Question about Samsung BP59-00016A Remote Control
How Do I Progam My Remote To My Tv
I Need To Get It To Work On My New Tv for Cable And Dvd Player And tv
I need the code for silvania dvd, control remote samsung
Posted on Nov 09, 2008
SOURCE:
I need the codes to program a magnavox tv with built in dvd player with this remote
Your universal remote should have a code search feature that allows you to search through its library to find a code or codes that will work. You might need two separate codes for the TV and the DVD player.
Jun 19, 2015 | Audiovox RCR314WR Universal Remote Control...
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
How to install a video machine if I don't have the tv remote?
I'm assuming by "video machine" you mean some kind of DVD player or Blu-ray player or something of the like. I will explain how to install a DVD player. There are two major cables: one sends the video to the TV and the other sends power to the DVD player. The power cord plugs into the wall with the other end attached to the DVD player. The video cable plugs into the TV. If you have an HD television, the video cable will have a male HDMI piece that plugs into the TV while the other end of the cable plugs into the DVD player. If you don't have an HDTV, then you will use an RCA cable which has three prongs: Yellow, White, and Red. These three colored male prongs plugs into the corresponding color coded holes in the TV. The other end goes into the DVD player. When you have everything plugged in correctly and the DVD player is on, all you have to do now is change the TV input. You will need the TV remote that came with your TV, or a universal remote that has been configured to work with your TV. Find a button on your remote that reads "Source" or "Input". This will cycle through the sources and inputs of your TV including AUX, VIDEO1, VIDEO2, etc. Keep going until you are on the correct input to see the DVD player menu. Good luck!
Jul 01, 2011 | Philips 42PFL5332D 42 in. LCD Television
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
I have lost my remote for my sansui tvm1916a and i want to still use my dvd player, how do i change the imput? pushing the two buttons at once brings up a menu but input isnt an option
If your DVD player is connected to your TV with a SCART cable, your TV should switch to DVD input when you insert a DVD and press' Play'. If you are connected with a standard co-axial aerial cable (fly lead) this wont work and you will need to buy a SCART cable (or new remote) if you wish to continue using your DVD player with this TV.
Hope this helps,
Regards,
BElectric
Nov 16, 2010 | Sansui TVM1316 13" TV
My polaroid tv remote isnt working
Get a new remote or try it again with new batteries.
Aug 17, 2017 | Polaroid 1720-7 Remote Control
Durabrand tv won't work with vcr/dvd player
I was given a dwt1905 tv for my kids without a remote so they would have a tv for there dvd player and games plus cable comes to find out I was not able to control anything I listed above with my cable remote because there is no codes you have to buy the remote from the company I called 3# before I was able to find out anything about a remote the contacted # is 1-800-242-7158 and the cost was 19.99 for a new remote that is the only way you will be able to work the tv with dvd player,game systems and cable I hope this helps........ good luck
Apr 17, 2008 | Durabrand DWT1905 TV
Need Emerson Remote for color TV with DVD Player
You need the remote codes for your cable remote? (if so who is your provider?)
or you need to buy a remote control for the tv?
Nov 19, 2007 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Having trouble hooking up my DVD player
Try looking on your tv's menu for "input" or "input select". This should allow you to switch to your front AV inputs. If that doesn't work hook into the coaxial cable in the back of the set (the one for your cable or satellite input. Plug the cable from the output or to tv side of your reciever into the input of the dvd player and run another lenghth of coaxial cable from the output of the dvd player to the coaxial input where your satellite or cable was plugged into the back of your set. When you want to watch a DVD just turn on the DVD player and the picture should come up. When you turn it off your satellite or cable should come right back.
Feb 20, 2007 | Durabrand DWT1905 TV
LASONIC DVD PLAYER NOT WORKING WITH COMCAST BOX OR SOYO TV
you have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
Mar 05, 2017 | Lasonic DVDP | DVD-7050 5.1CH
Samsung BP59-00016A Remote Control Logo
710 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
