Garden Logo
Garry Taylor Posted on Mar 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No start; recoil starter hard to pull.
Instead of making compression when the starter is pulled, this hedge trimmer creates a vacuum and is very difficult to pull. The cylinder frees up when the spark plug is removed. Is the problem created by a bad reed valve? thanks
  • 2 more comments
  • aar6 Mar 24, 2009
    Same problem - exactly as described by gtaylor108's only my machine is a strimmer.
  • Garry Taylor Apr 11, 2009
    this is a kawasaki KTH600S 2 cycle hedge trimmer. There is no crankcase drain, so I guess I'll have to disassemble the engine to check for fuel, right? thanks
  • Anonymous May 11, 2010
    remove the spark plug and inspect the cylinder walls for scratches and such. try adding a teaspoon of oil(no gas) to the cylinder thru the plug hole, replace the plug and pull a few times. tell me if anything is different, compression and were the oil goes. if you can still see it in the top or if it disappears. this can tell me what exactly the piston is doing. and if the fuel mixture screws are turned too high it can cause this problem also.
    what brand is this? is the exhaust screens clean and is the muffler plugged? need a little more info.
Anonymous
Level 2:
Sniper:
  • Expert 87 Answers
  • Posted on Apr 10, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
87
Questions
Helped
130568
Points
275
No. Sounds like the crankcase is filled with fuel.
  • Anonymous Apr 12, 2009
    Dis-assembly is not necessary. Remove the muffler and spark plug, turn unit so the spark plug hole faces down and let gravity take it's course. Unless this is an old unit, there is no reed valve. If the problem persists inspect the piston, rings and cylinder by looking into the exhaust port. If vertical scoring is visible a top end rebuild may be necessary.
My br600 backpack blower is almost impossible to pull
Likely the recoil starter is kaput. Removing spark plug so there's no compression, then pull starter. If it's still hard pull, remove recoil starter assembly and spin engine by hand. If engine spins freely, replace recoil start.
Dec 04, 2019 • Garden
I have been using the trimmer and now the pull start does not catch on the crank shaft. how do I fix this? bought the trimmer less than a year ago
Many trimmers have the pull start at the very top of the engine. Makes it easy to take off and see what's preventing the recoil starter from catching. BUT lately most trimmers have the starter between the Shaft and the engine THESE are tough to disassemble to get to the recoil starter.
Aug 27, 2015 • Garden
Why is my Stihl HS61 not firing up?
Try cleaning out the carburettor and make sure u are using new fuel and the correct mixture
Replacing pull start on 223l trimmer
Its pawl has either come off the recoil spring or the recoil spring has broken. There are videos on youtube showng you how to repair this fault.
Cant remove pull rope housing from homelite gas hedge trimmer
there is a screw in the hole of the clutch housing bell torx bit i think its a #20
Jun 04, 2012 • Garden
Pull the chord and it just uncoils and recoils, not turning anything to start the motor.
You might have a broken latch inside the coil assy or maybe just gummed up or stuck. take it apart and look into it further. Go to this website and they have a video about restringing starter coils this will aide you in your disassembly. smalleng.com
Only used my trimmer 5 times since I had, trimmed my hedges 2 times last year & twice this year. After done doing my hedges, I put on my weed trimmer when finished & holding my trimmer in idle it...
Some disassembly may be required to get to the starter/recoil unit to fix this. The unit has Torx head fasteners and some level of mechanical skill is involved. Check your warranty?
1helpful
Husqvarna 125r wont start. has spark, compression, air filter and exhust checked. could it be the timing? if so how do you adjust?
Pull spark plug out. Pull cover from recoil starter. Pull recoil starter. Inspect flywheel mag's for cleanliness. Then turn engine over untill piston is topped out. Your manets and pick up should be lined up to eachother at this point. If they are not, pull nut and or bolts from flywheel and remove to check for damaged key-way or woodruff key that aligns flywheel to crank. That is the only timing.
2helpful
I have this Toro trimmer/edger.Can't pull the starter cord
you must take apart the cord recoil and rewind the pull string,inspect string make sure its the same thickness through out if not replace it, not too hard i believe you can do it.
I just replaced the recoil \\starter rope on my blower
Are you sure you have the right length rope??? If you are sure the rope length is correct you may have wound the recoil spring too tight causing it to run out of travel. You want the recoil spring just tight enough to pull the rope all the way in.
Wayne
Top Garden Experts
Jay Finke
Jay Finke
john h
