Question about iLO (2 GB) MP3 Player
"storage device policies" key is missing from my registry...!!!
My mp3 player says that it is write protected when i plug it in ,.... so i was directed to change the  HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control \StorageDevicePolicies
value from 1 to 0  ....
when it looked it up i saw that inside the control folder the "storagedevicepolicies " is missing... my comp is normal and is not behaving abnormal.....
plz help.... thanks in advance..
  • 4 more comments
  • robingabz
    robingabz Jan 30, 2013
    my flash drive has been write protected. only a storage device policies to locate to complete the removal of write protected was lost in my registry
  • yasir
    yasir Nov 19, 2013
    man got the same prbl policies are missing
  • GONNABATHULA VAISHNO CHAITANYA
    oh i too got same prob!
  • arnav raj
    arnav raj Apr 05, 2014
    yes i also had same problem..
  • HAYETSADEG
    HAYETSADEG Jun 07, 2014
    REPARE MY USB
  • kushagra khare
    kushagra khare Jan 31, 2016
    plz give the solution for this...
My mp3 player says that it is write protected when i plug it in ,.... so i was directed to change the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control \StorageDevicePolicies value from 1 to 0 .... when it looked it up i saw that inside the control folder the "storagedevicepolicies " is missing... my comp is normal and is not behaving abnormal..... plz help.... thanks in advance..
Posted on Mar 17, 2010
    New Friend:
Storagedevicepolicies is access denied, how can i access it?
Posted on Jul 30, 2010
    New Friend:
You need creat it yourself!
The type of storagedevicepolicies is first (K).
And then you need creat dword WriteProtect with value 00000001
Posted on Apr 21, 2010
    New Friend:
I've made "storagedevicepolicies"key bt still the disk is write portected..plz help...??
Posted on Aug 29, 2011
  • ralf
    ralf Sep 02, 2014
    whats is a serial number of Storage Device Policies.zip?
    New Friend:
There is nothing about "storage device polices" on my computer'
Posted on Nov 14, 2012
If the key doesn't exist you can just create it.
go through the below link
http://www.helpwithwindows.com/WindowsXP/tune-28.html
Posted on Apr 01, 2009
  • yo yo honey Jul 28, 2013
    you the son of a doggy show me the screen shot you are fraud. you are miss guiding people
  • Jael Jefina J
    Jael Jefina J Feb 09, 2016
    Thank You so much.It works!
    New Friend:
Mi computador no tiene "StorageDevicePolicies" como lo consigo?
Posted on Oct 05, 2011
    New Friend:
In my pc no
What do do?
Posted on Mar 19, 2014
SOURCE:
I can't remove write protection from ur suggestion....in registry editor i hv no storage device policy
You can remove write protection from your drive using the below method:
Open start menu, in the search bar type regedit and press enter. This will open the registry editor.
Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note:
If the registry key Storage Device Policies does not exist, you will need to create it manually.
Double click the key Write Protect in the right window and set the value to 0 in the Value
Data Box and press OK button
Restart your computer and try copying files into your USB drives.
or you might
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope it helps
Apr 12, 2012 | Computers & Internet
How to remove the write protection om my usb. I tried to open HKEY_ Local_ Machine and i cant see the storage device policies. Can u just tell me how to solve this problem
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Apr 20, 2011 | Computers & Internet
My USB DT200 128 GB Kingston has got a write protected problem even there is no write protection from my side please help me
also
- Click permissions
hope this helps
Mar 21, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I want to remove the write protection on my usb flash
also
- Click permissions
hope this helps don
Mar 13, 2011 | Computers & Internet
I cant delete my files on my flash drive everytime i click it the WRITE PROTECTED always prompt! that i need to unlock it
I found this on another site, I tried it down to finding the usb device, you do the remaining part at your own risk, I'm very cautious about editing my registry.
Gary
# # Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
Read more: http://wiki.answers.com/Q/How_do_you_remove_write_protected_error_for_the_flash_drive#ixzz1EnkYwY1p
Feb 23, 2011 | Home
My datatraveler 2g is write protected
also
- Click permissions
hope this helps
don
Feb 21, 2011 | Computers & Internet
How to remove write protected
if you mean a usb drive
hope this helps
don't forget to vote
Feb 11, 2011 | Samsung Ls6410 Samsung Arm11 S3c6410 Board...
Reporting 0 bytes in disk part
Jan 14, 2011 | Kingston Technologies 512MB DataTraveler I...
Storage device policies is missing in HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
Oct 10, 2010 | iLO (2 GB) MP3 Player
How to remove the write-protection in my FLASH DRIVE?
  1. Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "use device" or "driverdesc" to open usb mass storage device. right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
  2. Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
Jun 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
iLO (2 GB) MP3 Player Logo
77,647 people viewed this question
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Rick
Rick
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
