP3 Player
Connecting ipod to a new laptop
You can actually (or could have) transfer the songs from your
Laptop & iPod by using you iPod like a removable
Hard Disk Drive
Here is the Apple sanctioned method:
Note: While you can use the Transfer Purchase From iPod option under the File menu to copy iTunes Store purchases from the iPod to another computer you can't transfer songs from other sources from the iPod library to iTunes
So you'll need to follow the steps below to use iPod as a hard disk to transfer music files from one computer to another. This process will require the use of iTunes 7 on all computers. Any computers running iTunes 6 or earlier will need to be updated to follow these steps.
Once you have the files transferred, you'll need to authorize any iTunes Store content. If you won't be using your old computer, you'll want to deauthorize it.
Important: Windows operating systems don't recognize Mac OS-formatted disks (HFS or HFS Plus formats), so you can't use a Mac-formatted iPod to move your music to a Windows PC.
Switch the iPod to manual update and enable disk use The first thing you need to do is make sure have configured your iPod to enable disk use. To do this:
  1. Open iTunes on your old computer.
  2. Connect your iPod to your old computer and wait for it to appear in iTunes.
  3. Select your iPod in the Source pane under the Devices section to display your iPod preferences in the main library window.
  4. Click the Summary tab in the main iTunes window.
  5. Click the Manually manage music button. Changing from automatic updating to manual puts a check mark by Enable disk use. A message says:
"Disabling automatic update requires manually unmounting the iPod before each disconnect."
If you need to copy from old computer:
Copy iTunes folder to iPod To copy all your music files (including the library file that holds all your playlists and other settings) to your iPod:
  1. Quit iTunes.
  2. Locate your iPod:
    Mac OS X: On the desktop
    Windows: In My Computer
  3. Locate your iTunes folder:
    Mac OS X: /Users/username/Music
    Windows: \Documents and Settings\username\My Documents\My Music\
  4. Drag the iTunes folder to the iPod. This can take a while if you have a lot of songs.
OR
  • When the copy completes open iTunes.
  • Click on the iPod in the Source pane
  • Click the Eject button in the lower right corner of the iTunes window.
  • Disconnect the iPod from the computer when the "Do not disconnect" message no longer appears on the iPod screen.
Now:
Copy music to new computer To copy all your music files (including the library file that holds all your playlists and other settings) to your new computer:
  1. Locate your Music folder (Mac OS X) or your My Music folder (Windows) on your new computer:
  2. Drag the iTunes folder in this location out to the desktop. 300173_10.gifFrom the My Music folder to the Desktop on your new PC
  • Locate the iPod on the new computer:
  • Mac OS X: On the desktop.
  • Windows: In My Computer.
  • Double-click on the iPod to open it.
  • Drag the iTunes folder from the iPod to the Music folder (Mac OS X) or My Music Folder (Windows) on your new computer. This can take a while if you have a lot of songs.
  • Open iTunes
    There you go. All your music, playlists, and other information like play counts and ratings have all been moved from your old computer to your new one.
If that doesn't cover it fully..... wow!
Feb 12, 2008 | Apple iPod nano
Keep getting an error saying "The iPOD cannot be synced. An unknown error occurred [-50]."
How To Fix The "Cannot Be Synced" -42 Error For 2nd Generation Nano?
Follow these simple steps (cannot be easier):
1.Plug in the ipod
2.Go to My Computer
3.Right Click the Ipod (F:)
4.Go to Properties
5.Click the "Tools" Tab
6.Click "Check Now" under Error Checking
7.After it's finished start itunes
8.Update Ipod once it shows up on itunes
9.It Works!
You're Welcome =]
Jan 19, 2008 | Apple iPod MA446LL/A MP3 Player
Not synching correctly with itunes music folder
I know another way you could try formatting which may fix this problem. Restoreing just restores all the setting to your iPod yes it shoudl format as well but it may not due to an error or something.
To do try it another way follow these steps, first click on "Start" - "My Computer" look for you iPod when it's connect usually called "Removable Disk" once you've found it "Right-click" on it then click on "Format", once format is complete disconnect, then connect it again then run "Update" for your iPod and for iTunes, once you've done that have another attempt.
Good luck. Hope my solution was helpful in some way. Further problems leave a comment and i will get back to you.
Nov 11, 2007 | Apple iPod nano
Apple iPod  shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A) Logo
596 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Parshiv Luthra
Marvin
Marvin
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
