Remove the batteries and clean the battery contacts inside the camera
with a soft cloth (a heavy buildup on the contacts may require cleaning
with a fine wire brush, steel wool, or sandpaper). Remove any residue
that the cleaning leaves in the camera, and then reinstall the
batteries. This clears most power-on problems, but if yours persists,
check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
what it said
Chances are that the problem is corroded battery contacts inside the camera. Remove the batteries and clean the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue that's in the camera from the cleaning, then reinstall your batteries. Hopefully this will cure the problem and get the camera back up and working the way it should. If that doesn't do the trick, you might want to try your luck with the Kodak Troubleshooting guide at:http://www.kodak.com/eknec/PageQuerier.j...
