Question about HP Officejet 5510 All-In-One Thermal Printer
Out of paper
My copier will not feed papers thru the bottom feeder. It tries to then says I am out of paper. I also can not fax now either. I have enough paper and nothing was jammed. Help!
  • kenpamela Aug 23, 2007
    tried but he rollers aren't moving. think its mechanical problem. Thanks
Printers and copiers generally pull paper in the same way. First there's something that pushes the paper up to a roller, then the roller spins and pulls in a page. The most common problem I've seen (and you may be able to watch this on your printer depending on how the paper is stored) is that the roller that pulls the paper gets dirty or just dries out over time and can't get enough friction to pull a piece of paper. The solution to this problem (though it may be temporary) is to clean the roller. You can do this using Isopropyl Alcohol and a lint free cloth (coffee filter works well). Or you can roll the roller over the sticky side of clear packing tape (I read this recently but haven't tried it). Let me know if this works or not.
Posted on Aug 22, 2007
The paper keeps jamming during feed I have changed it but it still jams, I think there is a fault with the feed section at the bottom but I cant find a manual that shows technical details for repairs so I...
Did you replace paper feeder with new one? Most paper feeder problem are rubber at paper pick up roller (bottom side) and small spring at bottom paper pick up roller. Check for "something" slip at paper feeder and lubrication at paper feeder mechanic.
Feb 02, 2010 | Epson Office Equipment & Supplies
Paper won't feed into printer
I have taken a piece of cardboard, like the ones you get with a new shirt, size it to 8.5 x 11, and tell the printer to print a test page. hand feed the cardboard thru, and most times it will clean out the residual paper pieces stuck in the internal rollers. I have used this method several times and was successful 99% of the time. It isn't rocket science, but It may work. You will probably have to push the cardboard thru, but do not force it to much. It will not go thru easily on its own. Just a suggestion.
Jun 17, 2009 | Epson Stylus CX3810 All-In-One InkJet...
im having the same problem was working fine then quit feeding
Mar 31, 2009 | Minolta EP4000/5000 CS/PRO Copier
Feeding paper for scanning/faxing - e-studio350
If u put stack of papers on the feeder, but it didnt pick well or paper jam occur, u need to check the feeder unit. Normally roller is wear and tear, foreign materials inside the feeder and etc will cause paper jam on feeder.
Mar 19, 2009 | Toshiba e-Studio 350 Copier
Fax double feeds sheets
This may occur if:
-the paper is too thick or too thin
-the roller mechanism is not properly aligned or has worn out
-the sheets of paper stick together
things you can try:
-unload the paper in the main tray and bend the stack of paper to loosen it up. Reload the paper to the main tray
Hope this helps!
Feb 17, 2009 | HP 1240 Plain Paper Inkjet Fax
Paper does not feed
Try feeding a post card or a different kind of paper thru the feeder tray, make sure that it is going in smoothly.
Try something innovative for checking out those rollers
Feb 08, 2009 | Dell 924 All-in-One InkJet Printer
Paper feeder
clean the rubber roller with alcohol this roller gets dirty all the time...this feeds the trying to upload my guide you..
Feb 09, 2008 | Canon S520 InkJet Photo Printer
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
HP Officejet 5510 All-In-One Thermal Printer Logo
191 people viewed this question
Ben Johnson
