Question about Panasonic KX-T7453 Corded Phone
Using the record button
My boss told me i could record conversations on my phone. while on the line, i pressed the record button, and at the end of the conversation, i hung up the phone. now i dont know how to listen to the conversation i think i recorded. please help
    Novelist:
  • 201 Answers
This is a phone system phone. If you can record conversations it would be a feature of your voice mail on the system (the phone itself cannot do this). If it all worked, you should have the recording in your voice mail box. It may be in with recorded messages or there could be a separate location. Example: Press 1 to hear your messages, press 2 to hear your recordings, press 3 to change your password, etc...
Posted on Aug 22, 2007
SOURCE:
Is it possible to connect my Boss multiple effects ME-25 to my BR-800 recorder. If so how, and can it then be linked to an amp (again how)
Hello Alan.
Yes you can connect your ME-25 to the BR-800, there is no risk to damage any. it is simple, you may use both outputs of the pedal and send them via two normal 1/4 plug guitar cables to two of the channels of the DR (i.e. ch 1 & 2) to avoid an initial saturation of the recording preamp, set the input sens pot at minimum and the sliders very close to minimum as you try playing and looking the levels on the display and adjunting them to the optimum.
To connect the DR to an amp you should use the pair of RCA jacks named LINE OUT (R & L) depending of the amp you have there might be the need for a conversion cable or plug adapters. The out put of the DR is stereo, and if you want to use a guitar amp, commonly mono, you should mix both channels to send them to one input, this can be done by putting two 10 kohms resistors in series with each channel output and joining the other end to the input.
Good luck and best wishes
Nov 20, 2014 | Roland Boss BR-800 Digital Recorder
As the receptionist I take calls and then transfer them to the person the caller disires to speak with. For example, if I am on a call and the person I am speaking with would like to speak with my boss, I...
A couple of things, but first. When you TRANSFER a call to your boss using the transfer button, he key to getting rid of the call is to hang up. But that's not your problem. When we install voice mail systems, we reserve 3 buttons; one for VM TRANSFER, one for 2 WAY TRANSFER, and one for VM RECORD. It's easier to link you to the OM of a TDA system than explain it, so here's the link http://www.public.carl.airpost.net/Pana/TDA/200_TDA_OM_06-121.pdf
Pdf page 170 will give you the table for setting up your 94,91 and 90 codes for the above features.
Basically, you press PROGRAM, the button, and dial, for example, 94 500 SAVE to store the VMT . You use it by pressing that button while you on the call (no hold) and either dial your boss' extension or press his DSS button. If you use the 2-way transfer, you can actually put his number under one button and carry on a 2-way conversation with the outside party. Kind of like you would do with the old 'pink slip' messages.
Carl
Mar 16, 2011 | Panasonic KX-T7630 Corded Phone
All the calls we recieve in the office go through me. I greet the caller and then transfer them to the person they want to speak with. When I transfer a call, let's say to my boss, my boss will pick up...
Haven't you solved this yet? When we install a system, we reserve THREE buttons for voice mail functions. One is VM Transfer, one is 2 Way Transfer, and one is VM Record. In order you pick 3 buttons press PROGRAM one of the buttons and dial in order 94 500 STORE 01 500 STORE and 90 500 STORE, assuming your voice mail is on the default extension of 500. To send a call to someone's voice mail you press VMT and his DSS button or dial his extension and hang up. The outside party will get all of his greeting. If you want to prompt the user, like you would if you were taking a pink slip, you press 2W Transfer and his extension and carry on a conversation with the outside party. The message records in their mailbox as a new message. If you want to silently record into your OWN box, you press the VM Record button and your conversation is recorded into your own box as a new or old message, depending on how the system is set up.
There are other variations, including a single button transfer into someone's mailbox and some other features that are covered in you telephone sytsem OM or User's manual under Customizing your phone.
Carl
I bought a used BR 532 Boss recorder - can't get a
I get an unformatted come on the screen on my Boss BR 532 when I swith on, and also when pressing record, although I can get drum machine to work and guitar go through it ok but no recording Hmmmm Erggg
Nov 16, 2009 | Boss Micro BR Digital Recorder
Random beeping on other end
What type of system is this? Also do you have office recording software which records the conversation. This will beep to allow the person to realize they are being recorded.
Jul 29, 2009 | Lands Phones
CALL RECORDING
yu can record yur conversation by pressing the black button on the right side of yur phone,,but during the process,yu cant be able to hear the person on the other line.
Apr 12, 2009 | Motorola Mobility L7I Cellular Phone
I'm using a Radio Shack telephone handset recording control that you plug one end into the phone and the other two ends into the handset and the recorder's mike jack. (I'm using an Olympus DS330). Trouble...
I use one, too, and it took me a minute to set up right. You need to plug one end into the digital in on your pc, or your recorder, and take the phone line from your phone, put it into the slot on the control, then take the phone jack from the control into your phone. Now, this is for a corded phone, but i cannot imagine it being any different for a cordless, as it, too, plugs into a wall somewhere.
Since I record directly to my pc, using WavePad, i don't know anything about the play button on the controller. I read that it would be used, somehow, to play the recording on the actual tape, but i realy don't know.
Hope that helps.
Jan 05, 2009 | Olympus WS-100 Digital Voice Recorder
Ringing on my phone when boss is on the line
You should turn off the "Hold Reminder" under phone settings. Get to this by pressing the silver enter button and scrolling down.
Dec 06, 2007 | AT&T 984 Corded Phone (att00148)
Not working
Astonishingly, assignment of announcement to phone line is not documented in the user manual. Tech support was totally worthless concerning this issue. I had to discover it by trial and error. To assign an announcement to a specific phone line do the following:
1) Record your announcement message for a, b, c, ao, etc. as documented
2) Press program
3) Keep pressing the feature button until ANNC appear at the bottom of screen, line 1 appears at the top, and the letter 'a' appears in the middle.
4) Choose the announcement to be assigned to Line 1 by pressing the select button
5) Press the feature button again. Line 2 appears in the display.
6) Repeat step 4 to select the announcement to be assigned to Line 2.
7) Press program button, or take phone off-hook to end the sequence.
Shame on AT&T for such shoddy documentation, and lack of support for their products!
Nov 09, 2007 | Lucent 1872 Corded Phone
Panasonic KX-T7453 Corded Phone Logo
235 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
