Belkin 2-port KVM Switch
Problem for Belkin (F1DK102U) (f1dk102uuk) 2-port KVM Switch
Can's switch without it switching back to first PC
By MSBoy on Aug 21, 2007
Cannot switch between pc's. Will work fine on one pc but when I switch to the other it automatically switches itself back to 1st pc.
Same Problem
Feb 25, 2009
-   same here. switch worked for about 3 days, then it started to switch back. strange is that one side of the switch works perfect on both PCs, but when i try to switch to the other side of the switch, no matter which computer is connected to it, its switched immidiately back....-   Guest
Feb 03, 2009
-   I have found temporary solution, I pull both the USB cables on my KVM for a few seconds, when they are both pulled I leave them unplugged for 5 seconds and then plug them back in and now the switch is happy again until the next time. -   Guest
Jun 25, 2008
-   same problem, work fine for a week...
I try rebooting one computer, than the other... no result
running XP on one an Vista on the other
a real pain !
-   Guest
Nov 17, 2007
-   Got the same problem. My laptop has ati mobility radeon and desktop uses Nvidia card. Dunno if that has somethin' do to with anything?-   Guest
Solution #1
posted on Aug 23, 2007
Somewhat Helpful)
DJYar
Rank: Wiz
Rating: 84%, 69 votes
Sadly, it is probably the KVM as this particular model has a string of failures and is only rated 2 out of 5 stars on Amazon due to poor performance. :(
http://www.amazon.com/Belkin-F1DK102U-2-...
What I would do first is plug in Computer 2 directly to the monitor, keyboard and mouse with no KVM. If those work fine, it is probably not a computer issue; if you don't get video here, then it is a seperate issue with that PC.
If Computer 2 is working, plug both computers into the KVM but switch the cables (plug Computer 1 into the KVM using Computer 2's cables). If Computer 2 shows up and can't switch to Computer 1, then it is the KVM messing up.
Was this helpful?
Yes
No
Popular Solutions for Belkin 2-port KVM Switch
Questions and Unsolved Problems for Belkin 2-port KVM Switch
Do you recommend Belkin (F1DK102U) (f1dk102uuk) 2-port KVM Switch?
Answer
Answer
Same problem but with a cheap kvm.It does not recognize the mouse until you unplug then plug it back... (More)
Answer
I added a wireless mouse and keyboard to my desktop. How can I connect to my laptop?
Answer
Flip Switch is not lighting up on Belkin Switch2 2-Port DVI KVM (F1DG102D) with remote even with... (More)
Answer
I have new computer and KVM switch works (scroll lock) from new computer to old one. When I try to... (More)
Answer
The monitor resolution is lower when docked laptop hooked on via the KVM switch. ControlPanel's... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Belkin 2-port KVM Switch:
Top KVM Switch Experts
Rank: Guru Guru
Solutions: 14921
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more KVM Switch Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
