Question about Canon PowerShot SD600 Digital Camera
Powers off my canon powershot sd600 digital camera keeps powering off after about 30 seconds. I have gotten a new battery and that didn't help. On the left hand side before it shuts down it has the letter and numbers E18 on the bottom. The zoom lens is also sticking out and will not retract. There are no error messages on the camera at all. If anyone has a solution please let me know. Thanks!
  • Lyn Richard
    Lyn Richard Aug 22, 2007
    When you told me it was the lens itself, I just pushed it in a little and now it works fine. I can't believe it. I was afraid I would break it if I did anything to it, but to my surprise it worked. I hope it keeps working and maybe if anyone else is as lucky they could try giving it a little push and it will work for them.
    Thanks!
  • 31 Answers
E18 is a lens error message, the lens is stuck or bent, and wouldn't come out, that's why camera shuts off after it tries to do so at the start, not much you can do, but replace the whole lens assembly
Posted on Aug 22, 2007
I have a Canon PowerShot SD600 Digital Camera. The battery has a full charge but the camera will not power up. I press on and nothing happens. What do you recomend?Best RegardsNeil
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Oct 02, 2011 | Canon PowerShot SD600 Digital Camera
Battery fully charged. but canon powershot sd600
Your problem may be due to worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Sep 26, 2009 | Canon PowerShot SD600 Digital Camera
Camera won't power up
You might try cleaning the battery compartment of the camera to make sure that the contacts are not corroded.
Jan 07, 2009 | Canon PowerShot SD600 Digital Camera
My powershot sd600 elph, won't power up. brand new battery, why?
smtimes new battery also may have problem of low power....
u should try it another camera and see it works or not....
if again same problem comes then definately get damaged....
if it runs good in nother camera then i think there is still havin sm problem in urs camera....
show it to ur dealer for more infomation....
Jun 08, 2008 | Canon PowerShot SD600 Digital Camera
Canon powershot SD600 - flash doesn't work
I have the same problem.. however I did leave my camera in my car for the past couple of weeks.. and it has gotten pretty hot in there.. I'm guessing the heat busted my flash..
Mar 28, 2008 | Canon PowerShot SD600 Digital Camera
POWERSHOT SD600 WOULDN'T SWITCH ON
Hi , try to remove memory remove battery from partment clean contacts and assemble again .
Mar 22, 2008 | Canon PowerShot SD600 Digital Camera
My lens wont fully extend
My sister's camera was having the same trouble and after trying a few different things, i came across a solution that fixed her camera. Her error said "lense error, restart camera."
I held down the shutter button for a few seconds, then i held down the power button as well. I tried it once or twice and then it worked. I hope this helps!
Mar 29, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
95 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
