Question about Epson Stylus Photo 830 InkJet Printer
Green and red lihts flashing
When I turn on my printer it seems to start up as normal but then as the cartridges go in to position the green light and the red one next to it flash on and off .I have re installed my drivers and even downloaded new ones from epson thinking it may be that but no so.....can you help me kindest regards makums
  • alexruba Mar 06, 2008
    try to change new ink and stop for 5 min. then try back.................but still the same problem acc
  • 353 Answers
Your waste ink pad counter has reached it's limit and you must change the waste ink pads and reset the counter before the printer will work again. This requires the printer to be dismantled! Sell it on e-bay for what you can get!
Posted on Jan 31, 2009
  • Gerry Millward
    Gerry Millward Jan 31, 2009
    Oh - I should have said you can overcome this problem temporarily by using the SSC utility - download from
    http://www.ssclg.com/epsone.shtml
    and reset the Protection Counter. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens.
SOURCE:
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Hi I have just put in ink cartridges and the reg light check print cartridges keeps flashing is there anyone there to help me
    Hello and Welcome to FixYa!
    Sir/Ma'am If the Check Print Cartridge message is shown and Red Light Flashing then it means that Either ink Cartridge is not installed properly or the function for detecting the ink level is disabled. For it Make sure that you install ink cartridges at correct position as indicated by the label on the print head holder. Press push mark until ink cartridge click into the place.
    If you are sure then you have installed ink cartridge properly then try following to stop the flashing of red Light.
    1. Lift the lid to the printer (cartridges are on the right side.)
    2. Turn the printer off, then power it on again.
    3. Unplug the power cable from the back of the printer when the grinding noise starts.
    4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct.)
    5. Take out the cartridges and close the top cover.
    6. Reconnect the power cord. The power and the resume lights (green and red) should be on.
    7. Open the top cover, reinstall the cartridges, and close the top cover.
    Now Turn On the printer, Mostly this issue is resolved by this,
    But if still you get the message and red light still flash then surely its an issue of Ink Cartridge, your ink Cartridge is defective, You need to change the ink cartridge, Your problem will be solved.
    I hope this solution helps you.Don't hesitate to let me know if you still have some confusion in your mind.
    Please Rate my solution as "Maximum Stars" and then give your Words of Appreciation as a Feedback.
    Thank you Sir/Ma'am for taking my service and fir using FixYa
    Concerned: Muhammad Uzair Team : FixYa
    Nov 05, 2011 | HP DeskJet 920c InkJet Printer
    Epson Stylus PHOTO R220 red lights keep flashing
    I hope this will help you :)
    * Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
    * RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
    * RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
    * RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
    * RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
    * RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
    * Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
    Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
    The top light of the two is flashing green/red back and forth very fast and the light on the bottom is a solid red. how do I fix this so that way it will work normally
    The steady lower light indicates the unit needs a new toner cartridge, MLT-D108S. Did you previously see this light blinking or blinking rapidly? (Those indicate the toner being low.) Replace the cartridge and check for any other error lights. Turn off the machine and let it cool. Then open the front cover and pull the old toner cartridge. Open the package with the new cartridge, remove the packing tape and paper that protects the cartridge and gently shake it (avoid touching the blue or green parts of the OPC drum). Press the cartridge into the slot until it is fully seated. Close the front cover.
    The green/red blinking power light is not one I'm seen before. The printer indicates a non-toner failure (open cover, no paper, LSU failure, etc.) with a steady red light.
    Aug 02, 2010 | Samsung ML-2240 Laser Printer
    Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
    Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
    May 21, 2010 | Epson Stylus C46 InkJet Printer
    My Epson is printing pages in code and will not stop and the green light is blinking and the red is staying on. We put in new ink cartridges today.
    zark4, The green light flashing means you have print jobs waiting to be printed. Don't Turn Off The Printer When The Green Light Is Flashing ! If you have paper in the printer, the red light means you have an empty ink cartridge. Because both things are happening at the same time, here's what you need to do. First click start. Click printers and faxes. Double left click the Epson C-60 Icon. Left click Printer and click Cancel all documents and click yes, then exit. Remove and reinsert your new ink cartridges to make sure they are seated correctly. After you have done this and the printer finishes the automatic charging of the ink cartridges, the lights should be back to normal. Green light on.
    Oct 22, 2009 | Epson Stylus C60 InkJet Printer
    Lights flashing, printer won't print as a result of a paper jam
    Hi Girlemom. Just had the same problem here. Lift up the lid and slide the ink cartridges to the left. If they are stuck in the middle, this will prevent the printer from starting properly. Then, unplug it, plug back in, and turn on. It should restart normally.
    May 08, 2009 | HP DeskJet 5550 InkJet Printer
    Epson C66 red light stays on for ink
    The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
    it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
    Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
    Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
    Epson C48 red and green lights flashing alternately
    Only Solution is Re-burn printer firmware.
    Mahesh DG, Pune
    Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
    HP Photosmart 7450 stuck cartridge
    not a solution, my paper feeds past the point where printer5.gif would normally begin. Then flashing light changes from green to red and print operation stops. Printer cartridge1.gif appears to be stuck in far right area of cartridge track.
    Replaced drivers as above and still have the same problem.
    Mine started after I had replaced the color cartridge. Mailed the old one to HP already so can't put in old cartridge.
    If I unplug printer from computer, I get same results. Does the driver software install in the printer?
    Geo
    Mar 28, 2008 | HP Photosmart 7450 InkJet Printer
    Epson Stylus Photo 830 InkJet Printer Logo
    240 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Inky Fingers
    Inky Fingers
    Clive
    Clive
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
