Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Pioneer SD-P40 I have the pioneer rear projection Sd-P40 that has a cloudy picture all of a sudden. Any ideas on what the problem is or how to fix it?
Remove front cloth cover (over speakers) Then unscrew main plastic front screen and clean lens (x3) and large mirror!
Posted on Mar 15, 2008
    Genius:
  • 1,153 Answers
Check to see if Q118 is shorted on video/defl pc
Posted on Aug 22, 2007
SOURCE:
Pioneer SD-533HD5 53 in. Rear Projection HDTV Television - Need Manual ....
ManualsLib has the manual for the SD-533HD5 here: https://www.manualslib.com/manual/384249/Pioneer-Sd-643hd5.html . (The manual covers two models.) Once you modify the picture parameters (starting from STD, REF THEATER, GAME), these are stored as the User mode. If you press Menu when done changing the parameters, that input should maintain the User settings for the last setting until you change the Picture type. If you modified the parameters for STD and then return to that input and change the Picture to GAME, any modifications to the GAME picture parameters will become the new User Mode. See page 50 of the manual for the details: https://www.manualslib.com/manual/384249/Pioneer-Sd-643hd5.html?page=50#manual .
I hope this helps.
May 27, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-P40
There may be high current in the board as one of the component may be weak or out of order , please check the voltage out of the at the fuse holder , Please change the board ASAP..... or call
For Service & Support Please Contact Us At: 310397382support-icon_small.jpg 1925 E. Dominguez St.
Long Beach, CA 90810
Call (800) 421-1404
Or contact us by e-mail.
Hours of operation:
24 hours a day for most services. Hours for product service, product operation and parts inquires:
Mon. - Fri. 9:00 a.m. - 7:30 p.m. Eastern (all product inquiries).
Sat. - Sun. 11:00 a.m. - 7:30 p.m. Eastern (plasma, DVD recorder, navigation inquiries only).
May 15, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer 52" projection TV, SD-533HDS,
It is likely that the CRT's (picture tubes or bulbs) are weak. It is a major job to change and all three should be changed to make the picture like new. However, it is not costwise to repair this old of a TV even if you can get the tubes. I estimate the cost of each tube is at least $200 each. I would call Pioneer and give them your model number and see if they are available. Only a trained technician should change the tubes because it requires a lot of time and setting up of the tubes and other things.
Jun 04, 2011 | Pioneer SD-533HD5 53" Rear Projection HDTV
Sd-p40
Have you tried to do set the convergence with a pattern on the screen? Some tv's have the pattern built right into the setup. Others do it auto just by pushing a button. Adjusting the pattern on one side of the screen may affect the other side, depending on how far out of whack it is.
Magnets (speakers) near by will play havoc with convergence.
Peter
Aug 04, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer tv
This is a common problem with pioneers. try resoldering the vertical output Ic that should remedy the problem. if not the vertical IC may be faulty
May 27, 2008 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer SD 5575 - Needs to wam up
best thing i can suggest is buying a can of freeze from radio shack and spraying each ic/transistor till the problem appears again.
Nov 11, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
High voltage
Why? Please give accurate symptoms and I probably can help...T.
Oct 24, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P40
Check your hori out put transistor if shorted replace NTE2973, this should be output number.if you need any more help let me know!
Oct 12, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
197 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
