Question about GE JKP27 Electric Double Oven
Upper Over Touch Pad dead
There is no display on the keypad. Lower oven works but upper oven does not.
  • Wazir Mar 31, 2008
    Please help to solve the problem: I set the temprature 350F but after reaching 100F the display immidiatley shows 00 and oven stop working No display shows any F code problems or indicator.
    Thanks,
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 68 Answers
This may be related to the F7 error problem. I have posted the solution to that problem on this website. Do a search on "Dreaded F7 Problem" and you should be able to open the link. If that doesn't work for you, email at: [email protected] and I will send you the solution. Regards, Charlie Popeck, P.E. Consulting Engineer
Posted on Aug 22, 2007
SOURCE:
E6 F2 Fault Code on left side Display panel of Whirlpool Accubake Upper oven. There is No Cancel Button on the Display Key pad. Double oven unit has just been cutting off in middle of Bake Cycle.
this is usually a problem with the keypad, most techs would say to replace the keypad, if that doesnt solve it, the main board will need to be replaced. make sure your connectors are tight if you decide to kill power and replace the keypad
Dec 20, 2016 | Whirlpool Ovens
CAN NOT CONTROL BOTTOM OVEN
I assume yiu had the electronic oven control repaired. Sometimes the touch pad also goes bad. I have had to replace them at the same time. If the oven indicator lights showing the oven being on shows up on the display it could be that the thermal fuse behind the oven has gone out. this in in the common line and will shut down both ovens at the same time but you will get the control panel to respond to the touch pad.
Nov 23, 2013 | Whirlpool RBD305PDS Electric Double Oven
I have Whirlpool double oven, model number gbd307pdb7, that after the self clean on the top oven quit working. The original message on the key pas was locked, then it said hot and lastly it had the error...
this most likely happened from when you self cleaned the oven,the oven gets up to 1000 degrees and can damage the electronics on the oven.i will never use this feature for this reason,i use easy off,but the f2 e1 error says it's a bad key panel or the touch pad that you push to control the oven.do you see upper and lower off?if you want to cancel the upper oven you press upper off,you can try to unplug the oven for like 10 minutes and see if it resets it or kill the power,pull the oven out enough to remove the top panel,unplug the ribbon and plug it back in and see if it resets,that code means the board can't read the touch panel,if you press the upper off and it clears and then returns the touch pad is bad part WP8300440 go here go to control panel
https://www.searspartsdirect.com/model-number/GBD307PDB7/1198/0125300.html?searchType=modelSearch&q=gbd307pdb7&searchTerm=gbd307pdb7
Sep 28, 2017 | Whirlpool Ovens
I want to use top and bottom ovens but at different temps - how do I do this
To Set a Cook T ime:
1. On double oven models only, press UPPER OVEN or LOWER
OVEN for the one you want to set.
2. Press BAKE or CONVECT UPPER (on some models).
Press the number pads to enter a temperature other than the
one displayed.
3. Press COOK TIME.
4. Press the HR and MIN "up" or "down" arrow pads to enter
the length of time to cook.
5. Press START/ENTER.
The start time and stop time countdown will appear on the
oven display.
On double oven models only, when both upper and lower
ovens are being used at the same time, touch UPPER OVEN
or LOWER OVEN to display the respective cook time.
When the stop time is reached, the oven will shut off
automatically and "End" will appear on the oven display.
If enabled, end-of-cycle tones will sound, then reminder
tones will sound every minute.
Repeat the process by choosing the other option of UPPER or LOWER OVEN
Sep 04, 2011 | Whirlpool RBD305PD Electric Double Oven
FO beeping on both upper and lower ovens
Hi
Error code F0 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 10, 2011 | GE Profile JTP56 Electric Double Oven
I have a GE double wall oven. I have a F7 errot on display. I unplugged the ribbon cable and shortly recieved a F0 error code on both the upper and lower side of the display. I replaced the ERC. it...
The F7 error coode means either the ERC or touch pad is bad. Having already replaced the ERC,replace the touch pad(the part w/the ribbon cable)
Gene
Aug 04, 2011 | GE Ovens
Error Message F2 E6
Perform the following actions to fix your error:
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'Upper Cancel key ' function and wait for 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thank you !!
May 30, 2010 | Whirlpool RBD305PR Electric Double Oven
How to start oven in PROPANE STOVE
Print the following infore for future ref if you wish. How it works is simple tage a look at it in Motion
Component Test Procedure Results
Electronic
range control
F1−1 –Upper Oven >650°F with door unlocked.............................
F1−2 –Lower Oven >650°F with door unlocked.............................
F1−3 –Upper Oven >950°F with door locked.................................
F1−4 –Lower Oven >950°F with door locked.................................
F1−7 –Membrane switch is not responding ...................................
F3−1 –Upper sensor is shorted at (< 100 ω) or
open at (>5 K ω) ...............................................................
F3−2 –Lower sensor is shorted at (< 100 ω) or
Check actual upper oven temperature,
if > 650°F check sensor.
Check actual lower oven temperature,
if > 950°F check sensor.
Check membrane switch for connection or damage.
Check upper sensor, harness, and connections
Engineering
Test Mode
Press BAKE pad.
Enter 100°F using the number pads.
Immediately push and hold BAKE pad for appropriate oven
approximately 3 seconds.
This mode can also be entered by pressing the hidden pad
for 3 second located to the left of the lower oven light pad.
Used to view the actual oven temperature for both ovens at all
times, even when an oven function is active.
This mode will also display the current fault code for 5
seconds in the time digits.
Fault codes
accessed
through
Engineering
Test Mode
F0−0 –No fault .................................................................
F1−5 –Upper hardware failure within control ....................
F1−6 –Lower hardware failure within control.....................
F1−8 –Shorted key in membrane switch ..........................
F1−9 –Internal communication errors within control .........
F1−A –Upper latch switches ............................................
F1−B –Lower latch switches.............................................
F1−C –Upper door switch.................................................
F1−D –Lower door switch.................................................
F1−E –Sensor input not calibrated ...................................
F1−H –EEPROM error .....................................................
F1−L –Temp in ovens are the same for long period .........
F1−N –Internal voltage on control not working .................
F9−1 –Upper lock switch is not correct.............................
F9−2 –Upper unlock switch is not correct.........................
F9−3 –Control does not see upper door lock....................
F9−4 –Lower lock switch is not correct.............................
F9−5 –Lower unlock switch is not correct.........................
F9−6 – Control does not see lower door lock ...................
EE –Control cannot read E-PROM. Unit will shut down.
Default from factory
Replace control
Replace control
Check membrane connection
Replace control
Check latch wire harness
Check lock wire harness
Verify sensor is operating properly
Replace control
Replace control
Check lock wire harness, and lock switch
Disconnect power for 60 seconds. If EE reappears, replace ERC
Test Mode This mode must be activated within the first 5 minutes of
power up.
Press BROIL and CANCEL pad for approximately 3 seconds.
If oven temperature is greater than 400°F, the Test Mode
cannot be activated or will abort if active.
Press and hold individual pads for 4 seconds to activate.
Display will have dashes in all segments to indicate the mode is
active.
Upper Bake: Energizes upper bake element
Lower Bake: Energizes lower bake element
Upper Broil: Energizes upper broil element
Convection Bake: Energizes convection fan
Upper Oven Light: Energizes upper oven light
Lower Oven Light: Energizes lower oven light
Upper Clean: Energizes upper motorized door lock
Lower Clean: Energizes lower motorized door lock
Stop Time: Energizes Beeper
Cook Time: Displays error codes
Timer 1: Energizes ROM version
Timer 2: Energizes EEPROM version
Keep Warm: Cooling Fan
Clock: All display segments light
If functions do not perform as specified, replace ERC
Oven
temperature
adjustment
Push BAKE pad.
Enter 550°F using the number pads.
To decrease or increase oven temperature. Push AUTO SET
pad until negative or positive numbers appear. Oven can be
adjusted from -35° to +35° (-37.2° to + 1.6° C) in 5° F (2.7° C).
To avoid over adjusting oven move temperature -5° each time.
Push OVEN CANCEL button.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 04, 2009 | Frigidaire 30 in. Electric Gallery Series...
F7 code keeps flashing on upper oven, nothing on keypad works
A function pad is probably stuck.
Push all buttons several times each. Often this will clear a stuck pad.
If that does not work replace the clock.
Mar 04, 2009 | GE Profile JT910SASS Electric Single Oven
Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Nov 17, 2006 | GE Profile JTP56 Electric Double Oven
Ovens Logo
429 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a GE Oven Expert? Answer questions, earn points and help others
