Question about Panasonic PT-AE700U Multimedia Projector
Blueish tint on picture
I have a new bulb, with under 300 hours of lamp life, recently (last 100 hours) a blueish tint is showing up more vividly throughout the picture... Looks bad with dark images. Anyway, I'm trying to determine if this is a problem with my projector itself or if I got a bad replacement bulb through B&H photo. I've ruled out a cable... I get the same results using HDMI, VGA and Component cables. Any help would be appreciated.
  • 5 more comments
  • mainerva Nov 24, 2007
    HI, I also installed a new buld a month or so ago and am now having the blueish tint problem. Has a solution or cause been identified?
  • lobsterman Dec 18, 2007
    I also just changed the bulb and developed a blue ghost on the screen. I dont think this is a conincedence that everyone has just changed bulbs..and gets blue ghost
  • Anonymous Feb 25, 2008
    I also changed a lamp in a Sanyo PLC-UX48 in January 2008 and now observe a bluish tint across 1/3 of the screen.
  • Rumorhazit Dec 13, 2008
    I bought a Pansonic AE700U a couple of years ago from Visual Apex. When I first bought the unit, I thoroughly enjoyed it. I was a little dismayed to find that I only got 900 hours out of my first bulb since they said I should get upwards of 1500. Nonetheless, the unit worked great with my high definition system. I replaced the bulb and everything has worked fine for the last year and I now have upwards of 1800 hours on the second bulb. About 3 months ago the screen got a blue hue that started in the right corner and got progressively bigger until it encompassed over half the screen. The blue was most notable when the background was black or very dark. We weren't sure if the bulb had gone bad since it continued to operate fine minus the annoying blue hue. Then, as we were viewing a movie recently, the screen created a "broken window" in the center two-thirds of the screen that has a yellowish tint. It appears to have pushed the blue hue back outside the border of the "broken window".The best way to describe what we are seeing is it is like looking through a piece of broken glass. There is the standard rectangular image that now has a large oval shaped, jagged "window" in the center. I put up with the blue hue but this new problem makes it too annoying to tolerate. Thinking I should have gone with the Sanyo.
    Annoyed in Alabama
  • waynorth Jan 04, 2009
    It appears we might be running into a Panasonic problem with the projector. I have just started getting the same blue hue without having changed any bulb. The unit is about 3 years old with 1,465 hours on the original lamp.
  • Anonymous Feb 28, 2009
    I have the same problem with my panasonic PT500. A blueish color starting from the right that propagate throught the screen. I had this projector for 5 years and always running in wish mode. The problem started 3 month after I replaced the Lamp.
  • beachgal53 Mar 17, 2009
    We have a PT-AE770U Panasonic Projector. It is 4 years old and we are on the second blub...been in for about 3 months now. We are NOW having a blue tint on the left hand corner of our screen. HOW DO I FIX THIS PROBLEM? Nobody seems to know what to do.
    Is it the lens, filter or the mother board ?
    What is everyone doing about this problem?
    Problem Solver:
  • 6 Answers
No... lcp panels will look different when going bad ! this is the polarization filter, most of the time the one BEFORE the lcd panel (blue in this case). these should be cheap but are not easy to get...so you might pay quite a lot. you can also buy polarization filter sheets and cut them to size. keep in mind to check for the right orientation !
Posted on Jun 10, 2009
    Champion:
  • 221 Answers
Most likely not a bulb problem (substitute a known good bulb if you have one to be sure). more likely is a bad LCD panel inside the projector. the light is split into 3 beams which go through 3 LCD panels (red, green, and blue) which produce the picture. the blue panel could be going bad.
Posted on Sep 13, 2007
SOURCE:
Mits. rear projection tv ws65905 picture has blue color tint
Your blue picture tube is failing. Invest in a new TV. "If" you can find a new set of tubes(you have to replace all 3 red blue and green) they are around $800-1000. Not cost effective. Run the TV into the ground if you want to wait but do not invest any repair money in my opinion.
Jun 01, 2015 | Mitsubishi WS-65905 65" Rear Projection...
My sony kdf 55e2000 rear projection tv picture and sound go out every couple of minutes, green power light blinks 42 times then the picture and sound come back. Does this religiously over and over again...
Hello, it sounds like the lamp has gone bad, it's gone interminent to the point its like a flasher in your cars blinker system. If you remove it, you might see if it's discolored to a blueish tint instead of a shiny silver mirror finish. On those with the small lamp it can be harder to see. the lamp number is XL-2400.....tks
Oct 28, 2014 | Sony Grand WEGA KDF55E2000 55" Projection...
Xl 2400 replacement bulb---dim after replacement
did you use a genuine sony replacement bulb or aftermarket? Often the aftermarket lamps are not up to par with the OEM versions.
Nov 01, 2012 | Televison & Video
My pictures have a purple tint to them
You're either using old/expired film, or taking photos during dusk. Color film is balanced for daylight photography. Using it under conditions other than that will result in varying color casts on the resulting images.
Fluorescent lighting: Greenish
Indoor bulbs: Reddish/orange
Outdoor at night/dusk: Blueish/purpla
Ourdoor at dawn: Pink/blue
Or, you may have just gotten bad print work done. Try a different lab.
Jun 12, 2011 | Canon EOS-AE-1 35mm SLR Camera
I don't know what happened but my monitor is blueish and not shar
pepsi_2_cola, If after reseating the vga plug to vga connector 3-5 times and the problem still persists, you will need to see about having the unit refurbished with new "switch-mode-power-supply"/ "inverter board" and possibly new "cold-cathode-fluorescent-lamps" installed. visit YOUTUBE before doing the refurb thing! Search and view vids on "lcd monitor disassembly" , "lcd monitor repair" the longer ones are more imformative. then get back here with what you have learned about how lcd monitors fail with age and amount of total "ON" hours of use. please state the age of monitor next time! a gateway 1975 could be 4-6 years old! It could also be time for a new one! You DO KNOW that those "cold-cathode-fluorescent-lamps" don't last forever!!!!! 12fixlouie If this was of any help please rat this response on fixya.
Nov 07, 2009 | Gateway FPD1975W 19" LCD Monitor
Bluish tint that starts in lower left corner and goes across scre
i have blueish on right lower corner of screen.... what causes this
Mar 05, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Westinghouse LTV-27w7 HD TV, two yrs old, blueish square flashing on & off, no picture.
if you have warranty work they will direct you to the service center you will need, I do not know of any bb that service tv's.
May 08, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Blueish flickering
Try to put speaker distance from monitor.
Try to remove the display card and fixed it again.
Then boot up your and see .
Apr 21, 2008 | Acer AL1913 19" LCD Monitor
Picture turns blue
bad Lcd's i guess get the projector looked at immediately before something worse happens
Jan 03, 2008 | Optoma MovieTime DV10 Multimedia Projector
Panasonic PT-AE700U Multimedia Projector Logo
1,658 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
