Question about RCA RS2620 Single Cassette Deck
RS 2620 has power but I do get any sound
My RCA RS 2620 stereo unit has power but I am not getting any sound. I have read some of the solutions but I would like to know how do I go about repairing the problem myself. For example, what part do I need, where can I get the part, and what are the steps to make the repairs.
  • 1 more comment
  • mousetrap46 Mar 18, 2008
    Replaced power amps TDA 7296 to no avail. There's no headphone output either but then I don't know if that is pre or post amplifier.. All of us really need a schematic but can't find one. the must be a switching chip that select the source at the root of the problem???
    Denny
    [email protected]
  • Anonymous Aug 24, 2008
    I have no sound in any devices i select: (tape, aux,cd,...).
  • Anonymous Apr 04, 2009
    no sound, but can hear a humming noise if speakers are turned up
    Sergeant:
    Champion:
  • 319 Answers
If you are not familiar with electronic circuitry, I would strongly suggest you did not try to service the unit yourself. There are many circuit functions that need to be tracked and evaluated, any one of which could be the problem or one of the problems.
Please consider taking unit to to serviced
Posted on Aug 03, 2008
SOURCE:
What rs remotes will work with a rca rs2610 book shelf stereo?
Remotes.com has a replacement remote that will work here: http://remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=+rs2610&uuid=14001121456810 . The original remote has the part number: ZA90459 . If you can find this remote, it would work. The other models of RCA RS stereo remotes won't work.
I hope this helps.
May 14, 2014 | RCA Televison & Video
Where is the aux jack for the RCA RS 2620 bookshelf stereo?
The Aux audio L/R input jacks are below the On/Off button on the left side of the front of the stereo's main unit. The headphone jack is just below the input jacks. You will probably need an adapter to split the stereo output from the Blackberry (probably a 3.5 mm stereo jack) to the L/R jacks.
Radio Shack has the manual for the RCA RS2620 here: http://support.radioshack.com/support_audio/doc72/72312.pdf .
I hope this helps.
Feb 04, 2012 | RCA RS2620 80-Watt 5-Disc Shelf System...
I have a RCA RS 2620 and non of the cds play. I have a 5 cd changer
Could you be more specific with your problem? It could just be that the lens is dirty. If not, trace your signal flow and make sure everything is wired and powered correctly.
Jan 04, 2011 | Audio Players & Recorders
My RCA stereo(RS 2620) will not read discs...
it might be the steiro cant read the disk because the cd is scratched or maby it cant read the cd cuz if you put the songs on a cd it might not read hope this helps!!!!
Jun 03, 2009 | RCA RS2620 Single Cassette Deck
Audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
Rca rs 2620 power but no audio
I need to see if the manual has any method of button pushing to get the sound back on. Otherwise, I am not an electronic type of guy that has soldering tools, can tell a resistor from a plug, etc. if that is what is needed to get the thing going with sound.
Dec 14, 2008 | Audio Players & Recorders
Rca 5 disk changer stereo model # rs 2640b
Unit may have defective amp or blown speakers. Have serviced
Aug 09, 2008 | RCA RS2620 Single Cassette Deck
RCA RS 2620
Re-state problem please
Mar 18, 2008 | RCA RS2620 Single Cassette Deck
I had the sane problem: No audio out from any source. Although I was unable to find a schematic or service manual, I did find the defective part was labeled on the circuit board as Q401 and replaced it with RadioShack part number 276-2009 (MPS2222A NPN Transistor TO-92 case NPN silicon). This is not an exact match, but is available at most RadioShack locations for under $1 and has fixed the problem.
Dec 12, 2005 | RCA RS2620 Single Cassette Deck
RCA RS2620 Single Cassette Deck Logo
310 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
