Question about Dell Axim X30 Pocket PC
Screen frozen with vertical lines
The screen has vertical lines on it, it won't reset. I've tried taking the battery out for a while, pressing the reset button. I haven't found a solution.
  • redarin7 Nov 04, 2007
    I have the same problem the link dosen't help
Get a new graphics card
Posted on Nov 13, 2007
Question. did you find an answer. I have the same problem. Linda.
Posted on Oct 28, 2007
  • 39 Answers
Http://pocketpccentral.net/help/dellx3reset.htm
Posted on Aug 27, 2007
2 Suggested Answers
  • 4 Answers
SOURCE: Screen frozen with vertical lines
http://www.pocketpctechs.com might be helpful. I am using their services to repair my Axim X30. I will let you know how the repairs went. Beaker 60
Posted on Feb 05, 2008
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
How to unfreeze the touch screen on a htc inspire
try taking the battery out for a short time,then refitting it.turn on phone
Jul 25, 2014 | HTC Cell Phones
Screen has lines through it
Try this, but this wll also wipe all data from your phone. so back up your stuff first
Step 1 Power down the Kyocera Hydro smartphone. If the phone is frozen, pull out the battery, wait a few seconds and reinstall it to ensure the phone is off.
Step 2
Press and hold the "Volume Down" button and then hold down the "Power" button.
Step 3
Release the buttons after a few seconds when you see the Android System Recovery screen.
Step 4
Press the "Volume Down" button to highlight "Wipe Data/Factory Reset" and then press the "Power" button to select it.
Step 5
Select "Yes -- Delete All User Data."
Step 6
Select "Reboot System Now" to complete the reset.
Feb 09, 2014 | Boost Mobile Kyocera Hydro Smartphone
My compaq presario m2000 lcd screen have vertical lines in different colors, how can i remove this vertical lines?
Take out battery from laptop and disconnect power cable. Keep the power button pressed for 30 seconds and then plug the power cable. This will remove static charge from laptop and should resolve the display issue,
Nov 20, 2011 | Compaq Presario M2000 Notebook
It's "frozen". won't change from the screen its
Try to reset it by taking out the batteries and leaving to sit for a minute or so, if that doesn't work take out the small battery as well and leave it sit, if you're still stuck you can call ti-cares (800-842-2737) they're generally very helpful.
Aug 05, 2011 | Texas Instruments TI89 Titanium Scientific...
When I press ON, my calculator screen displays a couple random numbers and letters scattered across the screen, including a solid vertical line in the upper right corner. As soon as I push any key, the...
There are three possible solutions here. From what you are describing to me, you say the screen displays a couple of random numbers and letters, including a solid vertical line in the upper right corner, are scattered across the screen? Sounds like you are still in graphing mode. There is nothing wrong with your batteries and changing them won't help because I already know that you didn't change the CR Lithium Battery. This is the "memory card" for the TI-83 Plus. If you don't change that, when you insert new AAA batteries in the calculator, the memory has not been deleted. You probably don't remember, but the calculator remembers the last problem that you did, which was a graphing calculation. Try pressing the "Graph" button and the calculator will go back to function mode. If this doesn't work, try resetting all the memory.
  1. Remove a battery from the battery bay.
  2. Press and hold the CLEAR button while re-installing the battery.
  3. While still pressing the CLEAR key, press and hold down the ON button. If the home screen displays, release the keys.
  4. If the home screen is displayed, press 2nd MEMto display the memory menu.
  5. Select 7:Reset to display the "RAM ARCHIVE ALL" menu.
  6. Press the right arrow twice to display the "ALL" menu.
  7. Select 1:All Memory to display the "RESET MEMORY" menu.
  8. To proceed with the reset, select 2:Reset. The message "MEM cleared" is displayed on the home screen.
If this doesn't work, try changing the CR Lithium Battery. It is located in the battery bay at the top with the cross-head screw in it (It says BACK-UP BATTERY). It tells you what type of battery it takes and how to insert them in. I hope these possible solutions help. If all of them don't, then the only other thing I can think of is that it has some internal part alignment issues or a cold soldering iron blob, on the inside of the calculator. I saw one time on the Internet that cold soldering irons can sometimes make electronics not work properly.
Jan 14, 2011 | Texas Instruments TI-83 Plus Calculator
My display is frozen at on. Vertical Lines appear on screen
Try to hold down the off button and restart it, if it still shows the same screen take it for servicing.
Feb 23, 2009 | SanDisk Sansa e260 MP3 Player
My delphi xm is frozen
My radio was stuck on "scanning media" and the regular reset (volume up and Mode) did not work.
Nothing that I did, fixed it...
I called Delphi and they said...
(1) Put radio in it's cradle, press Volume UP/Mode buttons for 3 seconds until it resets.
(2)Then when the "scanning media" message appears press up arrow, down arrow, up arrow.
My delphi screen unlocked. I LOST everything that I had recorded, but that was fine with me.
I had to update the firmware and everything is working fine.
Losing all my recorded songs was much better than having to send in my radio!
Hopefully this will work for you!
Delphi was extremely helpful and very nice so don't be afraid to call them if this doesn't work!
Jul 10, 2008 | Delphi SKYFi3 XM Radio Receiver
same problem
if anyone has any suggestions, it would be appreciated.
Nov 18, 2007 | Dell Axim X30 Pocket PC
Ti-83 Plus weird display problem (detail included)
Warning the following tip will erase apps and programs from calculator!
The following will run the self-test mode
Press mode then press alpha then press s then press enter
If you want to get out of the self test press the on button in case you want to attempt to save/transfer apps, programs, variables etc.
The calculator will start to test itself it'll countdown and display numbers on the screen. It can get better sometimes other times a replacement of both the cr1616/cr1620 lithium battery and the 4 AAAA batteries work. Also ensure that you've attempted to clear out all the memory and reset the calculator. To delete all variables, tables, graphs, etc: Press 2nd button then press MEM then press 2 then press 1.
To reset the calculator press 2nd button then press MEM then press 7 then press the left arrow then press 1 then press 2.
Jun 03, 2007 | Texas Instruments TI-83 Plus Calculator
Dell Axim X30 Pocket PC Logo
183 people viewed this question
Clive
Clive
Alun Cox
